Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Tire Rack's Tires, Wheels, Brakes & Suspension
Discuss everything about wheels, tires, suspension and brakes for your BMW.
Sponsored by The Tirerack. Moderated by Rudy@Tirerack.com
Old 11-30-2012, 07:41 AM
addfellow addfellow is offline
Mein Auto: 2013 xDrive28i
Need help identifying rims
Looking to sell set of 4 rims. Would like to provide buyer accurate identification info. Thanks!
ID:	351441   Click image for larger version
ID:	351442   Click image for larger version
Old 11-30-2012, 08:36 AM
vavet5308 vavet5308 is offline
NADAVAN
Mein Auto: 2002 525it
I think these are E36M3 wheels. The information that a potential buyer is going to want is the size (picture 2: 7x16) and the offset (also picture 2 ET:{illegible}).
There should also be a 7 digit BMW part number on the wheel somewhere, probably on the back of one of the spokes. If you put that number into realoem, it will probably tell you which model car this wheel came on originally.
Other relevant information :
documentation of any flaws (bends, scratches, peeling clearcoat on the finish, cracks, curbrash, etc)
how many you're trying to sell, package deal, individual, etc
if tires are included, if so :
-what brand & model,
- size,
-approx mileage and age,
-tread depth, providing tread depth at different points across the tread is preferable so any uneven wear can be detected
and of course your desired price
location of the wheels
willingness to ship, and how you intend to package if you are, cost to ship
Old 11-30-2012, 08:44 PM
LMC's Avatar
LMC LMC is offline
Mein Auto: M3 & X3
There will not be a BMW part number on the wheel, as these are aftermarket copies of the BMW M-Contour wheel that was fitted to E36 M3 in 17-inch sizes. There were a number of different manfuacturers of these knock-offs, if memory serves. I bought a set in 17 inches from Tire Rack in 2001 or so along with some winter tires.
The offset looks to me like ET38.
These should fit many E36 and E46 3 series cars from 1992 to 2005. Since they're 16s, they may not fit 330s, which have larger front brakes. They're too small for M3s as well. The correct tire size on these would be 205/55R-16 or 225/50R-16 for a 3 series. They might also be compatible with an E83 X3, although with larger tires.
Larry
BMW CCA #115780
'14 X3 35i M sport
'17 M3
Old 11-30-2012, 09:21 PM
NADAVAN
I will defer to you, but for my own edification I would like to know how you can tell that from the pics.
Old 12-01-2012, 11:20 AM
LMC's Avatar
LMC LMC is offline
Mein Auto: M3 & X3
I can tell they are not original equipment simply from the size... BMW never offered the M-Contour in 16-inch diameter; Only in 17-inch.
Larry
BMW CCA #115780
'14 X3 35i M sport
'17 M3
Old 12-02-2012, 09:54 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
if memory serves me correctly, these were the only 16s that could clear the front brakes on the e46 330i. i remember looking at these on TR in 2001 when looking for winter tires/rims.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
