BMW Coding and Programming
Discuss coding options and features on your BMW here. |
how to revert to original
hi all
i did some programming, and of course i did NOT read all the doc and manuals i was able to do some coding (enabling sli, digital speedo ...), but i'm not 100% sure what i did change and i maybe changed some values i shouldn't have touched. you know: real men don't do backups so i wanted to start from the very beginning. and do it all with a more methodical and revertible approach. afaik you can code the original setting. so what i did was: open e-sys connect read vehicle order activate fa right click SVT -> read coding click on the ECU itself - NOT the CAFD_**** click on CODE did this with all ECUs i played with so everything is back to how i received the car. all new features are gone, and the car looks like original. is it? could anyone confirm that i did it right? thanks regards izeman |
Real man just don't answer for your question.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 10-22-2012 at 08:24 PM. |
@shawnsheridan: thanks for clarification. to repeat: if i alter the FA, and start coding, then want to restart from the beginning and re-read the FA, this FA is altered, and not what i want. correct?
what i did was make a backup of the FA when i first connected my car. so if i load that .xml in the fa/vo window and then code all ECUs i should be fine. correct? |
So, as you did, you make a back up of your original FA that you can always use to VO Code your ECU's. You simply need to load it and VO Code the modules. You can leave the altered VO written to the car as is.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
Shawn,
In a related matter, if I backed up all the CAFD files before doing any coding, am I able to restore those CAFD files and therefore bring my car back to factory settings? If yes, what is the process of restoring the backup CAFD files? Thanks. |
So to restore that data or ECU state, in place of selecting Read Coding Data, select New and point to the saved .ncd file with the corresponding CAFD name in your backup folder and proceed with the regular steps of saving and activating FA and FDL Code the ECU.
Hi,
when I started coding my f10 I've done this procedure: Quote:
And still, this to me is not a preferred method anyway. I would simply use my original FA, and VO Code each ECU to reset it. It is a much simpler and cleaner process.
I am soon about to get started (slowly)... First I was going to read coding data of all of my green CAFD and then copy to another folder (which I assume is good practice even if I may never need and would likely restore using VO coding). First question: Is it safe to use the ctrl key and select all of the green CAFD files and then richt click and "read coding data" or should I do them one at a time or a few at a time? Second question: Roughly how many CAFD files are there to read and how much time should it take just to read all the original CAFD files if I were to select all of them and read all of them at once or if I were to do them one at a time? Verification of my approach: 1. My plan for my first connection to the car is to read all the CAFD (either one by one or all at once depending on what you recommend) and then disconecting from the car and making a backup copy of those files (to another folder). 2. I would then work offline with the FDL editor editing the CAFD files I read (located C:\ESysdata\CAF and not the backup copies, of course) and save the edited CAFD files(s). 3. Then I would connect to the car, click read and then right click FA and activate FA... 4. Then I would click on the CAFD file that I edited (offline) and click Code FDL (or would it be better to read it again and do the edit it while connected to the car / eliminate step 2)? Thank you again for all of your assistance and sorry if I am being a little too concerned here (e.g. too many questions), just don't want to do something stupid and brick my new M5. I really appreaciate all you and others (e.g. April1, etc.) contribute and how patient and willing to help you are... Oh crap, one last question (I know to run the ZGW_Search in XP mode which I already set), do I need to run e-sys in xp mode? I have a windows 7 64 bit laptop (same as you, I think) and I think you stated e-sys works with Windows 7 64-bit (i.e. not in xp mode)? Last edited by Glock 32; 12-03-2012 at 11:28 PM. |
In my car, I have around 40 CAFD's, and on average it takes maybe 20 -30 seconds to read a module. I am not sure on your "plan". I study my CAFD's while disconnected, but I have never edited one and saved it, and then attempted to connect back to the car and code the module with it. After your step 3, after you read and activate FA, I don't think you will have your SVT with all your modules still showing, particularly if E-Sys was shutdown and reopened during this "off-line working period", and you will have to read your VCM and for each module add your edited CAFD to it and code it. I run E-Sys straight from my Win7 64-Bit machine, with ZGW_SEARCH.exe running in XP Mode. I also have a version virtualized on XP Mode that I can use, but seldom do.
That makes sense. I realized I was misreading after this post and reading through everything again.
One last stupid question regarding saving a backup of the FA. I assume I just click the save button after reading the FA and assume that is more of a saveas which will save to the HARD DRIVE on my laptop and not the car?. Just want to make sure I don't make a a bonehead mistake with that assumption and start saving something back to the car. Thank you, again for all the help... |
From the e-sys manual:
Selection of individual CAFD entries Control unit is read out with the selected CAF Selections at Basic Variants level Control units are read out with all CADs listed below the selected basic variants Selection at ECU or SVT level All control units with valid CAFD entries with green check mark in the SVT view are read out. It appears instead of holding the ctrl key, I can select the SVT folder or ECU subfolder and all will be read... My only concern now is that 20 to 30 second per roughly 40 CAFDs equals about ~ 15 to 20 minutes and likely the car will turn off prior to completing. I assume that would not be tragic if only reading CAFDs and not coding the FDLs(?), but still do not want something to glitch. Is there anyway to make sure the car stays on besides running the engine at idle for 20 minutes or so(?) or do you think it will actually be a lot quicker than this(?) If I were to read only half of them (or if the car turns off halfway through), do I then turn off the car (wait, already off, haha) turn back on the car and then reconnect e-sys, read, read VCM, etc and somehow start where I left offt(?), which leads to another question... What is the proper way to disconnect from the car after coding(?), simply turn off the car and disconnect the cable or is there a disconnect button in e-sys to properly disconnect (e.g. worried about some sort of write cashing not completing as can happen with usb flash drives, etc. if I pull the plug to early). Do I simply shutdown the car and pull the plug once e-sys FDL code completes and I close the Report dialog(?) I am sure I am overthinking this now... I promise, this is my last batch of questions before I dive in
There are no delayed write issues. When you FDL Code an ECU, you will see the progress in the TAL report window, and when it is done it will show it was successful. So to disconnect, you can just disconnect from the OBDII port or the Laptop port so long as no Tal is executing.
I missed this in April1 "Coding made easy: Step by step instructions for Fxx Series":
BTW, April1, your trip to the PO was not in vain... I received the cable Monday (much appreciated!) Thank you both for putting up with all my questions on top of everyone else's. I know it can get old answering newbie questions over and over, yet you do it without any sarcasm and a ton of patience... You have been a big help to all. I am about to head out and start reading CAFD files for backup... |
Everything went fairly smooth...
The one click read of all CAFD only took a minute or so to read all 34... And I saved that report which gives me a nice list of all modules and the associated CAFD files for each module for my car. I was going to read one by one, but after reading the first one in only a few seconds, I decided to select the SVT folder and read all CAFD files. Successfully enabled the video in motion and the sport display; however, the sport display does not seem to work with the M5. That would be cool if it did on the M5 at 560HP, oh well. Will enable other stuff later... Kind if spooky for a newbie when the NAV goes blank and "No Signal" appeared in the display for a few seconds... :o) Thank you again... Last edited by Glock 32; 12-06-2012 at 12:22 AM. |
The Sport Displays work with the newer N55 and N63tu Motors, but not on the older N63 Motor, presumably because it lacks the data stream.
Hmmm (that is promising), I have a 2013 M5 (Sept production) and would think that is the newest motor.
The sport display shows and with correct units, but does not seem to work... |
What is your Short VIN (last 7)?
PM sent...
If I am not mistaken (hopefully), ALL M5's should have the S63B44TU. Hopefully that is what you find. I think the S63B44 is what is in the M version of the X5 and has less compression, etc.
I think I threw up a little... It does make me wonder if they changed something more minor (e.g. added pathway or software that is on the N63TU) at some point or maybe it takes a bit to start working? Now I need to search if other M5 owners have this working or not... I picked my September production M5 at a dealer and cancelled my December production (that just went into production) which is why I threw up a little when I started researching this technical upgrade (TU). If it is just software or an added pathway, no big deal. Last edited by Glock 32; 12-06-2012 at 07:17 AM. |
#25
We know that Sport Displays work in the N55B30 used in the F10 535i, and the new N63B44TU used in the F06 650i GC, but they do not work in the older N63B44 used in the F10 550i, the F12 650i, and the F07 550i GT. I find it odd though that the updated version of the N63B44 was made to support Sport Displays, but the updated version of the S63B44 seemingly was not. Maybe BMW just does not want Sport Displays working in the M5/M6.
