Old 11-30-2012, 10:50 AM
CMRTN CMRTN is offline
Speed Racer
Mein Auto: 98' 540i/6
Aux Input
I was going to post something on this late last night, but decided to hit the sheets instead. I'm long burnt out on burning cd's and have been wanting to do an aux install. I have a 06/98 540i/6 with the tape deck and DSP. I was planning on following this write up this morning.
http://forums.bimmerforums.com/forum....php?t=1763361
Then I pulled out the tape deck and saw this(See attached image), so the pins i was planning on tapping to isn't the same to the diagram on the diy posted above. I know about the Dice adaptors and upgrading to CD53 but is there any way i can just tap into this unit for an auxiliary input? I'm at home and had the day off wanted to do something to the car.
Old 11-30-2012, 03:49 PM
240sxguy 240sxguy is offline
Mein Auto: 1998 540i/6
It's obviously a bit late, but you can do aux in by disassembling the tape deck and soldering in a plug. You're gonna have to google this one, but I have seen it done and the PO did it to my car before I got it.
Old 11-30-2012, 04:15 PM
Nline6's Avatar
Nline6 Nline6 is offline
Slip slidin around town
Mein Auto: E36 M3
I think the DIY with tapping into the tape will still give you tape quality? I am in the same boat, I am using a tape adapter. I used to have the dice kit and I wasnt much happier with that set up.
Old 11-30-2012, 10:04 PM
NoWayJose's Avatar
NoWayJose NoWayJose is offline
Mein Auto: 00 528ia Sport
this is how i did it
http://www.bimmerfest.com/forums/sho...229&highlight=
00 BMW 528ia Sport
M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, Euro Lens, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza Orion halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks with H&R Sport Springs, 19" M6 Reps, Full LEDs.
Old 12-01-2012, 11:55 AM
Speed Racer
I cant use my cassette player at all because whenever theres a tape in there the motor that spins the tape is loud. I think I'll just end up getting CD53. Seems like the best way to go here, unless there is a way to do this that I haven't found yet.
