My 540i/6 wont rev! - Bimmerfest - BMW Forums
Old 12-02-2012, 11:49 AM
Kapten_sjovild Kapten_sjovild is offline
Mein Auto: 540i/6
My 540i/6 wont rev!
Hello!
The problems continue with my 540i/6... All of a sudden he refuses to rev higher than 800-1200 rpm, no matter how far u press the pedal... Otherwise there are no other symptoms, except perhaps that I think it is ticking a little from this section:
http://imageshack.us/photo/my-images/832/bmwm62b44.jpg/
Any suggestions??
with best regards Adam
Old 12-02-2012, 01:13 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Okay, report the stored codes. We are not clairvioant.
I believe that device is the purge valve for the vapor recovery system, and I think it buzzes periodically. Mine doesn't have one like that.
Old 12-02-2012, 05:14 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Yes, that is a purge valve for the charcoal canister that is above the left rear wheel liner.
It has nothing to do with why your engine won't rev.
Have you checked the ACS throttle body that is just past the MAF to see if it is fully open?
2000 540/6 Slightly tweeked...everywhere
Old 12-03-2012, 03:13 AM
Mein Auto: 1999 740i
What year is the 540? If its 99 or later its drive by wire and most likly the gas pedal part or the TB.
Old 12-03-2012, 05:13 AM
Looking at the link he posted its not drive by wire, looks like a 98 to me.
Old 12-03-2012, 05:41 AM
Ahhhh. Sorry. I didnt notice the link.
Old 12-03-2012, 11:51 AM
Mein Auto: 540i/6
I dont have any codes at the moment. Alright then i exclude that it may cause a problem!
The translate of "charcoal canister" doesent give any results for me. Is it possible to explain what it is or some other name? vapor recovery system?
I havenīt checked the ACS yet, ill do it tomorrow and report results!
It is an 1997.04
Old 12-03-2012, 11:59 AM
The vapors are stored in the charcoal canister that is above the left rear wheel. The purge valve sucks the vapors out of this tank.
Back to the rev problem.
What happens if you operate the throttle linkage under the hood by hand? Have you tried that?
Also look at the traction control throttle body butterfly, it should be wide open.
Old 12-03-2012, 12:37 PM
Mein Auto: 540i/6
Ok!
Yep, it is the same as when pressing the pedal, so i guess that the problem isnt anywere between there.
You mean this part? http://imageshack.us/photo/my-images/28/bmwm62b44.jpg/
I havent checked that yet, i guess that is the second thing after unplug MAF sensor to do?
Old 12-03-2012, 01:07 PM
Mein Auto: 540i/6
Ok!
(wops i pressed send again, im sorry, can i delete this post?)
Old 12-03-2012, 08:14 PM
Yes, that part you just circled is the secondary throttle plate that is controlled by the ASC.
Will it rev to higher RPM's in neutral?
Old 12-08-2012, 05:11 AM
Mein Auto: 540i/6
loosened MAF sensor and sat back, and opened and operated the second throttle plate manually, now she runs like usually
