Old 10-05-2012, 06:21 AM
lifo_1 lifo_1 is online now
Mein Auto: F10
F10 - Remove TPMS Warning
I have successfully removed all warnings about TPMS from my NAV - HU_CIC / RDC = nicht_aktiv (Thanks shawnsheridan!)
Now Im trying to remove the yellow warning light in the instrument cluster.
Anyone attempted this?
Old 10-05-2012, 07:48 PM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
Did you search KOMBI for RDC setting, and if that did not work, remove 2VB from VO and VO Code KOMBI, HU_CIC, and RDC?
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 10-06-2012, 05:09 AM
Ta da!
Kommentar=RDC Ueberwachung (Comment=RDC monitoring)
KOMBI / ST_TYR_TIMEOUT = nicht_aktiv
KOMBI /ST_TYR_ALIVE = nicht_aktiv
- BMWCCA #446923
- flick
Old 10-06-2012, 11:21 AM
Mein Auto: F10
I tried those 2 above and it didn't fix. I will try to remove 2VB from vo
Old 10-06-2012, 12:57 PM
Hmmm...that surprises me that those two did not kill it.
Ok. Try this one too:
KL_PREDRIVE_F10_RPA = nicht_aktiv
If unsuccessful, kill 2VB in your VO, and VO Code HU_CIC and KOMBI. RDC has no coding data, so there is nothing to VO Code there I don't think.
- BMWCCA #446923
- flick
Old 10-08-2012, 04:08 PM
Mein Auto: F10
Removed the 2VB and VO coded HU_CIC and KOMBI.
No luck. TPMS warning still present in NAV screen and instrument panel
Old 10-08-2012, 04:18 PM
That is almost impossible to believe. Are you sure after you removed 2VB from FA, that before you VO Coded HU_CIC and KOMBI, you loaded that FA (the modified one without 2VB) and activated it, and not the FA read from the car?
- BMWCCA #446923
- flick
Old 10-08-2012, 04:46 PM
Mein Auto: F10
So load the xml file with the 2VB option removed and VO code those 2 again?
Old 10-08-2012, 04:51 PM
Yes! That is why removed it. Now when you VO Code the ECU's, it won't enable 2VB like your regular FA that is stored in your car will (assuming you did not go so far as to write the modified FA to the car, and the FA in the car is original).
- BMWCCA #446923
- flick
Old 10-08-2012, 05:53 PM
Mein Auto: F10
Just to keep the thread alive I have confirmed with Sean what I did was correct. New FA and VO coded Kombi and HUCIC. Still not luck. Will keep researching
Old 11-20-2012, 04:17 PM
jaza45 jaza45 is offline
I'm in Miami B.
Send a message via AIM to jaza45 Send a message via Yahoo to jaza45
Mein Auto: E92 M3
when you remove the 2VB out of the VO, you still need to pulll the plug out of the RDC or remover the fuse, otherwise the car is still going to recognize the module and light is going to stay on.
Old 11-24-2012, 07:05 AM
Mein Auto: F10
Success! Did everything mentioned above but this time I removed fuse. No more tpms warnings, alerts in nav or instrument panel.
However, while coding the kombi it came up with a CEL out of the blue. It has been 3 days and its still there. I don't drive the car that much so I'm hoping it goes away on its own.
Old 11-24-2012, 07:15 AM
You can try this.
Assuming the fault condition no longer exists, to clear the fault code.
1) Launch C:\EDIABAS\Bin\TOOL32.EXE
2) Hit F3
3) Load C:\EDIABAS\Ecu\F01.PRG
4) In the "Select Job: F01" window, select FS_LOESCHEN_FUNKTIONAL
5) Hit F5
6) "Results" window should show "JOB_STATUS = OKAY"
Hopefully, Problem Solved.
Note: fs_lesen_funktional only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it.
- BMWCCA #446923
- flick
Old 11-25-2012, 03:45 PM
Mein Auto: F10
Shawn you the man! CEL is gone. To recap for people wanting to disable TPMS
Pull the fuse in the trunk for TPMS.
Remove 2VB option in VO
HU_CIC / RDC = nicht_aktiv (this removes TPMS options from NAV)
Old 11-25-2012, 03:59 PM
Glad I could help.
- BMWCCA #446923
- flick
Old 11-30-2012, 04:38 PM
Mein Auto: F10
It went away the first time i drove it after clearing it but it came back after that. Comes back after i clear it everytime. Might have to take it in
Old 11-30-2012, 05:21 PM
CEL Zombie! Do you know what the CEL Code and its meaning is?
Maybe undo all your coding, clear it with Tool32, and see if it stays off. At least you will know if it is coding related.
- BMWCCA #446923
- flick
Old 04-07-2013, 06:20 AM
nimuh nimuh is offline
Mein Auto: F10
hi guys, sorry to dig up this thread again but I could not manage to remove the RDC error message yet.
is it really necessary to remove the fuse to kill the error message? i dont even care about the yellow warning light much, i just want to remove the warning message from the idrive that pops up on every start.
I coded the 3 values as stated above, but I do not want to remove the fuse if not 100% necessary.
what does this mean: "Remove 2VB option in VO"? I have e-sys running and have coded a couple values before, but im not a coding expret. what is the VO?
Old 04-16-2013, 05:26 AM
Mein Auto: F10
update: well it wasnt too hard. I just had to remove the RDC fuse in the trunk. warning is gone forever thanks to everyone in this thread
