Old 11-20-2012, 06:43 PM
butlerbp butlerbp is offline
Mein Auto: 325i sedan 2001
Question Right rear tail light malfunction
Hi, my right rear tail light is not working. I get the dash message "check brake lights". I swapped the bulbs with the left side and all bulbs work. I took 12v dc across the connector pins on the lamp, and all bulbs work. The running lamp works fine as it normally would. The high mounted stop lamp doesn't work (bulb is working fine). Any suggestions?
Old 11-20-2012, 06:49 PM
deccody deccody is offline
Mein Auto: 04 BMW 330i
What year and model. On my 04 330i the light was on I took it to BMW to have the oil changed the guy there said there was a recall on the lights something about not being grounded right. Maybe that's your problem they did it for free so .
Sent from my Galaxy Nexus using Bimmer App
Old 11-20-2012, 08:42 PM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
Did you check the connector for corrosion?
Steve
OSRAM CBI
BMWCCA Member #337964
Old 11-21-2012, 04:17 PM
Yes. I checked for corrosion on the connector, and it really clean. Not a hint of corrosion.
Old 11-21-2012, 04:20 PM
Sorry for not being specific on the model. It's a 2003, 530i, manual transmission. The ground looks good. I checked the connector wire ground with the body ground and got very low resistance. I think that's good.
Old 11-21-2012, 04:56 PM
So the brake light, turn indicator, backup light and LED tail light all do not work?
Steve
OSRAM CBI
Old 11-22-2012, 08:03 AM
Jim Rolando Jim Rolando is offline
Mein Auto: 1999 528i
I'm guessing that you need to replace the socket for the third brake light in the back window. It goes bad cause these symptoms and drives owners crazy until they replace it.
Old 11-22-2012, 10:18 AM
Correct. Also, the yellow flashing light that goes on when I lock the doors. It might be the emergency flashers, too. The only light that works is the running lamp. Also, the high mounted stop lamp doesnt' work.
Old 11-22-2012, 10:20 AM
Correct. The only lamp that works is the running lamp on the right side. The blinker, backup light, LEDs, and the yellow flasher that is used when I lock the doors (it might be the emergency flasher lamp, too, but I'm not sure). Also, the high mounted stop lamp doesn't work.
Old 11-22-2012, 10:22 AM
Hi. The high mounted stop lamp socket looks very good, too. No corrosion, no damage.
Old 11-24-2012, 08:47 AM
What do you guys think about this response that I found on: http://forums.bimmerforums.com/forum....php?t=1352393 ?
Just for information purposes...all external lights are controlled by the LCM (light control module)...there isn't a "fuse" that controls them...this can be verified by looking at the fuse index card in the glovebox and on the back of the battery compartment fold down door. (no fuses for external lights...take a look see)
Can you reveal what made you remove the tail light in the first place? For those of us out here on the internet...it's as if a big piece of the puzzle is missing. Most people wouldn't remove an entire rear light assembly just to remove it (but I guess it's possible) ...could it be something else that is causing the problem?
Old 11-24-2012, 09:56 AM
Sorry, bad linkes to the images. Here they are. They're up on Photobucket.
http://i1356.photobucket.com/albums/...01995-1998.jpg
http://i1356.photobucket.com/albums/...t20Info201.jpg
http://i1356.photobucket.com/albums/...t20Info202.jpg
Old 12-01-2012, 12:30 PM
OK, here are more symptoms:
--left front flasher doesn't work
--left front halow lights don't work
--left front LED doesn't work
--Left front high beam doesn't work
--left front flasher bulb works fine (I switched them from lt to rt)
--back up lights don't work
All other symptoms remain:
--high mounted stop lamp doesn't work
--right rear flasher doesn't work
--right rear stop lamp doesn't work
--right rear running lamps are ok
--right rear LED are ok
UGH!
tail lamp failure
