Drop all the hammers you want, but I have a legit Winter Tire question! - Bimmerfest - BMW Forums
Old 11-29-2012, 10:58 AM
agbasher agbasher is offline
Mein Auto: e90 335i X-drive
Question Drop all the hammers you want, but I have a legit Winter Tire question!
I know I am going to get massacred for this ("search previous discussions", "this has already been answered", etc.) but I have a winter tire question and I CANNOT find a previous discussion about it!
Just got my second ever BMW -- first in several years -- e90 335 x-drive / m-sport. Just swapped summer 18"s with winter 18"s that came with it.
WHOA! Horrible ride. Squishy, much worse handling, etc. IS THIS NORMAL?!
Thanks, and please refrain from what I probably deserve.
Old 11-29-2012, 11:06 AM
floydarogers's Avatar
Pedant and Curmudgeon
Mein Auto: 335d, 328d, Toyota T100
Yes, it's normal. If you read all the winter tire threads you'll discover mention of this, but it's not the #1 element of most of the threads. I advise you to go to tirerack.com and read about winter tires there.
Old 11-29-2012, 11:08 AM
Alarbus Alarbus is offline
Mein Auto: '09 328xi
Yup. Summer and winter tires have entirely different purposes. I'm holding off on swapping mine, since the car feels like it floats, and I just picked it up. (Sold my 2006 and bought a 2009) I wanted some fun time before I have to be practical, but I'm probably only good for another week.
That's also why it's not good to run winter tires in warm weather - the softer compound wears faster when it's warm. Plus, the tread is designed for snow, and will function poorly without it.
A lot of people just run all seasons in the winter as more of a compromise. Vermont weather is bad enough I just use snows for 4-5 months.
2006 325xi 6MT Electric Red - Sold
2009 328xi 6MT Barbera Red
Old 11-29-2012, 11:33 AM
galahad05's Avatar
galahad05 galahad05 is offline
Better with Butter
Mein Auto: 335i sedan 6MT
Winter PERFORMANCE tires can (somewhat) bridge the gap in handling and feel between true high-winter tires and summer performance tires.
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 11-29-2012, 11:36 AM
Are All Seasons an OK Replacement?
The winter tires I have are nearly run down, with just enough tread for one more season.
I am considering All Seasons as the replacement and not winters. These winters are HORRENDOUS!
Old 11-29-2012, 11:39 AM
DSXMachina's Avatar
Bimmerdex 7.4!
OP, you've tested backwards. Wait until you've got 6" of fresh snow on top of an inch of hardpack. Do your driving test again. Let us know which tires you like then!
FYI, some of the very best Winter tires are the worst for dry performance. It's the nature of the beast. You want the best Summer tires you will have the worst Winters, and vise versa. I will give you some encouragement though. You are going to notice that your Winter tires perform better and better on snowless roads as time goes by. They will be at their best just before you junk them.
Old 11-29-2012, 11:56 AM
Oh, if only, IF ONLY, cheap summer tires functioned as great winter tires. IF ONLY.
Old 11-29-2012, 01:44 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
I run an xDrive with winters 3 months of the year, and all-seasons the rest of the year.
We got an early snow storm a few weeks back, so I was on it on relatively new Continental DWS All-Season tires (about 5000 miles on them).
In the rain at the start of the storm, they were fine.
In the snow, they were OK (not great, not good, OK).
However, I got onto one section where there was 1/2" of slush on patches of ice. Past winters on the snow tires, this type of surface was not a problem if care was used. However, with the A/S tires, I was going under 5 mph (creeping at a light) and suddenly found myself sliding with no control at all. Zero. Nada. None. I slid for about 15' at less than walking speed until I got back onto slush-on-pavement under the new A/S tires.
There are people here who insist A/S tires are fine, if you just slow down. If there's ice involved, they're wrong. Grossly, utterly wrong.
If you expect to see wet snow coexisting with ice, you need winter tires. Dry ice, A/S are barely tolerable. Wet ice, A/S tires are not acceptable, regardless of how many people start telling you how many years they've used them without a problem.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 11-29-2012, 02:14 PM
Thanks all
Thanks everyone for the perspective.
I live in MN and definitely face torrents of extreme winter conditions.
I think I will be slower on the trigger next year in putting on my winters.
Old 11-29-2012, 05:21 PM
DSXMachina's Avatar
Bimmerdex 7.4!
MN??? Why are we not discussing the use of studded winter tires vs. chains?
Old 11-29-2012, 05:28 PM
Orient330iNYC's Avatar
Flying monkey herder
Mein Auto: Daihatsu Terrios
Originally Posted by dsxmachina View Post
mn??? Why are we not discussing the use of studded winter tires vs. Chains?
chains vs tracks. Discuss
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 11-29-2012, 06:06 PM
jummo's Avatar
jummo jummo is offline
False Enthusiast
Mein Auto: 14 435xi 14 X1 35i
This is how I roll.
jummo
"I know you were offended, but jummo's advice was sound."
Old 11-29-2012, 07:18 PM
Squidget Squidget is offline
Mein Auto: 2011 335i E90 (MT,Sport)
Rule 1: Check your local laws! Often one or both are against statute and will cost you quite a fine.
BMW CCA Member
Old 11-29-2012, 08:33 PM
A set of rims per set of tires is great. If you decide you put them on too early, a bit of time in the garage fixes it.
Old 11-29-2012, 09:20 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 11-30-2012, 05:08 PM
pointandgo's Avatar
We presume that you don't have studded tires? Winter tires usually have all the (tread design) features that will result in less precise handling "feel," such as: slightly deeper tread depth, "softer" tread rubber, numerous slits and "sipes." All this results in a more "squirmy" tire footprint...especially when new (or underinflated!). The sensation will improve as they wear down as noted above.
Probably the greatest contributing factor is the tread rubber compounding which is specially formulated to stay soft in sub-freezing temps. Quite the opposite of what we want for crisp handling. As they say, all tires are a compromise of sorts, and dedicated winter tires are certainly a compromise for winter snow traction.
Don't try to take that on/off ramp at the same speed that you're used to with your summer tires...the winter tires certainly won't pull the same G-loads!!
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
