Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 12-02-2012, 01:03 AM
svenmate svenmate is offline
Mein Auto: a bmw
325i with Bee*R Limiter
Hey chaps,
I'm putting a BEE*R rev limiter in my 325i e30 with motronic M1.1 ecu and built m20b25.
Just wondering if anyone has done it before/may know which wires to tap.
The manual for the limiter says one wire goes to the sensor-in signal and one to the sensor-out signal. Upon looking at other installations the 'in signal' is really just a tachometer pulse and the 'out signal' is an ignition source/crank angle sensor wire.
Apparently the motronic ecu has two Crank Ref Sensor wires. I presume i wire the signal out to the positive one of these?
Any help would be appreciated.
Old 12-03-2012, 05:32 AM
BMWFatherFigure's Avatar
Old School
The ECU has a rev limiter in it already (unless yours is broken). How far down do you want to set it? Is this so your partner does not more speeding tickets?
Current:
Previous:
Old 12-03-2012, 07:41 PM
pjoa09 pjoa09 is offline
Mein Auto: 318i E30 1992 (M40)
doin mah two step
Old 12-03-2012, 10:33 PM
kamotors's Avatar
kamotors kamotors is offline
Mein Auto: 325i
not sure how to setup a Bee-R but I have mine on a momentary switch with megasquirt. 6 psi off the linevideo is old and on Pirelli p-zero's, I'm now on much stickier rubber.
400whp turbo M20
