Old 11-28-2012, 09:05 AM
robertw robertw is offline
Mein Auto: 1999 z3
z3 seat belt guides
i have a 1999 z3 roadster with two broken seat belt guides. i also have a machine shop. i am going to make a set of these guides for my vehicle out of aluminum, would anyone else be interested in a set of these. from what i read, it seems they all break. we could supply these in pretty much any color you would like. please let me know.
Old 11-28-2012, 11:42 AM
Tmabry123 Tmabry123 is offline
Mein Auto: 98 z3 2.8
Im interested for my 98 roadster. Any idea abt cost?
Old 11-28-2012, 12:06 PM
Mein Auto: 1999 z3
seat belt guides
i am not sure what i would need to get yet. i need to see what kind of response i get and i am open for ideas. new are approx. 25.00 ea. i would think around 65.00 to 75.00 depending on color.
Old 11-28-2012, 04:28 PM
CTHuskyinMA CTHuskyinMA is offline
Mein Auto: 2003 Z4 3.0
I look forward to seeing the prototypes! Someone must have tried this before. It'd be nice if they could be installed without having to remove the seat skin.
Old 11-29-2012, 04:49 AM
crappyattitude1 crappyattitude1 is offline
YYZED3M Driver
Mein Auto: '99 ////M Roadster
Interesting....
especially in brushed aluminium. And might I add an amen to CTHusky....
Crappy
(Just outside of Nashville)
Old 11-29-2012, 11:54 AM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
I think there would be tremendous interest in this. Virtually all Z3s have broken seat belt guides and they are quite difficult to replace. It would be worth it to most owners to replace the original guides with more durable ones.
BTW, If you're taking orders, put me down for a pair, preferably in black.
Old 12-02-2012, 08:55 AM
morrieschoice's Avatar
morrieschoice morrieschoice is online now
Mein Auto: 2001 3.0 Z-3 ROADSTER
seat belt guides
I would be interested...black if possible. Will you send me a pm when you make a decision about making them and the price. I would greatly appreciate it.
Old 12-02-2012, 11:31 AM
postalZ3 postalZ3 is offline
Mein Auto: 2000 Z3 2.8
+1 You may also post in other Z3 forums and get more people.
<img src=http://i.imgur.com/JMjPR.jpg border=0 alt= />
Old 12-02-2012, 01:17 PM
vintage42's Avatar
BMW CCA 1405
Originally Posted by Blacklane View Post
... Virtually all Z3s have broken seat belt guides and they are quite difficult to replace. It would be worth it to most owners to replace the original guides with more durable ones...
Originally Posted by robertw View Post
... new are approx. 25.00 ea. i would think around 65.00 to 75.00 depending on color.
I looked at a 1998 and a 2000 Z3 both with broken guides before buying my 1997, whose guides are OK. What is so hard about replacing them? Are they unobtainable as parts, or just hard to install?
Old 12-02-2012, 03:50 PM
OEM seat belt guides are readily available and not too expensive (about $20 US each), but replacing them requires removing the seat from the car and removing the seat leather from the back. That is a many-hour job. I have heard of several short cuts, such as cutting the stitching and re-sewing the leather and installing screws into the foam.
Old 12-02-2012, 04:34 PM
vintage42's Avatar
BMW CCA 1405
OEM seat belt guides are readily available... but replacing them requires removing the seat from the car and removing the seat leather from the back. That is a many-hour job. I have heard of several short cuts, such as cutting the stitching and re-sewing the leather and installing screws into the foam.
There seems to be a short-cut here...
…... am at a loss as to why you basically disassembled the entire seat…... was able to replace the guide in 2 minutes…... slid my hand behind the leather with the washer and pressed the new guide in with the other hand…...
Msg #10
http://forums.bimmerforums.com/forum...eat+belt+guide
Old 12-02-2012, 04:45 PM
That was after removing the seat and disassembling the back. It is still a lot of work. Morrie just didn't remove the leather or back foam.
Old 11-15-2014, 06:44 PM
winninh winninh is offline
Mein Auto: 2001 Z3 2.5i
Seat belt guide
I'd be interested in learning more about the metal seat belt guide stabilizer.
Old 12-02-2014, 09:32 AM
dehard dehard is offline
Mein Auto: 2001 BMW Z3
Z3 seat belt guide fix
THE BEST SOLUTION I HAVE SEEN IS POSTED ON EBAY FOR ONLY $12.00, SHIPS FREE AND FIXES THE BROKEN GUIDES ON BOTH SEATS. IT IS A VERY SIMPLE AND INEXPENSIVE REPAIR THAT SIMPLY ATTACHES TO THE GUIDE AND HOLDS THE TOP AND BOTTOM OF THE GUIDE IN PLACE TO PREVENT THEM FROM SEPARATING WHICH IS WHAT CAUSES THEM TO LOOSEN AND SUBSEQUENTLY BREAK. I WOULD RECOMMEND ONE OF THESE EVEN IF MINE WAS NOT BROKEN AS IT WOULD PREVENT IT FROM BREAKING. GO TO Ebay Item # 150914868208. IT IS A SIMPLE AND QUICK INSTALL AND WELL WORTH $12.00. YOU WILL BE PLEASED.
Old 12-02-2014, 04:03 PM
I had those Velcro things for a while hoping that the drag on the seat belt would some day diminish. I just had to fight to get the belts to retract. One day, the loose belt got caught in the door and I couldn't get the door open. That's when I removed the Velcro things and threw them away. I was not pleased.
I think a better solution might be heat-shrink tubing.
Old 12-04-2014, 12:12 PM
kmassey kmassey is offline
Mein Auto: 2001 S54 M Roadster
I would definitely be interested...black please
Old 12-04-2014, 04:58 PM
I don't believe he's selling them; he's telling you where to find them on ebay.
Old 12-05-2014, 11:27 AM
danzy3 danzy3 is offline
Mein Auto: z3
If I could see a picture of what they would look like after they are done I would be interested.
Old 12-05-2014, 03:29 PM
There are plenty of pictures in the eBay ad. Just go to eBay and search on the item number. From Post #14 above: "GO TO Ebay Item # 150914868208."
Old 12-15-2014, 10:27 AM
someguy1313 someguy1313 is offline
Mein Auto: M-Roadster
definitely interested in seeing a protoype
Old 12-15-2014, 05:21 PM
It's been around for years. Way past the prototype phase.
1999, belt, broke guide, cracked guide, guide, plastic seat belt guide, seat, seat belt guides, z3
