BMW Coding and Programming
Discuss coding options and features on your BMW here. |
RE-coding no-dazzle high-beam assistance?
On the US market, when you order 5AC Automatic high beams, you also get the following:
5AP Decoding for no-dazzle high-beam assistance From what I understand, this is to DISABLE the no-dazzle high beam assistance feature, described as: "Included in the equipment package for the first time is an anti-dazzle High-Beam Assistant, which allows high beam to remain engaged even when there is oncoming traffic. A cover applied across the headlights as and when required eliminates the danger of dazzling approaching vehicles." So, any ideas on how to enable this via coding? In FEM_BODY, under LaMaster1, I see a couple of related entries. However, when I changed the binary values (werte) and code, it didn't work (but the car showed error messages regarding blind spot and adaptive headlights). Any of these entries make sense? I assumed C_HBA_ENA does not apply to the F30, but C_HBA_GRHB_ENA and/or C_HBA_ADAPT_SHUT_ENA should do the trick. I later noticed that it had reverted to the original settings. The car even forgot my previous changes (windows up, folding mirrors with keyfob, etc.). I don't know whether this is related to an out of memory error e-sys gave a couple of times (restarted e-sys every time). I tried the whole thing again to no avail. Last edited by ahmadr; 11-27-2012 at 10:17 AM. |
Unfortunately US cars do not have this feature. You could potentially retrofit it if you brought over ECE headlamps, but I'm not aware of it being compatible (yet) with the US DOT headlamp beam pattern.
Essentially the car "tracks" an oncoming light source and uses a built-in shutter in the headlamp housing to adjust the light output and "dip" the lights. Your highbeams remain ON, but the pattern changes to not dazzle oncoming traffic. Here's a video from Bimmerpost:
![]() 2013 ///M5 Alpine White · Sakhir Orange Full Merino Executive · Driver Assistance · B&O · 20" HRE P40SC · Akrapovic Evolution · H&R Springs · Many Euro Mods |
Are you sure? The BMW system is very simple compared to Mercedes / VAG, just changing the height of the cutoff, afaik. In other words, all it needs is the high/low beam shutter mechanism to be variable instead of on/off.
I'd be surprised if they have two separate housing designs when it is so simple. You are right on the DOT issue though. From what I heard, BMW didn't go through DOT compliance, and simply disabled the feature altogether for the US market. Last edited by ahmadr; 11-27-2012 at 01:15 PM. |
I have run ECE headlights on all my cars. While you'd think the housing would be the same more often than not it isn't. It's been this way with Audi, VW, BMW, etc.
There's always some difference.
So just FYI... European F30:
For vehicles with Xenon Light S522A=Yes Adaptive Headlights S524A=Yes Bi-xenon headlight AKL, left 63117338701 Bi-xenon headlight AKL, right 63117338702 For vehicles with Xenon Light S522A=Yes Adaptive Headlights S524A=No Bi-xenon headlight, left 63117314531 Bi-xenon headlight, right 63117314532 Different part numbers.
Point taken. Thanks.
The reason I still feel there is a chance it's a coding only issue is the "5AP Decoding for no-dazzle high-beam assistance" option in the car build. If it was a hardware issue, why add that to the list of options on the car? We don't get, for example, "bumper reflectors", "rear red turn signal", and "rear fog light delete" in the option list
I did find part numbers (apparently for the US market) for both bi-xenon and bi-xenon adaptive lights. So perhaps it's coming? I don't know.
BMW option codes are interesting. There are "top level" option codes that automatically assign components during build. Some option codes are not used, deprecated, or reserved. (5AP in the US market might be one of those - the M6 Coupe/Convertible have this code, as does the F01 LCI.) So while the option exists, there's another companion option code required. (On my car, 522 is Xenon headlamps. You'd need 523 or something, but 523 isn't valid for your model code - see below.) But as for the market-specific items, this is all contained within the model code. For example, my car is FV93. But in EU it's FV91. FV93 automatically adds the appropriate components for NA cars during build, like reflectors, etc.
Oh - btw - if you can, post the part numbers for your headlights (if it's accessible). I can tell you immediately whether it's coding or not.
Left: 63.11-7 259 553 Right: 63.11-7 259 554 Thanks Last edited by ahmadr; 11-30-2012 at 11:37 AM. |
I'm trying to find the bundle those part numbers are part of. I'll get back to you.
Today I played around (again) with the HBA settings under 3073 LaMaster1 and the HBA speed settings under 3074 LaMaster2 of FEM_BODY.
I can confirm, without any doubt, that with the current settings I have, under auto high beam mode, the car sometimes uses something in between the high and low beam settings. The high beam indicator remains on when in the medium-beam setting(s?). Yes, this is what the No-Dazzle High Beam Assist is supposed to be. And no, I don't know how many steps / zones does the system have between full high and full low beam. Unfortunately however, I am pretty sure that the car is sometimes using a too aggressive beam, making the whole system unsafe to use. I'm not sure whether this is due to the speed settings I changed, other settings that need to be changed, or hardware limitations of the US model (e.g. camera, camera calibration, headlight hardware). P.S. My original goal for changing the speed settings was to reduce the minimum speed for the auto high beam to function. Anyone with a European model care to share their HBA settings, please? Last edited by ahmadr; 12-02-2012 at 12:05 AM. |
Can someone tell me what VO is needed for high beam assist in the F10, is this just coding, or you need hardware ?. Thanks.
It is hardware too. You need the KAFAS camera which can support HBA, LDW, and SLI, and I think now their exists a new HBA only camera on some models.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
