Noise after shutdow
Guys, I need a little help on a noise that I'm hearing after shutting down the engine. i have a 2001 330i (e46). Here's a link to the sound file to hear what I'm talking about......The sound is around 6 seconds in and again at 22.
Any thoughts appreciated! Last edited by jwchi; 11-30-2012 at 07:46 AM. |
Link is dead, and this is not the X5 Forum....
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
2001 330i (e46)
corrected link, thanks Last edited by jwchi; 11-30-2012 at 07:47 AM. |
Might be better to do a YouTube video of the sound... I, for one, am not downloading a file from your Google docs.
The woosh sound is your CCV letting off vacuum pressure. It's normal - mine's done it for as long as I can remember. If it starts to sound like a fog horn, chewbacca, dying duck, then it's clogged and needs replacing. Most people replace around 80-100k as preventive maint as they tend to clog and the hoses get brittle and leak.
^^^^^+1.......vacuum purge and totally normal
So, since mine doesn't make this noise at shutdown, is this a sign that mine has a defect?
Not necessarily.....the sure sign of a bad CVV is when that "whoosh" sound turns more to a foghorn noise. There are tests you can perform to test yours out and directions are either in the WIKI or can be found by searching similar threads on this site.
Thanks for the help guys!
| Tags |
| noise, shutdown |
