E90/E91/E92/E93 (2006 - 2013)
Old 12-03-2012, 01:45 PM
dinanwes dinanwes is offline
Mein Auto: Bmw 328i sedan
Make service engine soon light go away?
I currently drive a 2008 328I and my yellow service engine soon light is on due to a recently added cold air intake. Is there any way to reset it or make it go away without going to the dealer or mechanic?
Thank you in advanced.
Old 12-03-2012, 02:48 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
What did you do with your Hot film Mass air flow meter? If the new intake system doesn't have the ability to accept that sensor you probably
shouldn't use that intake system. You could do some drilling to make it work. By the way since you're running an E90 328i you're better off just
getting a reuseable drop in filter. Unless you're running your "cold air" intake from a wheel well or outside the engine bay, or unless you're running
an Arma supercharger, it's best to leave the factory intake box as it draws air from outside already. You knew this already though.
Good Luck.
Check your mirrors as often as it takes for you to know where everyone is around you!
Old 12-03-2012, 03:17 PM
I appreciate your response I am not thoroughly educated in cars which is kind of why I'm on here. I did keep the sensor in there because the cold air intake had a spot for it. Ill attach a picture below. Is there anyway to reset the service engine soon light or will it constantly think that somethings not right and come back on? Thanks again I appreciate it.
Old 12-03-2012, 03:21 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Yes. Wouldn't you like to know which codes were thrown?
Likely it will return.
I refer you to e90post for educational experience!
Old 12-03-2012, 03:52 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
Is that an oiled filter by any chance .
The kind that can fowl the MAF Sensor do to too much oil on the MAF Sensor.
If you get a coding setup or a BAV tool you can reset stuff and read what your problems are.
With a coding setup you can also code stuff .
http://www.e90post.com/forums/forumdisplay.php?f=368
http://www.e90post.com/forums/forumdisplay.php?f=16
Old 12-05-2012, 07:54 AM
bimmerzone's Avatar
bimmerzone bimmerzone is offline
Supporting Vendor
Mein Auto: E63 650i
There is a tool to reset it, but again, you really should check to see what the code is, and fix the issue.
http://www.bimmerzone.com/Diagnostic...ST06-EI07.html
or
http://www.bimmerzone.com/Diagnostic...nic/BT-EK.html
Good luck!
| Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 833 Lincoln Ave, Suite 5, West Chester PA 19380 |
Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw
We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!!
