E30 (1982 - 1993)
Old 11-30-2012, 05:06 PM
HicksLJames HicksLJames is offline
Mein Auto: 89 325i
89 E30 with M20 intermittent misfire
Hey everyone my car is been having some problems lately... Mostly when Im crusing on the freeway or under high load the car misses one cylinder. I pulled the car around and started to do some diagnostics. I started at the Ign Coil and ohmed the primary and secondary circuits .53 and 6100 ohms which is normal. I pulled the spark plugs (E3's which could be the problem IMO) wires (almost 0 ohms on all which is normal), and the rotor (cleaned the posts up). I put it all back together and test drove it. The problem was still there but not as apparent... The problem feels like a ign cut because its so sudden and not just a loss off power like a fuel cut problem. Im going to buy some NGK-R's on Monday to see if its those ****ty plugs but other than that Im at my wits end and would appreciate and input or help. Thanks!!!
Old 11-30-2012, 06:33 PM
downhiller's Avatar
livin large
e3 plugs a problem? you will be the first i hear that from. have you checked the crank sensor yet?
Old 11-30-2012, 06:50 PM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
M20's like old school copper core plugs...
Old 11-30-2012, 06:54 PM
WickedFast.Inc WickedFast.Inc is offline
Go Fast or Go Home
Mein Auto: 1989 325I
Check for spark at each plug +1 on crank sensor check fuel pressures fuel pressure reg
Wicked Fast Entertainment
Old 12-01-2012, 06:03 AM
BMWFatherFigure's Avatar
Old School
If it only misses one cylinder do a compression and leak down test. Is a plug lead shorting out?
Current:
E38 Parts Car
Previous:
Old 12-01-2012, 10:54 AM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
please don't buy ngk's.. you will notice things will get worse.
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
Old 12-01-2012, 05:14 PM
downhiller's Avatar
livin large
i dont see any logic in that statement. the only 2 plugs i ran where the u-power ngk and u-groove denso. those are by far 2 of the best companies for spark plugs.
Old 12-01-2012, 05:34 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
spark plug leads should be about 5kOhms, not 0 ohms. Im going to call you out and say you havent tested those.
E30 above Sold
Last updated 2nd January 2014
Old 12-02-2012, 01:04 PM
downhiller's Avatar
livin large
maybe he ran continuity instead of ohms.
Old 12-03-2012, 01:04 AM
Mein Auto: 89 325i
Hey Guys! So I tossed those sad excuses of spark plugs and put is some NGK-R's and test drove it. MUCH better but problem still apparent. after a second of pondering I had a theory. I bought the car used and I am damn sure that the previous owner did have the gall to bite the bullet and buy some damn spark plug wires... so I pulled the loom off the valve cover and cracked that sucker open.. ALAS!!!!! carbon tracks from the old plug wires crossfiring under heavy loads! so I manned up and just dropped the hundred for the wires and installed them. Test drove the car and now its running like a champ! now I gotta tackle the oil in on the filter and in the intake boot, intake manifold and such but thats not on the top of my list. Im thinking CCV and I plan on replacing the hose after I get paid tomorrow. And also I have a 1222 DTC for the O2 sensor. and I understand that the O2 sensor just measures oxygen and something can cause the Rich/Lean code to appear I just want a second opinion on wether it would be a good idea to start at the O2 and just get it outta the way so if its something else I can move on. Or maybe a wideband...... hmmmmmmmm and advice would be much appreciated -M POWER-
Old 12-03-2012, 10:09 AM
Mein Auto: 89 325i
And whatever specification that I got for the spark plug wires was off of AllData. hmmm maybe they made a mistake
Old 12-03-2012, 06:50 PM
downhiller's Avatar
livin large
This wire typically has a resistance of 3,000 to 20,000 ohms /ft. depending on the manufacturer.
http://www.auroraelectronics.com/Und...ug%20Wires.htm
also, you cant blame the spark plugs when the wires were shot. grant it e3s may not be the best choice for the e30s, but they still out perform alot of spark plugs. its a proven fact but many second hand testing companies.
Old 12-03-2012, 09:35 PM
Sorry, just reread that, i sound like a bit of a **** there, i didnt mean to!
You should be able to read the resistance on the side of the lead if they are genuine/oem leads in there currently.
I think i missed something, i tried reading above again but alas no, what do you want us to diagnose?
E30 above Sold
Old 12-04-2012, 03:16 PM
Mein Auto: 89 325i
well the new plugs and wires helped alot. the inly reson I got the E3s was becuase they didnt have NGK plugs at the time so I got them pretty cheap they just dont work for me I guess. My E30 does have a pretty terrible idle and it throws that 1222 code whenever it is idling at a stop. after I take off the weak idle goes away and the car runs like a champ. I have heard of pulling off my Idle Control Valve and giving it a good cleaning. I also have oil being pulled into my intake. theres oil on my air filter and all up in my throttle body and everywhere. First thuing that comes to mind is PCV but I just wanted to get some second opinions on what it could be. Im not trying to shotgun parts into the thing....
Old 12-04-2012, 05:13 PM
downhiller's Avatar
livin large
oil in the intake, too much bypass gases. which on these cars tends to lead to bad rings. and if i remember correctly, these do not have a pcv. there is a tube that goes from the underside of the intake to just above the oil pan.
Old 12-10-2012, 01:31 PM
Mein Auto: 89 325i
Eureka! Crank Sensor CAKED with gunk. Cleaned it up put it back. No more misfire, O2 code, and it idles like its supposed to now =D
Old 12-10-2012, 05:05 PM
Go Fast or Go Home
+10 for another solved
drivability problem, ignition problem, misfire on cyl, misfiring, stutter
