X5 E53 (1999 - 2006)
The X5 SAV Forum |
Nav screen scrambled/fuzzy?? Help??
Hi Guys, my 05 x5 nav screen recently started going nuts, looks all scrambled, like an old tv. This is the 16;9 screen. before this happened the screen was loosing some color but would come back from time to time. The screen did come back completely yesterday but today its all scrambled again. Can I swap the screen or is the unit in the back bad?? Please help!!!!!
99 540i sport, acs type 2's chrome, acs spler pdls,Euroclrs 04 745i aw sport,21's aib's acspedals& rf splr(sold) 00 328i Prem Aw18" 335spt whls(sold) 02 Corvette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav 05 X5 3.0, pana rf,nav,xenon,cldweather, premium.ipod hookup, 20"4.6rims staggered 315rrs. 06 750I aw, sport. chrome21's,acs pdls,acs rfsplr,mtecs,8k hid fogs,Leds.oem ipod&sirius 03 VIPER, forgelinewheels,tune,exhaust,intake. |
Jeez the x forum is terrible, not even 1 person.
Looks like it may be the actual nav unit in the back, ordered another one will keep the thread updated for future people if this resolves the problem.
I got a used Navi screen MKIII for selling, very neat, all light & button work perfectly. Removed from my car & replaced with a Hualingan screen.
I searched quite BIT WITH NOTHING, I did come across the screen issue but im almost positive Its the unit in the back. I ordered one that hopefully will be here today. This morning i started the truck and everything is perfect again?? Im going to swap the mk4 and see if thats the problem. If anyones int in a used dvd mk4 thats not 100% working pm me. I'll update as I fix this.
Got another unit and that fixed the problem, nav is back to new. what weird is the old one sometimes is perfect maybe its an easy fix, I will be selling it if anyone is interested.
Hi,how did you fixed it? How much cost you?
Thanks |
NAV screen issues
On my 2003 X5 the screen has what looks like a burnt spot about a 1/2 inch wide right in
the middle of the screen...I am not selling the car anytime soon so am looking into just replacing the dash part of the unit...Love the car otherwise. |
I installed a new mk4 dvd drive unit in the rear. That fixed the prob.
How much cost you mate?
about 450 for a used like new mk4 off ebay.
If anyone wants to take a shot at fixing my other one pm me an offer.
well the screen got scrambled again, so i guess i have an extra mk4. Maybe its a loose connection to the screen, will take the screen out and check connections before installing anewer one. wish me luck.I will keep this updated for a fix.
As I recall the screen has the video drivers in it.... I had a video issue on my E39- wound up replacing the screen (warranty). Red drivers died, so screen showed distored images.
Keep it as simple as possible...but no simpler. |
Just saw this post. The scrambled screen issue is due to a dirty ribbon cable connection. That is all it is. I first had the issue where I would loose the color blue. The ribbon cable from the screen to the nav unit has no connector on it, just bare conductors on the end. The ribbon cable plugs into a receiver/connector in the Nav unit that clamps down on it. I pulled this cable out and cleaned the contacts. That solved the problem for a couple of years and then one day I had a scrambled screen. I was able to just tug lightly on the cable behind the screen and fix the issue, but I need to take the unit out and clean the contacts again. Use Deoxit contact cleaner. You can buy it at Radio Shack. It is also popular amongst us audiophiles for cleaning our audio cable contacts. Very good stuff. So the problem is not your screen, just a corroded connection.
2007 3.0si w/Sport Pkg, Navi, Leather, Strut brace, garage door opener and delete airbag warnings on sun visors |
Not the screen, the connector in the Nav unit that the ribbon cable is plugged into. It requires that you remove the Nav unit from the dash, and then the ribbon cable can be seen coming from the screen and going into the top of the Nav unit. You simply open the connector clamp and remove the cable, clean the connector contacts and the conductors on the end of the ribbon cable and reinsert into the connector. Close the clamp and all should be good then. You do not need to remove the screen at all. Use Deoxit which also comes with a preservative. That should help keep a good connection for a long time.
do I need to open the radio up to access the ribon or is it just plugged in and easy access??
It is right on top as I recall. You might have to take the top cover off of the unit. When I pulled mine, I started to take the screen out and then I stumbled upon the ribbon cable and remembered a post from someone else talking about that chinzey connection method. I was working to pull my screen out and order a replacement because I had lost the color blue. But when I thought about that posting I tried cleaning those contacts reassembled it and plugged it back into the car. Everything was good after that until about two months ago. Now I get a scrambled screen once in a while, but like I said, I can open the panel like I'm going to put in a cassete tape, give a light tug on the ribbon and the screen works fine again. So I need to pull mine out again and clean the contacts. It has been about two or three years since I had to clean them the first time. I don't think I had Deoxit on me at the time either. This time I have some Deoxit cleaner and preservative. I expect that to keep the contacts good for hopefully an indefinate time period. If you search these threads some more you might find a picture. I could post a picture the next time I pull mine out, but unless it goes out and stays out, I have too many other alligators to fight off right now. Plus, if the sun is shining, I'm cruisin' in the Z4.
Thanks Tony will give it a go.
well I cleaned the contacts and now i just get a white screen??
You didn't get the connectors in the back of the in dash unit fully engaged. They can be difficult. Unplug and reinsert them. Be sure the latches are completely locked down.
http://www.xdrivers.co.uk/forum/index.php?&topic=2273.0
The above link was a useful tool for the nav screen repair. It was successful for me. |
anyone have any ideas about a nav screen having the back light flicker on and off ?
well I got a resonable used one and swapped it in works perfect now. I didnt bother trying to reconnect the cables. i prob should.
#25
Excellent post... I have an 06' 750Li with the same exact problem. I assumed it was a loose cable somewhere as it works on and off again. More annoying than an actual problem but its frustrating when you need a working NAV. Was going to save up to have dealer fix this but it sounds like I can save a boat load of money if I clean the ribbon connections myself. Are there any E65/E66 owners that have fixed this issue?
![]() 2006 BMW 750Li - Black on Black 2001 BMW X5 - Black on Black 1997 BMW 328iC - Black on Tan |
