BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#151
#152
![]() Anyway, I went through the new instructions and moved things around a bit. In your instructions you state, "Make sure that there is a "Dist" folder in each of the Chassis (F01/F10/F25) folders etc." My psdzdata folder (now in it's proper place) has nothing but files with the pattern psdzdata.7z.001 through 030. There are no subdirectories in C:\E-SysData\psdzdata. I'm also not sure where the cafd* files should be. I guess they should be copied to C:\E-SysData\CAF?
Joe Morris 2013 X3 28i (prem, tech, cold1&2, conv, hud) |
#153
When done just copy the PSdZData folder per my instructions. Don't do anything else. The CAFD files will be in the right place nested under the PSdZData folder.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 11-30-2012 at 02:45 PM. |
#154
Awesome. Everything in place right now. Just waiting on the ENET cable at this point. LED's arrived and ready to put those in too.
#155
The files have been uploaded to usenet as well:
Link to Usenet So feel free to grab them there as well |
#156
hi you can send me link of PSDZDATA 48.1 on my e-mail..?
andreabasso39@yahoo.it thank you very much |
#157
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
#158
Hi Shawn,
I have the 47.5 files, could you please send me the link to new 48.1 files. Many Thanks |
#159
PM Sent.
#160
Many Thanks Shawn.
#161
Per your instrcutions: 10) Run "C:\EC-Apps\ESG\E-Sys\E-Sys.exe"... However, the shortcut that is created on the desktop during the e-sys install points to "E-sys.bat" in that same folder. The .bat file seems to setup alot of options (e.g. memory setting, etc.) and paths that does not overide any of the parameters we put into the settings following your directions): -----partial example of e-sys.bat file content: SET ESYS_DATA_PATH=%ESYS_DATA_PATH:\:=:% SET ESYS_DATA_PATH=%ESYS_DATA_PATH:\\=\% set JAVA_HOME=%~dp0jre set PATH=%JAVA_HOME%\bin;%PATH%;C:\EDIABAS\Bin;C:\EC-Apps\EDIABAS\Bin cd /D %~dp0lib\environment :startEsys rem VM arguments set OPTION_THREAD=-XX:ThreadStackSize=1024 set OPTION_ENDORSED=-Djava.endorsed.dirs=..\xml set OPTION_MEMORY=-Xmx512m set OPTION_JMX=-Dcom.sun.management.jmxremote set OPTION_GC=-XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode ---See actual .bat file attached for remainder--- Should I set the shortcut to point to the .exe file instead so as to not run the .bat file? I clicked on the desktop icon (starting using the .bat file) for the first run and then made the following changes per your install instructions (which are still there if I start with the .bat file or the .exe file): On the PROGRAM TAB, set the Directories - Data Path to C:\ESysData On the EST Tab, set the Developer-Soft-Token EST Path to "C:\ESysData\e-sys est\Code Away.est" On the ODX Tab, set the ODX Rule Path to "C:\ESysData\Rules" I would think we would want to run the .bat file provided with the e-sys install that the shortcut points to for other e-sys default settings, but then we would not be following your instructions exactly as written. Probably does not matter either way... Question #1: but it would be nice to know if there is a specific reason to bypass the .bat file provided with the e-sys install or if it just does not matter either way? Question #1A: If I shouldn't be using the .bat file, did I accidentlly change some option that I shouldn't have like the memory setting of 512m that my e-sys is set to even if starting with the .exe file (e.g. should I do a re-install and this time not use the e-sys.bat file / desktop shortcut to start e-sys ever and only use the e-sys.exe in which case I will change the target in the shortcut to the .exe file)? Question #2: On another subject, I assume it is OK to delete the extracted install folder "E-Sys_EST_PIN" once I have completed all steps of the installation or will I need other files in there readily available during coding (I did keep the original compressed / *.rar files as downloaded in case of a need to re-install)? Last edited by Glock 32; 12-02-2012 at 03:04 PM. |
#162
I would not worry either about the .bat file changing the default E-Sys settings, as it won't. The .bat file should just be session specific. You can delete anything that the instruction does not specify it be copied and put in use or is left behind after doing so.
#163
Shawn, can I please have the 48.1 links. Thanks.
Regards, Alex 2012 w204 Mercedes-Benz C350 4MATIC MY 05/2012 Black/Sahara 2011 F10 535i xDrive MY 01/2011 Sophisto Grey/Black |
#164
#165
Can you please pm me the link to the files also. I currently have 4.75, Just picked up my 335i yesterday. Dont know if its compatible with it, planning on downloading 47.7. Should I download it or just use your 48.1 stuff? Also how do I go about using the file you sent me. Never coded a car before. I have the steps on how to set up and code though. Also does coding void the warranty, I have extended warranty on my car. Planning on taking to dealer to code the A.S.S. but I also want my windows to keep rolling up when I open the door. Thanks a lot in advance.
#166
Add 48.1 CAFD files to your existing 47.1 PSdZData by copying them to C:\ESysData\psdzdata\swe\cafd folder. Do not waste your time downloading 47.7. Follow the Getting Started Coding Guide to understand FDL Coding. If you encounter a problem, let me know. Simple FDL Coding will not void your warranty.
#167
Windows up when door is open, also up with holding the lock button, tire pressure #, dvd in motion, fold mirrors with keyfob. |
#168
All of that is simple.
#169
Hi Shawn,
Please can you send me a link to the updated files? Mine went in for servicing and received a random update that broke all my tricks ![]() With thanks |
#170
PM sent.
#171
Hi shawn
please could you send it to me too? Is it possible to update to v48.1 from V46.3 directly? Many thanks Utzeman |
#172
PM sent.
#173
Shawn could you PM the link to 48.1.
Current: 2013 BMW 535i GT- Neptune Blue-Venetian Beige Nevada Leather-Fineline Matte Wood Trim-ZCW/ZVP/2ST/3AG/416/677 2005 BMW X5 30i- Kalahari Beige-Sand Beige Nevada Leather-Dark Burl Walnut Trim-ZCW/ZPP/ZRC/508/522/609 Former BMW's: 2010 BMW X5 xDrive 48i 2003 BMW 745Li 2001 BMW X5 30i 1995 BMW 525i |
#174
#175
Hi shawn.
Could you tell me the link of version 48.1? Thank you. |
