#26
Thanks to a pointer by JimLev, I belatedly realized Bentley, Volume Two, pages 610-29 to 610-37 shows the 88 fuse spots (F1-F5, F1-F114 inclusive) in the 6 fuse locations listed below (spots F67 to F74 & F77 to F99 don't exist & F1 to F5 exist in two different locations):
For the record, this thread today points out why, when you install an electric fan, that you need to consider finding a BIG fuse to connect it to:
- E39 (1997 - 2003) > Power fuse issue In particular, this thread shows a nice routing of wires when you need to ADD big fuses for an electric fan: - Mechanical Fan Exploded! Is another one Justified? Last edited by bluebee; 11-20-2011 at 11:39 PM. |
#28
For the cross-linked record, today cn90 put a nice closeup picture of the airbox fuses in this thread:
- E39 (1997 - 2003) > Immediate need! Quote:
#29
For the record, while researching this thread just now:
- Do we have a good description of how the BMW E39 Secondary Air System (SAS/SAP) works ... I ran into this excellent cn90 thread showing some of the best pictures ever of the under-seat fusebox in the 528i: - DIY: Troubleshooting S.A.S. and How to Replace the Famous Fuse # 107! Here are some of cn90's excellent fuse-related pictures from that thread: Quote:
#30
Here is a link to BMW's
1 dealer service manual - TIS and 2 wiring diagrams - WDS http://spaghetticoder.org/ And I noticed one of the other posts gave you a link to the owner's manual. EDIT: and you have now seen there is LOTS of help here in this forum. EDIT2: the Bentley manual can be useful too. But for wiring, I recommend WDS every time. Bentley often omitts circuit diagram changes that evolved over the E39 platform lifecycle. Good luck
Regards RDL Last edited by rdl; 12-22-2011 at 09:01 AM. |
#31
So that folks can find fuses and the WDS easily, this is in the bestlinks:
- Where to find E39 fuse boxes (1) (2) (WDS) (WDS.ru) & how to find the front passenger seat undercarpet fuse panel (1) Also, today there was a related thread looking for fuses over here: > E39 (1997 - 2003) > 528i fuse diagram
#32
This information posted today on another thread may be useful:
#33
For the record, JimLev kindly posted a DME fuse picture in this thread just now:
#34
For the record, I reorganized the fuses for the E39 over here while debugging parasitic drain:
> E39 (1997 - 2003) > In progress: Step by step diagnostic DIY ... dead battery ... parasitic battery drain For the record, DME ground wires and other ground wires are covered here: > E39 (1997 - 2003) > Tighten your ground wire today Great pictures of the underseat and glovebox fusebox wires are in these threads: > E39 Electric Memory Seat Install Guide 'How to' PIC HEAVY > DIY Retrofit Rear Electric Blind > How to: OEM Front heated seat retrofit > The fun I had fitting electric comfort seats
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 02-05-2013 at 08:42 AM. |
