Old 11-24-2012, 11:23 PM
Sumotide17 Sumotide17 is offline
Mein Auto: 2001 540I/6 Sport
What DIY hasn't been documented?
There are so many helpful DIY guides on this forum so which DIY job has not been documented yet?
Old 11-25-2012, 12:20 AM
Albo's Avatar
Albo Albo is online now
Der ursprünglich....Albo
Mein Auto: OO=[][]=OO
Torque Converter replacement..
Want to learn about your E39 5 Series?
Click Me
2003 530iA - Mumbo Jumbo *E39 in Sig is Not My Car
Originally Posted by edjack View Post
If you don't want to do nothing, you must want to do something.
Old 11-25-2012, 08:10 AM
Fudman's Avatar
Fudman Fudman is offline
Engine rebuild.
Old 11-25-2012, 11:28 AM
If I could buy a used M62 or M62TU I would love to rebuild one. That a pretty intense DIY. Probably month long.
Old 11-29-2012, 02:55 PM
I've been considering renovating the Power Steering lines from reservoir to pump with steel braided lines. I haven't found a DIY to upgrade to steel braided lines yet. Does this sound interesting?
Old 11-29-2012, 03:33 PM
Nervous Nervous is offline
Mein Auto: 01' 330CI 6MT / 00' 540i
Steering lines are very easy to replace. Anyway, it most likely documented in Bentley.
I can tell what is not documented. Manual tranny rebuild (either 5 spd or 6 spd).
Old 11-29-2012, 03:59 PM
matt540's Avatar
matt540 matt540 is offline
Mein Auto: DINAN 540
Dinan F&R strut tower brace, M5 F&R sway bars, Koni Sports, Eibach springs, Dinan stage 1 engine and trans software, Zionsville cooling kit, resonator delete, Dinan exhaust, AFE cai, 18' style 5's, 235/40/18 275/35/18, and some small cosmetics, with more to come.
Old 11-29-2012, 05:40 PM
fullthrottle540's Avatar
fullthrottle540 fullthrottle540 is offline
DINAN 5
Mein Auto: E39
how to permanently repair this crappy cooling system
Old 11-29-2012, 07:09 PM
champaign777's Avatar
Mein Auto: 2010 550i M Sport
how to rebuild steering rack
E39 4 ever
M54 GARAGE SALE
2003 530i 107k miles for SALE
Old 11-30-2012, 04:30 AM
mr magoo mr magoo is offline
Mein Auto: 2000 528i
Steering lines
My upper lines leak at the reservoir. The Rez-to-pump line looks easy. the rez-to-radiator hose confuses me as to how to detach from the radiator. do all 4 lines have to come out of the radiator to replace 1 line?
Old 11-30-2012, 07:21 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
There was one, but it did dissapear, the link is not working anymore. However, here is one for Acura. Different steering rack, but probably close. And here's Cam's steering rack removal procedure. An old e30 guide.
Found a vid as well, maybe it can help:
Looking for a DIY? Parts? Check this out, it might be your ticket
TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint
Stable: e39 M54, e53 N62 & Tribby
Old 11-30-2012, 07:41 AM
BentValve's Avatar
BentValve BentValve is offline
Mein Auto: 00 528i 3 pedals
LSx swap...lol
Old 11-30-2012, 07:51 AM
Yes replacing the power steering lines are very easy. I am speaking about a DIY on how to fabricate/ retrofit those same lines with professionally adapted high pressure steel braided lines. I suspect this would help preserve the PS lines a lot longer, match the oil filter lines, and help correct the reservoir leak along with installing new cap o-ring. At least one of those lines is a HIGH pressure and susceptible to failure and I'm sure we will all receive better steering control as a result.
I talked to these folks in Fremont, CA and I will be working with them to ACTUALLY see if it can be done.
http://www.hoseandfittingsetc.com/
Old 11-30-2012, 07:58 AM
^ That definitely sounds interesting!
Old 11-30-2012, 09:48 AM
Reuvers Reuvers is offline
Mein Auto: BMW e39 540i '97
Doru, tried to look at a couple of diy's on your sig link; however problem I encounter, and this is common with many links/forums, is that either pics are removed from threads or links don't work at all...
I have been searching for a good diy on throttle gasket replacement on a m62 pre vanos. Reason is that I am unsure how to remove the bottom bolts...seems like all sorts of parts are in the way. TIS explains it, however it seems they skip several steps to show finished product.
Old 11-30-2012, 09:56 AM
doru's Avatar
Yes, I know. I saved a few that interests me directly as pdf's on my home computer, fearing that they will dissapear. Sorry, but I can't help you. I tried contacting some of the members, but I think they left the forum for good, and don't check the pm, or the other that were linked from outside sources, some web pages don't exist any longer. You can try to contact some sellers that have an active help forum for DIY-ers, like Pelican or Bavauto. They have quite a few procedures in detail, even if they are for different other model BMW's, some are similar.
hope this helps.
Old 11-30-2012, 10:35 AM
Albo's Avatar
Click Me
Old 11-30-2012, 10:40 AM
doru's Avatar
Try this one out
Old 11-30-2012, 11:20 AM
This is for M62TU, but pretty close to M62:
http://www.beisansystems.com/procedu...anos_procedure
Old 11-30-2012, 02:34 PM
hh3uunp hh3uunp is offline
HE's back
Mein Auto: 540i 6 01
The awesome hit a tree mod... No wait lalaray has got that covered
I got a m5!!!!!!
