E34 (1989 - 1995)
Old 11-25-2012, 05:36 AM
mark cherry mark cherry is offline
Mein Auto: 535i & 318is
Question virgontour
1989 5 series e34 3.4 engine automatic..... very sluggish off the start , any tips to improve this .....
Old 11-25-2012, 05:50 AM
Banned
Mein Auto: car
Ok lets start with what you have done or checked recently so far, please list that here.
And do take a look at the relevant table here as well :
http://www.bimmerfest.com/forums/sho...d.php?t=658957
Old 11-25-2012, 07:13 AM
The Ornery Old Man
Mein Auto: GTI
Manual gearbox, lower rear differential ratio, sell it and buy a V8
The engines 4200 rpm torque peak and the transmissions 2000 rpm stall speed will never conspire to give you aggressive off the line acceleration.
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 11-26-2012, 01:33 AM
BMWFatherFigure's Avatar
Old School
Service it properly, tune it correctly. If it's still too slow for you - bigger engined BMW here you come.
Current:
E38 Parts Car
Previous:
Old 11-26-2012, 03:21 AM
Ssuss34 Ssuss34 is offline
http://i1341.photobucket.
Mein Auto: '89 E34 535i
Push your foot down harder.
Old 11-28-2012, 05:56 PM
im ready to cut a hole behind accelerator pedal to get more get up and go ..lol
Old 11-28-2012, 06:02 PM
ok... nothing has been done to engine all stock.... was sort of asking what direction would i start at without spending $$thousands$$ like a few of the lads have
Old 11-28-2012, 07:10 PM
Josh429er Josh429er is offline
Mein Auto: 1989 BMW 535i
These motors really don't respond to upgrades. If you think It's slow It's because It's behind on maintaince somewhere. Also second and third is where mine shines. 1st is just to big to for being quick. Just takes to long to get to 3.5k and up, where it signs.
2003 GMC Sierra SLT 2500HD CC/SB
Old 11-28-2012, 08:01 PM
Banned
Mein Auto: car
First time i have heard that a 3.5litre is sluggish. Please get your car's codes scanned. Something is clearly wrong somewhere. Might be your air flow meter.
Old 11-28-2012, 11:29 PM
Agreed, It's not fast but it moves.
Old 11-29-2012, 09:06 AM
Monsignor's Avatar
BMW CCA Memeber #445389
Mein Auto: Sig
tune-up
"the car ran fine for 20 years! how after 4,567,092 miles would it become sluggish?!"
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 11-29-2012, 09:11 AM
"My car ran fine for ten years, how after 9 years of no oil change would it now be sluggish" - first or second owner to my car
Old 11-29-2012, 09:30 AM
Banned
Mein Auto: car
Someone actually told you this ? Which oil was he referring to, or was he talking about everything ?
Perhaps lifeguard would be able to go the distance for a transmission, but not engine oil. Surely the engine would have fallen apart long before that.
Old 11-29-2012, 09:29 PM
Funnily enough, I now know what you mean by "sluggish". I also have a 535, Last week i'd floor the accelerator and it would have great acceleration and rev high up into 1st gear then change to 2nd gear. Now, for some unknown reason, I floor the accelerator and it feels like its starting in 2nd gear and takes forever to rev out and I have not done anything to the engine. TELL ME HOW TO FIX IT
Old 11-30-2012, 10:37 AM
Banned
Mein Auto: car
Reset your transmission. Delete all error codes. Unclamp your tcm and ecu for a few minutes. Then take the car for a test drive.
Old 12-01-2012, 06:19 AM
Old School
or remove the battery leads at the terminals and join the cables together
Current:
E38 Parts Car
Previous:
Old 12-01-2012, 06:41 AM
Banned
Mein Auto: car
This idea of joining the cables together has to do with the notion that there is some balance electrical charge left in the system due to the presence of capacitors. And, as long as there is a balance charge, the existing error codes are kept alive and undeleted on the system.
To get rid of this capacitance, I used to recommend that the ignition be key2ed following removal of the ecu clamp, in the effort to delete error codes.
I'm not so sure that it works this way. Could someone with a code reader confirm ? Its easy to create a code...just disconnect the afm while the engine is running.
Old 12-01-2012, 08:21 AM
No it was a joke to the previous statement and the fact my 535 was horribly maintained before me. The diff oils probably at 9 years however hahaha
Old 12-01-2012, 08:33 AM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
i found that adjusting the linkage at the throttle body eliminated most all of the hesitation in accelerating on my 20 YO BMW.
Old 12-01-2012, 04:05 PM
Banned
Mein Auto: car
Mark, what does "virgontour" mean ?
Old 12-01-2012, 04:52 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
is it missfiring at all?
E30 above Sold
Last updated 2nd January 2014
