Old 11-26-2012, 06:46 PM
Markie Markie is offline
Mein Auto: 2007 BMW x3 3.0si
My x3 won't start I need help now!!!):
I tried driving my 2007 BMW x3 3.0si today and it won't start I don't here a clicking sound and all the lights work and the radio works I tried jumpim it and it did ot work...pls help me thanks
Old 11-26-2012, 07:33 PM
wil33562 wil33562 is offline
Mein Auto: 2007 X3 / 2007 335i
Hey Markie,
Does the vehicle crank but just won't start?
About two weeks ago on my 2007 X3 (111,000 miles) I had the problem where it would crank but just wouldn't start. I tried jumping it, but that didn't help either. I had it towed to the nearest BMW dealer, 90 miles away. They determined it was a bad fuel pump.
Once it was replaced, I was good.
If I had've known that it was the fuel pump, I could've replaced it myself for around $300.00. But since I had no clue if it was the fuel pump, a sensor, or several other random things, I really didn't have a choice but to tow it in. The final cost for the pump and labor was $820.00.
Old 11-26-2012, 07:59 PM
X3-terrestrial's Avatar
Aficionado
What's up with newbies not even saying hi
So what I get is that you turn the key and nothing happens, but you have power? My two guesses are starter or battery.
Hope this helps.
-Mario Andretti.
___________________
River City Bimmers BMW CCA
2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
Old 11-26-2012, 09:50 PM
Mein Auto: 2004 X3 2.5i
I will add 1 more less likely guess - the immobilizer.
Try the other key in case that one has suddenly lost its chip coding.
But could also be the system (EWS) that reads the key and communicates with the computer to signal that the starter (and fuel pump, etc.) can be energized.
However, starter motor is the prime suspect - failures in later model X3's are not unheard of.
These are the 3 things that will prevent a jump start from working, although for the battery to be the culprit it would have to have suddenly developed a complete internal breakdown.
Old 11-27-2012, 09:23 AM
timarnold timarnold is offline
TA
Mein Auto: 2003 bmw 525i 2005 X3
There is one other possibility. I had the problem on an intermittent basis where everything would power up, but the starter would not turn. I was fairly sure it was the immobilizer, but in fact it was the ignition switch.
Old 11-27-2012, 05:44 PM
Markie seems to have disappeared as quickly as he came.
Very hard to help people when they don't give you much to go on and don't let you know if and how it got resolved.
Old 11-27-2012, 05:45 PM
Alexdfw Alexdfw is offline
Mein Auto: 2007 X3 3.0 si
Interesting... my 07's battery died five years on the spot! Seems like a trend...
07 X3 Platinum Bronze
Old 11-27-2012, 11:14 PM
Thanks guys for the info.. I tried using a different and it still won't start and it's not cranking up
Old 11-27-2012, 11:15 PM
Key*
Old 11-28-2012, 10:26 AM
pfrose pfrose is offline
Mein Auto: 2005 X3 3.0l
I have an 05 3.0i. Mine had the same exact symptoms as you describe. Wife started it, then it instantly sputtered and died. Wouldn't start for a week. I checked the fuel pump, pressure, crank sensor etc. it was only flooded! 4 plugs were soaked. Dried them off and it started right up. My only concern is figuring out how it flooded. Anyway it drives fine now.
Old 10-12-2016, 12:00 AM
br7478 br7478 is offline
Mein Auto: 2007 x3 0si
I have a 2007 x3 0si About once a month it will no crank no start, all the lights, windows, etc works. No sounds from starter. This is after driving awhile. I have new high amp battery. After about 1 hour it starts right up perfect. I would love your input. New to this site so my email is butchralston@gmail.com Hope I,m doing things right on here. thanks a bunch
Old 10-12-2016, 05:39 AM
abscate abscate is offline
Mein Auto: 2006 BMW X3... VOLVO... V
How many miles are on the car? The starters on these cars can fail in stages, so if a jump isn't working starter diagnostics are next.
The starters on the N52 engine (2007- on) are really tough to swap.
The original thread is four years old, and the only ones who stick around that long are the ones too infirm to move, like me.
Old 10-12-2016, 12:23 PM
The car has 135k. I'am a retired mech. But not a BMW mechanic. I sure hope you can help me. Thank you!
