E34 (1989 - 1995)
Old 09-29-2011, 09:24 AM
rodneyb525i rodneyb525i is offline
Mein Auto: 91 525i
Angry Help!!!!! Battery keeps dying.
Fellas,
I have 91 525i. This is my first BMW. My battery keeps dying but i have had it checked and it's a good battery. Everything shuts down where I cant even get into the car. So I have to leave the hood popped. My interior lights will not come on anymore. Im assuming its my alternator. i have to unhook the negative cable on the battery when its parked. Any suggestions?
Thanks in advance.
Old 09-29-2011, 10:14 AM
ECSTuning's Avatar
Instructor of the Stig™
If you want to check the alternator many auto parts stores have the ability to do this for you and it's often free of charge. But if you're losing power while the car is not running there is a high probability you have a power drain issue, or simply put something isn't turning off. Start with the easy stuff make sure all your lights are turning off, interior, ruining lamps, trunk light, etc.
ECS Tuning
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
Click HERE to read what people are saying about ECS Tuning
Old 09-29-2011, 10:20 AM
Mein Auto: 91 525i
Thanks for the reply. I forgot to mention that had a bad negative cable to my battery, that I replaced 3 days ago. I thought that was the source, but clearly it wasn't.
Old 09-29-2011, 11:48 AM
dansr dansr is offline
Mein Auto: 2002 540i Sport 6Spd
I had the same problem with my daughters 1994 525i a month or so ago. Turns out my ignition switch was not terminating correctly, leaving a constant drain on the battery. Apparently, the switch had a bunch of crud built up over the years, so I sprayed it WD40, worked the switch on and off about 10 or so times, repeated the process 3 times. That cleaned the switch out, it now works as advertised.
Hope that helps,
Dan
Northern Virginia
Former Volvo Enthusiast
2002 540i 6 spd, Sports Pkg
Mods so far:
Redline MTL in tranny | Redline 75W90 in diff |
05/545i short shifter | Weighted selector rod |
CDV Delete | Zionsville Cooling Solution
Old 09-29-2011, 12:16 PM
Mein Auto: 91 525i
thanks dansr,
This might be a dumb question, but Im a rookie when it comes to working on cars. Im sure you had to take the ignition switch out/off before spraying it with WD40, right?
Old 09-29-2011, 10:47 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
how new is the battery, and what size is it? i havent a lot of experience with the E34, but one thing i know for sure is they are very sensitive to thier batteries, and a half cut one often wont do, even if it bench tests fine
E30 above Sold
Last updated 2nd January 2014
Old 09-29-2011, 11:24 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
find a 900-1000 CA Battery. Spend 95-150 On a Euro Spec and change it in every two years for a prorated replacement .These cars go through batteries.
Old 09-30-2011, 09:33 AM
Mein Auto: 91 525i
Thanks Luckydog,
I called around and I could not find a battery that's pushing 900-1000. But I did find a 800. Is that acceptable? I dont know how much my curret one is pushing out @ the moment.
Old 09-30-2011, 09:46 AM
Mein Auto: 91 525i
Ok, I just found one that has a cold crank at 850 and cranking at 1,050 for $119.00. Is that good
Old 09-30-2011, 09:50 AM
Mein Auto: 91 525i
ethrty,
The battery is not very big. In fact, it doesn't fill the space for the battery holder.
Old 10-01-2011, 12:56 AM
luckydog's Avatar
If its not wide long heavy and short and come with a small plastic breather vent hose, its proably not a Euro Spec .Min 850 cca..
Name:	1990 german Spec M5.jpg
Old 10-01-2011, 01:02 AM
yes the batteries are huge! they should easily fill the entire space under the seat
E30 above Sold
Old 10-01-2011, 03:58 AM
BmwMan92's Avatar
BmwMan92 BmwMan92 is offline
I <3 my E34
Mein Auto: 1985 318i// 1988 325e
the e34 in this picture was on cl in washington like a year or so ago haha
Brandon
http://www.facebook.com/brandon.m.fore
Originally Posted by v8bimmer View Post
I just dont see any other logical way around this problem.
Old 10-04-2011, 08:00 AM
Hey Rodney, have you found a good replacement battery? I found that Advance Auto, Walmart and AutoZone carry a battery for our beloved E34s. All around $100 USD.
I did not remove the ignition switch. Just held a paper towel under the steering column and sprayed the heck out of it.
What ever you do, don't try a battery that is not made for the E34, and be sure to connect the vent tube!
Dan
Northern Virginia
Mods so far:
Old 12-02-2012, 12:23 PM
bmw325i82 bmw325i82 is offline
Mein Auto: 325i
help
i have a 94 325i that i got the other day and was told it had a charging prob,so replaced the the alterantor with a new one and was driving home last night and all the lights dimmed and then the car just died,when i turn the car on all the lights are bright but when i try to start it it just clicks,it fires right up when i jump it and last mabye 5 to 6 miles then dies again,i had the new alterantor tested the day i got it and it was good,all wires are hooked up right,ive checked all my grounds and replaced all the fuses,with a full charge it will last all day,does any one have any ideas what could cause this to happen or has it happened to any one else and they have figured it out,any help would work thank you
Old 12-03-2012, 06:52 AM
BMWFatherFigure's Avatar
Old School
Alternator failing under load, thread jacker.
Current:
E38 Parts Car
Previous:
Old 12-03-2012, 06:37 PM
Mein Auto: 325i
battery
i had the alternator tested and its fine,i was told its my battery,i was also told to check all my ground wires and also check the ignition
Old 12-03-2012, 06:54 PM
Banned
Mein Auto: car
Please post this in the e36 forum. They would be more familiar with your car's peculiarities.
