Old 11-29-2012, 12:34 PM
daytona745 daytona745 is offline
Mein Auto: 645CI, CorvetteZ06
Dynamic Stability Control Malfunction
On my 645 CI I had a message "Dynamic Stability Control Malfunction" pop up. Anyone else had this occur and what to do?
Thanks!!
Old 11-29-2012, 12:51 PM
davewoolley davewoolley is offline
D Woolley
Mein Auto: 05-645 / 14 435I
My seems to do it once to twice a week, if I turn car off and restart it goes away.
Old 11-29-2012, 01:24 PM
I just tried that and mine went off also. Wonder why it keps coming back on. One article I read mentioned a steering sensor. Thanks!!
Old 11-29-2012, 01:31 PM
D Woolley
I read that could be the battery so I'm going to get mine checked out.
Old 11-29-2012, 05:00 PM
All-Or-Nothing's Avatar
All-Or-Nothing All-Or-Nothing is offline
Woo Hoo FREE Donuts
Mein Auto: 2004 645Ci Convertible
It's probably the battery.
Old 11-29-2012, 05:54 PM
amennrahh's Avatar
amennrahh amennrahh is offline
BM6er
Mein Auto: 2005 BMW 645ci
Check your power steering fluid level. I had the exact same malfunction and found out that my steering fluid level was low. I topped it off and it solved my issue.
SEMPER FIDELIS
Old 11-29-2012, 07:11 PM
Yorgi's Avatar
Yorgi Yorgi is offline
+1 on the power steering fluid level. Mine was low and caused this error.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 11-29-2012, 07:22 PM
colink colink is offline
+2 on the power steering fluid - this solved mine
Old 11-30-2012, 05:46 AM
Medicus Medicus is offline
Marine
Mein Auto: 2005 BMW 645Ci
I have only had mine come on when I disconnected my battery. Check to make sure that all the terminals are on tight. Also +3 check fluid
Old 11-30-2012, 07:26 AM
ammobmw ammobmw is offline
Make sure you use the correct power steering fluid in case you need to refill it.
Semper Fi
Old 11-30-2012, 07:42 PM
Thanks for all the input. I drove the car tonight and the message was gone. I will still check the power steering fluid tomorrow. I think it uses the Pentosin fluid I used on my Porsche. I bought it from the BMW dealer.
Old 08-06-2014, 05:35 AM
DJ_USMC DJ_USMC is offline
Mein Auto: 07 650
New battery last week and just filled fluid this morning. Error came back on. Wwish i could be +4 but back to the drawing board.
