E90/E91/E92/E93 (2006 - 2013)
Hello fellow BMW owners; any winterizing suggestions?
I recently bought my second BMW: a 2007 328ix Sport Wagon that seems to have been very well-cared for. My first BMW was a 1978 R100 motorcycle that used in college in the early 1980s. In the early 1970s I was a BMW mechanic at Autohaus Continental in New Jersey. I've since moved on from that profession, but I've retained some of my wrenching skills.
I live on a relatively steep, unmaintained dirt road in the Rockies, so the x-drive will come in handy when it starts snowing. When winter finally arrives, I plan to park the car and cover it for the winter with an outdoor factory cover. Apart from oil change, etc. any suggestions on winterizing? |
Better yet get a battery tender, it holds the voltage just like the alternator does. Plug the car in and it will be ready to go when you want it. Clean it fill the gas tank, change the oil and pump up the tires and you are done. I have 2 cars stored in my garage every winter and that is what i do.
David |
Definitely use a battery tender.
Also Stabil fuel stabilizer added on your final fill up.
Laser ___________________________ 2011 535i Black Sapphire Metallic, Sport, Euro Del (ret) 2009 328i Black Sapphire Metallic 2007 Honda S2000 Berlina Black |
Easier than tearing into the trunk, but is it better? A resounding NO! Why, just imagine the strain on our nation's electrical grid with every winterized car marinating on a battery tender. David Williamso, it is your patriotic duty to go the extra mile, to make the effort above and beyond what is easy and convenient, to disconnect those batteries! |
I say plug it in, Nothing like a good old rolling brown out to get our country to see that wind mills and solar power just want supple our electric needs!
Hondo |
Clean well inside and out, wax, dress tires and seals around doors etc. Change oil, check all other fluids and antifreeze protection. Fill tires to max. Fill tank with fresh tank of gas and fuel stabilizer. Pull fuse/relay for fuel pump and run until it dies. Put desiccant bags inside. Stuff steel wool into tailpipes and air intake (if possible). Pull battery and take it inside charging monthly or on a tender (there are benefits to leaving it in and doing this but it is outside after all). Check with your agent about maintenence insurance. Cover and done!
>AHEM< Climate control. Temperature and humidity play a vital role re: corrosion and organic material longevity. Let's not discount the advantages of a hermetically sealed, controlled environment! What is does for wine, it does for fine machinery. Your vehicle can outlive you - I recommend you reflect that in your will or trust. . Last edited by CALWATERBOY; 12-03-2012 at 10:33 AM. |
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic. ------------------------------------------------------------------------ E90 328i E92 335i 6MT E46 M3 6MT E39 528i 5MT MBz W140 S320 MBz W124 300E (slammed) (unmentionables in between) '71 AMC Javelin (4-Spd Stick on the floor) '67 Pontiac Firebird 'cabrio' (1st car - "the leaker") ------------------------------------------------------------------------ Member: BMW CCA |
Nevermind OP, just follow Calwaterboys advise. Build or locate for rental a hermetically sealed, controlled environment and disconnect those batteries! That is really all you need to do. |
Either get a battery tender or disconnect the battery completely. Pour in some STA-BIL into the tank, let it run through the system and leave it be. You may also want to cover the exhausts with something just so that no creepy crawlies go into your exhaust.
OMG! OMG! OMG! rdorman, your education needs a boost - Uncle Bob can help! For the well heeled, service oriented facilities. OP, for Winter TLC, please PM yours truly for Caymans bank routing info - I'll be pleased to provide excellent Winter layup for your personal ride - substantial registration fee is required. We must ask: Is OP a dedicated BMW aficionado? |
We all should be looking forward to the forthcoming advise on storage of fine wines. |
I would crank the car at least once a month, keeps the cylinders from rusting and the bearings coated with some oil. worst thing for a car is not driving it for extended periods of time
Hondo |
Sta-bil and a Battery Tender is all you really need. And if you insist on disconnecting the battery, don't forget that it will be very difficult to open the trunk, should it inadvertantly be closed. Tom |
Tom, the good news is: There are Trunk Latch Electrical Activation Connections in the engine compartment. Configured for easy use while wearing gloves, just clamp on those jumbo jumper cable jaws & press the key fob button. Bonus: She'll start right up! |
