E36 (1991 - 1999)
Old 03-22-2012, 03:15 PM
stone128 stone128 is offline
Mein Auto: 2005 330ci ZHP
Occam's razor for sure. Changed to summer tires today and no noise!
Old 04-06-2012, 07:18 AM
JayMac JayMac is offline
Mein Auto: what ever starts
I have posted some shot on another thread of the axles I purchased from Rock Auto from Cardone. $55 plus shipping and limited life time warranty. That's less than an hour of labor at most shops. Just a FYI for you consideration if you have joints going bad. I am putting mine in this weekend.
http://www.bimmerfest.com/forums/sho...21#post6748921
Old 04-26-2012, 02:37 AM
darylismail darylismail is offline
Mein Auto: e36 M325i
Hi Guys. I am new to the site and have recently purchased an e36 328i. Just recently it developed a clicking sound , from the drivetrain, while pulling away (especially when cold). I have visited the resident mechanic and he suggested it could be the centre bearing. Has anyone experienced this problem, and found the cure???
Old 04-26-2012, 09:40 AM
clicking would lead me to think cv joint on shafts. You can jack the car up and put it in gear, have some one else out side listen. Start simple think it through, keep us posted.
Old 04-30-2012, 04:13 PM
lytte lytte is offline
Mein Auto: 1992 e36
Theres a rubble coming from the rear passenger side when I pull off in first gear this rumble rattling sound happens whether I pull off fast or very slow the faster I pull off the louder the rumble or knocking is but this only happens in first gear every other gear is good does anyone have a.idea what this knocking noise can be.....
Old 05-01-2012, 07:24 AM
Are you diagnosing that while you are in the car? If so it might not be from that location. It is very hard to tell while driving with the windows down and listening. If it goes away as you accelerate i would look to the tires first. Balanced? uneven wear or just normal noise. If it is mechanical in most cases speed will not make it go away. It could be a bearing or cv. Jack up that corner and check the wheel for play. Put your hands at the 3 and nine position on the tire and check for movement. DO the same at the 12 and 6 location. If you have play in the wheel it should be the bearing. Start simple first. Check you pressure wear on tread bearing and look for any grease inboard or at the hub and get back to us. Also you might want to actually read some of this thread to see what other have dealt with and what it eventually was.
Good luck and patience.
Old 05-02-2012, 07:10 PM
Poorboysracing's Avatar
Poorboysracing Poorboysracing is offline
I <3 Underpowered BMW's
Send a message via AIM to Poorboysracing
Mein Auto: '00 BMW 528i '68 BMW 1600
If it soudns like a un godly whine at high speeds / grinding at low speeds, then My best bet is the diff, havent fully confirmed that yet but im 99% sure lol.
Also gets worse with accel and deccel (different noises)
le sigh poor lola
how does a 318 ruin a diff
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
Old 05-02-2012, 07:28 PM
cj.surr's Avatar
cj.surr cj.surr is online now
some kid
Mein Auto: 1995 318is
Yeah, definitely sounds like the diff. At least they're cheap and easy to replace.
-CJ
Old 05-02-2012, 11:01 PM
Mein Auto: 1992 e36
Thanks for all the advise guys......... If this helps I did recently change 1 rear tire but I didnt hear this knocckin noise untill about two Weeks after I put on the new tire I did a small burn out and thats when the knockin noise started it feels like the car is doing a burn out but its not the rattle only happens in first gear from 1500- 2500 rpms its smooth over rough roads and only rumbles n acceletation AZ
Old 05-07-2012, 11:34 PM
kyle2blue's Avatar
kyle2blue kyle2blue is offline
Mein Auto: 94' 325is
great thread
Old 05-09-2012, 06:36 AM
Mein Auto: 1992 e36
Hey sorry for the wait, but thank for all the advise it was all very helpful..... The knocking noise was coming from a combination of problems 1) a loose brake hose thats was knocking agaist the body
2) to much air in tires
3) top strurt mount was bad
I fixed all these problems myself but theres still a small ruff rattle knockin noise redused and doesnt last that long guess it tom fore me to take my baby to the shop........ Smh but no shop want to work on my car they its to low......haha
But this is a great website
Old 06-13-2012, 03:59 PM
Flotsam's Avatar
Flotsam Flotsam is offline
New to this board
Mein Auto: 1995 BMW 325i
some of those sounds apply to other cars as well! thanks
Old 07-22-2012, 04:39 AM
Sundancer Sundancer is offline
Mein Auto: 1997 328is
started this morning
On my way to work, got progressively worse...a wub wub wub sound from the rear, you can feel it in the seat of your pants, no sound or vibration whatsover when under accceleration, but as soon as you let off it starts, I only went to 80 km/hr, it's much worse and more solid sounding at higher speeds...driveshaft bearing? flex disc?
Old 07-23-2012, 11:55 AM
In a matter of miles, it has progressed to fulll blown helicopter...I mean Huey coming in over the water like in Apocalypse Now helicopter noise...I'll go back to the top...
Old 08-30-2012, 06:35 PM
Sunsetter Sunsetter is offline
Mein Auto: 2001 330i, 2006 MX-5
Tails of whoa
Wow! this is why I keep the stereo cranked!
Old 08-30-2012, 11:30 PM
Eight Thirty Eight Thirty is offline
nothing.
Mein Auto: ItAintUrShtYUCare?
jack up your car and make sure ALL your wheel bolts are tight.
im guessing they arent
dont just drown out the sounds with the radio..... /sigh
nothing.
Old 09-14-2012, 11:01 AM
sierra117 sierra117 is offline
Mein Auto: '93 325is a.k.a. jenn
SAME THING happened to me it sounded terrible and i could feel it in between the seats!!! i fixed the frame work but still get a knocking do you know if its the drivetrain torqueing itself into the underbody or how i can prevent the the knocking???
Old 09-21-2012, 09:34 AM
325rob 325rob is offline
Mein Auto: 325is
My 94 with 224k makes a squeak over bumps. The noise is comming from the left rear and sounds like bouncing on an old matresss. I need a "if the bimmers a rockin sticker". The prior owner said its been doing it a while. I had just put a rsm and sway bar link on that side so I dropped the shock but it still makes noise. I put a scope on all the bushings and couldn't hear anything. Could it be a worn out spring? I sprayed silicone lube on the spring pads but that didn't help. Any ideas?
Old 11-09-2012, 11:20 PM
96'328i 96'328i is offline
Mein Auto: 328i
Hi all, I am experiencing a noise from the rear as i drive over a speed bump the car will go up and down as normally would driving over the bump but after the rear tires goes over and the car is bouncing up i hear a thump. I just changed the rear springs because the ones that were on broke at the top of the coil, could it be the shocks? and if so should the springs and shocks be changed a the same time? The noise only thumps once but after the rear is being pushed back up from coming out of a bump. Thanks in advance
Old 11-10-2012, 05:00 AM
veteran011's Avatar
veteran011 veteran011 is offline
WARNING: Has Dumb Ideas
Mein Auto: 97 328is
96 328i I'm gonna suggest taking a look at your rear trailing arm bushings (aka RTABS). My car made a knocking noise over bumps until I replaced those. Now she's golden.
dab of oppo anyone?
Project List:
Replace coolant temp sensor
Replace starter
Brake and Power Steering Fluid Flush
Front Control Arms, Bushings, and Tie Rods
Replace Passenger Lock Actuator
Reglue Peeling Hedliner
Swirl removal
Old 11-10-2012, 06:58 AM
You only have a few options here so work through each one. As suggested it could be RTAB. Are the shocks securely fastened. Are you running out of travel. Spring rate could be different and as such bottoming out. If the noise is coming when the car is actually going up the shock would be extending. How old are they. When was the last time the RTAB were replaced? Do you access to more than one suitable jack? If so lift rear and then jack on that side trailing arm and look for something out of normal.
Keep in mind that you might not have enough strength or force to cause the sound. Work slow and think it through. Safety first and keep us posted.
Old 11-10-2012, 10:12 PM
Mein Auto: 328i
Thanks!
@Veteran011 & @JayMan this next week Friday I'm doing the head and intake manifold gaskets because i found a small amount of oil in spark plug bay #1 but the following week i will do a check list type inspection of the rear end and keep you guys posted thanks for the help much appreciated!
Old 11-27-2012, 07:27 AM
josephroberts75 josephroberts75 is offline
Mein Auto: e36 bmw
And if all else fails check your rear window is still sealed to your car!!!! MINE made a thumping noise when going over bumps i found that i could pick up on the glass and only the corner was holding it on!!!
Old 11-30-2012, 12:00 AM
GeorgeBush234 GeorgeBush234 is offline
Mein Auto: Passat
Changing your shocks might solve the problem it could also be a tie rod and or a bushing form your stabilizer bar and or rack and pinion.
Old 12-02-2012, 01:37 PM
nothing.
lol
nothing.
:3
