Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > E82 / E87 / E88 1 Series (2008 - 2013)
BMWs throw back to the iconic 2002, with a renewed form and function. The smallest car in BMW's line up but still packs a punch. Available in coupe or convertible, powered by a naturaly aspirated inline 6 in the 128 or the turbo twin power inline 6 rocket sled 135.
Old 11-23-2012, 12:40 PM
ChocolateLab ChocolateLab is offline
Mein Auto: 2000 328i
128i vent valve leaking... How serious is this? DIY?
Sorry guys, I did search, didn't find much...
Was about to buy a 128i but it has a leaking vent valve. Dealer fixed other issues with the car but only reset the SES light on this one because they said it wasn't a critical issue.
Is this just an emissions problem that isn't that big a deal? Is it something I can fix? I'm no super mechanic, but I'm coming from an e46 where most problems could be fixed relatively easily.
Thanks for any help... Was going to get the car tonight, now not sure.
Old 11-28-2012, 07:39 PM
MINI+BMWtek MINI+BMWtek is offline
BMW master tech
Mein Auto: e30 318
Tank ventilation valve? not as easy to replace like e46
Old 12-04-2012, 05:03 AM
JimD1 JimD1 is offline
Mein Auto: 128i convertible
The dealer probably just reset the light because this code normally comes when you don't tighten the gas cap properly. My SUV is a Suzuki and it threw the evap code when new. The dealer wanted to demonstrate how to tighten the gas cap to us. My late wife got tired of it and told me to take it in myself. I talked them into running a smoke test. They discovered the pump that was to pull vacumn to check the system was bad. It was replaced and no more codes.
I would get the dealer to state in writing that they will fix this if it happens again or ask them for a smoke test now. All they have to do is put the car on the lift and get their smoke pen.
Jim
Old 12-19-2012, 03:52 PM
mr29 mr29 is offline
Mein Auto: bmw
Jim
good info to know here
Old 01-05-2013, 06:31 PM
Cyb3r H3x's Avatar
Cyb3r H3x Cyb3r H3x is offline
BMW CCA Member
Mein Auto: 17 Mini 2dr HT; 14 i3 Rex
Jim
I had this happen on a brand new 2011 Honda Accord V6. Threw the code after 1 hour of driving the car off the lot. Took the car in next day and dealer had to replace the entire gas tank system. Cause rats had chew the electrics.
Old 01-06-2013, 05:43 AM
mr_bean mr_bean is offline
Do you know the specific error code that was triggering the SES? I recently had one relating to the evap system and the problem was solved with a software up date by the dealer.
