Old 12-02-2012, 06:01 AM
mjposner mjposner is offline
Mein Auto: BMW M
coding HUD
Does anyone know if the 2009 HUD can be coded to show the turn signals? I saw that the '12 could be done this way. I keep my steering wheel low and it blocks the side view so I some times pull a blue hair.
Old 12-02-2012, 06:25 AM
rebel.ranter rebel.ranter is offline
Mein Auto: M6, 630i, 320iC
Yes, that's possible:
Module: HUD
Parameter: BLINKER_AUSSTATTUNG
Setting change required: nicht_aktiv -> aktiv
Result: Turn signals in HUD
There are additional HUD changes possible too:
HUD:
M_SPORT_HUD. -> aktiv
M5 HUD - shows RPM bar and current gear (all three needs to be enabled for Mview to work in HUD settings)
CAPPL:
HUD_M -> aktiv
CAPPL:
MDrive -> aktiv
Old 12-02-2012, 10:41 AM
houbmw-cm houbmw-cm is offline
Mein Auto: 2007 BMW 650i
As Rebel stated ye it can be. It is a very nice feature to add to the HUD since the turn signals are behind the steering wheel. I foudn this feature to be very useful. Hopefully you can find someone to help you get setup for coding. It is a chore to setup, but once you have it setup, the coding part os pretty simple.
Good luck.
Old 12-02-2012, 12:56 PM
Mein Auto: BMW M
As I only have a 650i I can't get the sweet M stuff. I also want to turn off seat belt chime (every morning, bong bong while I get situated, I wear them I swear), lawyer screen on nav, sport mode on by default if possible
Old 12-02-2012, 03:24 PM
You should be able to enable the M elements in your HUD, there's only one HuD hardware & it is coded according to the car it is fitted to. Similarly the MDrive menu can be enabled in any iDrive system but it doesn't do anything, you can select P400, P500, P500 Sport but it does nothing. I think the HUD functions do work though.
As for Sport mode on by default, I don't think this is possible. You might be able to make up a circuit that provides a momentary pulse of positive (or negative, would have to check that) power supply to the back of the Sport switch at start up. There is no code to do it anyway
Legal Disclaimer remove
Module: CAPPL/MASK
Parameter: LEGAL_DISCL
Change required: aktiv -> nicht_aktiv
Seat Belt chime remove
Module: ABG & SGM (2 modules for total disable, just disable ABG if you want it to bong just twice)
Parameter:
SBR_BEIFAHRER_ACSM (Driver)
SBR_FAHRER_ACSM (Passenger)
Change required:
Video in Motion
Module: CAPPL
Parameter: VIDEO_DENY_C0B
Change required: deny_slow_key -> deny_never
There's tonnes of changes on top of this that can also be done like adding a digital speedo
Old 12-03-2012, 11:14 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
Module: CAPPL/MASK
Change required: aktiv -> night_aktiv
Parameter:
Change required:
Video in Motion
Module: CAPPL
All true. My car is a 650i (2007) and I have the M HUD option coded. Blinkers are great as well. But, I don't get the gear in my HUD Guess I need to go check this out when I get home.
Ranter - Can my car show video? and do you know the module/command to unlock doors when put it in Park or kill motor?
M6 bumpers, skirts & wheels
HUD, Comfort Access
Old 12-03-2012, 01:25 PM
Unlock Doors:
Module: CAS
Parameter: ER_KEYOUT_AUTOVR
Change: nicht_aktiv -> aktiv
(Note if someone opens a door prematurely the other door/trunk will not auto unlock)
Another useful one is being able to press & hold Start/Stop button to pop key out:
Module: CAS
Parameter: KOMFORT_EJECT
As for playing video? What would the source be? There is a code to enable reverse camera if you have a CIC or CCC, maybe you could use that feed? Another option is to install the Dension system.
Old 12-04-2012, 05:05 AM
Mulchman's Avatar
Mein Auto: '07 650i
Unlock Doors:
Module: CAS
Module: CAS
Thanks for those. I will do them this morning.
I was hoping for DVD playback. I've read threads that say it is possible and seen many that say you need a CIC.
HUD, Comfort Access
Old 12-04-2012, 10:47 AM
TRIPLE_O TRIPLE_O is offline
OOO
Mein Auto: F80 M3
Unfortunately your car doesn't support DVD playback from factory.
Old 12-04-2012, 06:09 PM
pablo645's Avatar
pablo645 pablo645 is offline
Mein Auto: 650i Convertible
I will have to try some of these one of these days . Since I got my PC and NSExpert working I haven't had time to do anything like this. The HUD change does seems interesting and would be handy for me to do as well. I may have to reach out to some of you experts when i'm ready
2012 650-xDrive Convertible. Titanium Silver Metallic - M Package - Driver assist package- Cold weather package - luxury seating package - Bang & Oulfsen system.
Previous Cars:
2008 650 Convertible 6 speed manual
2004 645 Convertible 6 speed manual
1994 540 6 speed manual
Old 12-06-2012, 10:55 AM
greco2000's Avatar
greco2000 greco2000 is offline
Mein Auto: 2008 650i LCI
Just had some coding done for me today. Did the HUD turn signal, roll up window with key fob and anger eye led code delete.
2012 BMW M6 CONVERTIBLE
Old 01-22-2016, 05:04 AM
tomtebloss tomtebloss is offline
Mein Auto: 530D LCI 700NM
Module: HUD
HUD:
CAPPL:
HUD_M -> aktiv
CAPPL:
MDrive -> aktiv
I LOVE YOU !! /From Sweden!
Old 01-22-2016, 03:41 PM
Thanks! ........I think
Current cars
1996 e36 320iC (convertible)
2006 e63 630i Sport w/SMG
2007 e63 M6
Previous Cars: 2002 e39 525iA Sport, 1994 e36 318i, 1990 e34 520i, 1989 e30 325i, 1986 e30 316
Old 01-22-2016, 08:11 PM
Its abit funny. I got a 530d and my rpm only goes to 4500rpm before shifting. 4500 rpm is like lower than middle on the hud rpm haha. Abit fail
Old 01-23-2016, 02:04 PM
KwlAznKid KwlAznKid is offline
Mein Auto: E46 325 CI
damn i wish i had HUD for this, i always have trouble seeing the blinkers, they are placed horribly
BMW E64 650I- H&R Springs, BBS LM reps, 8000K HID, 8000K HID fogs, Custom Exhaust, Interior LEDs, Vinyl Amber Cover, LED Sidemarkers, Carbon Fiber Roundel, Vorsteiner Rep Spoiler, Black Kidney Grills
Mercedes Benz W209 CLK500- 8000K HID, Resonator Delete, Mangaflow Muffler, Black Grill
BMW E92 335I (SOLD) / BMW E46 M3 (SOLD) / BMW E92 328I (SOLD)
Porsche 996 Carrera (SOLD) / BMW E46 325CI (Totaled)
Old 01-23-2016, 02:44 PM
I wish i had cup holders
haha
Old 01-23-2016, 04:36 PM
The unfortunate problem is you are missing 4 cylinders to allow the Rev counter in HUD to register correctly.
Old 01-23-2016, 05:15 PM
I really think its because m5 e60 revs to 8500 rpm and my diesel revs to 4500rpm
Old 01-24-2016, 02:34 AM
Sorry, I was saying that in a very round about way. I have an M6, the rev limit is 8250rpm.
Old 06-24-2016, 09:30 PM
happythanh happythanh is offline
Mein Auto: Vietnam
hello everyone,
I tried to code my 2007 E70 4.8i to show the RPM bar and current gear on HUD but it only shows the RPM bar but not the current gear, it only show the gear when I switch to Manual gear.
besides I do not see the Menu CAPPL as per the guide below:
/quoted/
HUD:
CAPPL:
HUD_M -> aktiv
CAPPL:
MDrive -> aktiv
/quoted/
Old 06-25-2016, 11:47 AM
6 Five-O 6 Five-O is offline
Mein Auto: '07 650i, '98 M3
I'd be very interested to know how to show the gear on the HUD with an SMG. Any one done this?
Old 06-25-2016, 04:23 PM
roseng's Avatar
roseng roseng is offline
I have not but, try BMWCoding.com or the M5 forum M5 and M6 sections.
