E89 Z4 (2009 - current)
Black Kidney Grills
I am going to purchase new black kidney grills. I see that there are gloss black ones and matte black ones. Can anyone suggest a better option? Would like to order within the week.
I prefer the matte black look myself.
BMW Z4, red on black with aluminum trim, Sport Package, Cold Weather Package, Comfort Access, 6 speed manual. |
The gloss black versions would be done by BMW performance, and I personally think they look great. We do have a matte black option as well, strangely not listed on our website, but it is available as well if you're interested, for a lower price than the BMW performance:
![]() BMW Performance Gloss Black Grilles E89 Z4 Send me a message over the forums or via email and I'll help you out if you have any further questions!
![]() We Specialize In: BMW Wheels | KW Suspension | AE Performance | Remus Exhaust | Forgestar Wheels | BMW Angel Eyes Jurrian Terpstra | Jurrian@ModBargains.com | (714) 582-3330 ext. 8002 Hours: Monday - Friday 8:00am-5:00pm (PST) |
hi I replaced my chrome with Black Gloss, personally better match with the black sapphire gloss finish. Matt is too flat IMO
Does my bum look good in this ! |
I've seen pictures of kidney grills that have black slats but chrome rims. Are those available from BMW or Modbargains?
Since when does the color, or better yet lack of (especially plastic) make it performance.
Everyone knows that chrome valve covers make cars faster...this fact was proven by hot rodders the fifties...duh
Also thinking about replacing my chrome ones on my saphire black Z4 35is. I was think the carbon fiber ones might look good. Opinions?
z4 black grill
I purchased the glossy ones and they look great on my Jet Black Z4. I guess it is a matter of taste - glossy in my opinion looks cleaner on Jet BLACK
Thanks |
I removed my Chrome with Grey grilles, separated the inserts, sanded them with 600 and painted just the inserts with Gloss Black paint, for plastic, and kept the chrome ring.
This is a very easy mod and cost $8.00 vs spending $100 plus on new. You too can sand the chrome rings and paint them also, gloss or matt black, your preference. I like the Chrome/Black contrast look.
I actually did buy the gloss blck ones and they look awesome. I also had the bottom front facia painted white. Pictures will be posted this weekend. Now onto the rims......
2011 E89 Z4 30i Crimson over Ivory (Munich delivery, redelivery at Performance Center) 2003 E46 325i Touring Oxford Green over Sand |
Removing the grills- very easy BUT patience is key. For the 35i- 1st Remove the air intake from inside the engine compartment. There are 4 small bolts to remove the complete air intake. This gives you tight arm access to reach down and have access to the inside of the grills. There are 8 clips for each grill- 3 across the top, 1 on each side and 3 across the bottom- see my picture with the grill removed and see where the clip slots are located. With a small flat head screw driver find the 1st clip located along the top working from the outside in towards the center 1st. Gently put pressure upwards on the clip with one hand and gently pull down and out on the grill from the outside. The 1st clip is the hardest. When the clip is free you should hear a small snap and the grill then should slightly pull out. Once the 1st clip pops, move to the center clip with the same procedure and then the last top clip. Next pop the side clips starting on either side, with the same procedure. They should snap free fairly easy. Now the challenge. Now that you have the top 3 and 2 side clips undone, the grill will pull out appx 1 inch and allow access to the bottom clips ONLY with a Long thin tool inserted under the grill from the outside. I used a very thin hook end shaped tool. The bottom clips are hidden behind a metal structure beam. Gently pull the grill out and up to allow you to side the tool under the grill bottom going in from the side and work your way along the bottom of the grill. With my picture and knowing where the 1st clip is located slide the hook end under the grill from the side. Once tHe clip is located, gently twist up to unsnap the plastic clip. Now keep moving along the grill bottom in the same direction to the last 2 clips. Again use my picture to know exactly the clips are located for reference. It took me appx 30 minutes to get one off then very quick on the 2nd as I know where the clips were located. Patience is key.
