F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
KW V1 Coilovers question
I just ordered the V1's for my 2012 550i Msport.. I've got the adjustable suspension setting feature where I can adjust my ride firmness from Comfort+ to Sport+
Will I still be able to use this feature with the V1 coilovers installed or is the feature pretty much useless after I install?? |
That feature will no longer work after doing the KW's. You will also need to get the KW control box to eliminate the dash error that you will get after the install since the ecu will be looking for something that isn't there anymore.
Alan
Current - 2013 N55 535xi Msport SAT Retired - 2009 N54 335i Msport 6MT Retired - 2000 M52TU 323i ASA Supercharged 5MT More photos of my car here |
Thanks Alan.. what about standard lowering springs as opposed to coilovers?? Would I be able to utilize my vehicles factory adjustable suspension after installing springs?
Yes. I have the DDC option on my car and ACS lowering springs. You still retain all adjustable settings if you only get springs.
I have ACS lowering springs on my 550ix sport and it is, in my opinion, the best option you can put on the car. I also have Dinan 2. Although I love the extra power, lowering that car is needed more than anything else. I NEVER liked the way the car looked with those big gaps between the tires and the wheel wells. The car just "feels" better.
When I had an occasion to take the car in for a problem a while back, they had to do new coding, which wiped out the Dinan download. I had to drive the car for a couple weeks with the stock power, waiting for Dinan to update its software. With that experience I was able to determine that the lowering springs, without the Dinan, made for a better driving experience than having the Dinan 2 before I lowered it. Bottom line....put on ACS springs and lower the darn thing. Every time you walk out to the car and see it sitting down where it belongs, you'll be glad you did. |
Okay.. I was fortunate enough to be able to cancel my order of the V1's.. I will consider installing springs instead. I've done some research though and it seems like installing these springs is a pain in the ass for body shops so I'm kind of left with the concern of a proper install.. But I will still consider it..
thanks guys |
After installing lowering springs, is a suspension re-alignment necessary?
| Tags |
| kw v1 |
