Old 11-30-2012, 11:17 AM
danobox danobox is offline
Mein Auto: 2006 X5
Cooling System
I have a 2001 330xi with 70,000 miles. The temperture when I turn on the car either goes straight to the middle or to the right 1 to 2 degrees after it warms up, after this it does not move. I was wondering if the temp sensor would be going out or what could cause this. I think there are two sensors and which one would I need to change.
The other question is it easy to change them or would it be a tough job?
Old 12-01-2012, 07:17 AM
KillnTime KillnTime is offline
Mein Auto: BMW
Do you mean the temp needle goes right to the middle position as soon as the car starts or does it go to the middle after you've driven for a few miles?
Old 12-01-2012, 09:47 AM
Mein Auto: 2006 X5
It goes to the middle after it warms up
Old 12-01-2012, 11:23 AM
joegr joegr is offline
Mein Auto: 2002 325i
So, what are you saying is wrong with it?
Old 12-01-2012, 12:22 PM
Mein Auto: 2006 X5
After it warms up it isn't consistent every time. It is either exactly halfway, or 2 degrees past halfway. I'm wondering if the sensor or thermostat is going bad.
Old 12-01-2012, 02:38 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
If the car *doesn`t* overheat, but gets up to proper temp (relatively) quickly, and you`re getting good heat from the vents, there`s probably nothing wrong. BMW temp gauges are heavily buffered, so they`re not all that accurate like a REAL mechanical gauge would be.
The road goes ever onward....
(R.I.P. Jever)
Old 12-01-2012, 06:19 PM
It would be more likely to be an issue with the gauge in the cluster. However, two degrees of movement is very small and I would expect that to be within tolerance.
You can put the cluster into test mode and get a digital readout of engine temperature.
Old 12-02-2012, 11:39 AM
This E39 M54 thread may help for the E46 M54:
- What is the temperature of the coolant when the thermostat opens under normal conditions (1)
