Old 12-02-2011, 10:47 AM
- How to clean the headliner (1) & how to fix a sagging headliner (1) & how to replace the headliner (1) (2) (3) (4) & known good headliner glues (1) (2)
- How to replace the E39 V8 valve cover gasket (1) (pdf) (2) (3) & VCG DIYs for the E39 I6 (1) (2) (3) (4) (5) & which VCG brand to buy (1) (2) & what VCG lubricants to use (1)
- How to change the high MID OBC clock to display time in 24-hour military format (1)
- The search for a heater core DIY (1) & questions about temporarily bypassing the heater core (1) and searching for a cooling system heater pipe heater core inlet return pipe leak (1) (2) (3)
- DIY for how to replace the auxiliary fan (1) (2) (3) & how to test the cooling system auxiliary electrical fan (1) (2) & the infamous fuse 75 (1) & the aux fan relay (1) & an exploding aux fan noise situation (1)
- How to remove & replace the a-pillar (1)
- ABS BRAKE DSC trifecta brake pressure sensor diagnostic test DIY (1)
- Various methods for draining & refilling (1) (pdf) & bleeding the cooling system for all E39s (1) (2) (pdf) & instructions specific for the V8 (1) & the BMW TIS for bleeding the cooling system (pdf) & for working on the cooling system (pdf).
- Strut tower braces explained (1) & strut tower camber kits (1) & how you can diagnose & repair your E39 if your strut towers mushroomed (1) (2)
- How to rebadge a debadged bimmer numbers & letters, e.g., 540i (1)
- Summary advice to provide users who suspect a major engine repair due to overheating (1) (2) (3) (4) & how to test an engine for a blown head gasket, cracked heads, a warped block, stripped head bolt threads, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2) & what are the major factors in deciding whether to rebuild the engine, replace the engine, or sell the car (1) & a DIY for replacing the I6 M54 head gasket (1) (2) & replacing the V8 M62TU head gasket (1) & why these engines are so prone to heat-related damage in the first place (1) & welding the crack between cylinder #3 and the water jacket on the exhaust side (1) & what engine swaps are most recommended (1) (2) (3) & where to obtain a new or rebuilt head (1) replacement short block or long block (1) (2) & how to lift & remove the engine (1) & the most recent real-world results from people faced with similar blown engine problems from which this advice came from (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33) (34) (35) (36) (37) (38) (39) (40) (41) (42) (43) (44) (45)
--- since last backup ---
- What does it mean when my cluster tells me "gurt anelag" i.e., put on a belt (1)
- How to understand the BMW E39 EWS alarm drive-away protection system (1) (2) (pdf) & troubleshoot the alarm & hood switch (1) (2) (3) (4) or replace the siren (1) or disabling or enabling the unlock chirp (1) (2) (3) & how to maintain (1) and repair your hood release bowden cable (1) (2) (3)
- How to diagnose oil consumption & oil pressure problems (1) (2)
- What happens if you remove the under engine cover splash guard plastic shield (1)
- What gasoline mileage should an E39 get (1) (2) (3) (4) (5) (6) (7) (8) & the truth about mpg calculation accuracy (1) (2) & E39 great mpg stories (1) (2) (3) & people repeatedly asking about awful E39 fuel mileage (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31)
- Hints from experienced E39 forum posters for newbies on efficient searching (1)
- Where to get a proper DISA valve repair kit (1) & how some jury-rig 'repair' a rattling DISA unit (1) (2) (3) & how the DISA valve operates (0) (1) (2) (3) (4) & how to test DISA operation (0) (1) (2) (3) (4) & a simple DIY to install an M54 DISA (1) & a nice DISA autopsy (1) (2) & a great DISA group buy (1) & how the disa valve o-ring fails (1) (2) & how it can reputedly cause all sorts of cold-engine rough idle problems (1) (2) & where to get just the DISA valve o-ring (1) & why you want to check the DISA at 100K miles or whenever the airbox is removed (1) (2) & why the DIfferenzierte SAuganlage ("Differential Air Intake") valve flap breaks (1), sometimes with parts sucked into the intake manifold (1) (2) (3) (4) (5) (6) (7) (8) & a well documented example of how a broken DISA flap can ruin your engine (1) & yet another seemingly complex set of misfire codes reputedly traced to a broken DISA valve (1)
- Useful cut & paste ASCII TEXT symbols:° ± ¿ ÷ · strike ½ ¼ 1st 2nd 3rd 4th 5th µF § ¢ £ € X-x H2O, Vb TM ® (1) (2)
- Supplier prices lookup comparison engine (1) & BMW salvage (junkyard) parts lookup engine (1) & BMWfans search by part number (1) & Realoem nominal prices by part number (1) & EACTuning actual prices by part number (1) & BMW of South Atlanta actual prices by part number (1) & Maxmillian BMW dealer prices by part number (1) & the most often recommended parts suppliers (1) & what BMW E39 parts & supplies are best to buy OEM (1) & joining BMWCCA to lower parts costs (1) (2) & what parts to always get OEM (1) which BMW dealers match prices (1) & in situ pictures of common parts of the M54 engine (1)
- What's the trick to get the radiator back in on the M52 engine?
- JB Weld & epoxy radiator repair (1) (2) (3)
- - What gasoline mileage should an E39 get (0) (1) (2) (3) (4) (5) (6) (7) & the truth about mpg calculation accuracy (1) (2) & E39 great mpg stories (1) (2) (3) & your basic E39 awful fuel mileage issues (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31).
BLUEBEE BACKUP 20120110
Bluebee backup 20120114
Old 02-03-2012, 11:32 AM
Updates:
- Summary advice to provide users who suspect a major engine repair due to overheating (1) (2) (3) (4) & how to test an engine for a blown head gasket, cracked heads, a warped block, stripped head bolt threads, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2) & what are the major factors in deciding whether to rebuild the engine, replace the engine, or sell the car (1) & a DIY for replacing the I6 M54 head gasket (1) (2) & replacing the V8 M62TU head gasket (1) & why these engines are so prone to heat-related damage in the first place (1) & welding the crack between cylinder #3 and the water jacket on the exhaust side (1) & what engine swaps are most recommended (1) (2) (3) & where to obtain a new or rebuilt head (1) replacement short block or long block (1) (2) & how to lift & remove the engine (1) & the most recent real-world results from the last 50 people faced with similar blown engine problems from which this advice came from (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33) (34) (35) (36) (37) (38) (39) (40) (41) (42) (43) (44) (45) (46) (47) (48) (49) (50)
- How to logically choose tires by the numbers (1) (2) or by Bimmerfest user recommendations (1) (2) & where to buy your tires in the USA (0) (1) (2) (3) (4) (5) (6) & tire plant codes (1) (2) (3) & tire safety (1) & recommended tire pressures (1) (2) (3) & the claimed benefits of nitrogen gas (1) (2) & choosing the right BMW tire/tyre size (1) (2) & tire circumference, diameter, offset, & clearance calculators (1) (2) (3) (4) (5) & a torque conversion calculator (1) & tire terminology (1) (2) & wheel terminology (1) & BMW wheel specs (1) & BMW & replica wheel styles (1) (2) (3) (4) & the difference between cast vs forged wheels (1) & where to find the wheel markings for proper match mounting (1) & the best products for cleaning wheels (1) & how to choose the right size wheel spacers (1) (2) & where to go when you bend or otherwise damage your wheels (1)
- What could cause a BMW fan blade to explode or disintegrate (1) (2) (3) (4) (5) (6) & should you go electric (1)
- What is the cheapest usable BMW E39 airbag srs reset/scan tool on the net (1) & what can cause a BMW E39 SRS airbag light (1) (2) (3) (4) (5) (6) & what tools reset the fault (1) (2) (3) (4) (5) & what happens when we disconnect the airbag before the battery or we connect the battery before disconnecting the airbag in seat and window regulator repairs (1) (2) (3) (4) (5) (6) (7) (8) & where to buy an airbag occupancy sensor bypass unit (1) (2).
- How to open the hood (1) or trunk manually when you have a dead 12v car battery (1) (2) (3) & how to unlock the older E39 if the key is locked inside the trunk (1) (2)
- Information about the plastic underbody panel kick panel splash plate under the engine (1)
- How to test the crankcase ventilation (aka CCV, CVV, PCV, CPV, & OSV) pressure regulating valve system (1) & a video of oil separator quacking chubacca noise (1) & vacuum leaks due to holes in one or more of the five CCV hoses (1) (2) (3) or frozen or torn diaphragms (1) & a clogged CCV (1) causing pressure in the crankcase and smoke in the exhaust necessitating CCV system overhaul (BavAuto M54, M54,M54,M54,M54, & M54 observations) (M52,M52) (M52TU) (M62,M62) ('99 528i) ('98 528i); usually replaced with the insulated CCV upgrade (1) & sorely needed clarification on how the M54 CCV vacuum port works on the M52 CCV valve connection to the fuel pressure regulator connection (1) & how to do a CCV delete (1)
Old 06-03-2012, 09:11 AM
Update:
- How to diagnose & repair cracked, broken, or frayed BMW trunk loom wires causing all sorts of strange mischief (1)
- How to test, clean, & redesign the original BMW dipstick guide tube to prevent CCV vent clogs (1)
- How to repair your DISA valve using titanium & aluminium machined parts and eliminate the chance of engine pin ingestion (1)
- How to diagnose the E39 engine failsafe prog cluster error message (1) (2) (3) (4)
- How to diagnose the BMW amber ABS BRAKE DSC/ASC trifecta or bifecta (1) & what are all known options when your ABS control module is bad (1) & Quick99Si's explanation of why the 10-minute wheel speed sensor diode-action quick test doesn't always work, especially on brand new non-OEM wheel speed sensors (1) (2) & explanations by 540iman as to why the fancy diagnostic tools very often (extremely often, like almost all the time) fail to properly diagnose the trifecta or bifecta (1) (2) (3) (4) (5) (6) & where to get the fancy schmancy diagnostic tools for free once you're aware of these limitations (1) & an ABS BRAKE DSC trifecta brake pressure sensor diagnostic DIY (1)
- How to test your generator (1) & how to determine exactly what alternator you have (1) & a DIY for replacing the E39 I6 alternator (1) (2) (3) (4) (5) or E39 V8 alternator (1) (2) (3) (4) & why you want to clean out the air-cooled alternator air duct & cooling vents (1) (2) (1) (2) & why rebuilding an alternator is preferable to replacing (1) & cn90 DIYs for rebuilding a 1998 air-cooled BMW Bosch alternator (1) (2) or his VW Bosch alternator (1) & cdawg246's quest for materials for a Bosch water cooled alternator rebuild (1) & Aioros' 1999 Valeo Alternator rebuild DIY (1) and his quest for materials (1) & Cn90's explanation of where to get hard-to-get alternator rebuild parts (1) & how to tell from the part number if a replacement alternator is actually rebuilt "by" Bosch (1) & a DIY for replacing the brushes in an (Audi) Valeo alternator (1) & a Bosch alternator bearing replacement from a 1997 MB S600 (1) & from a Range Rover (1).
Old 08-03-2012, 09:02 PM
- One users' example of total electrical failure (AAA towed away) alternator repair (1) [Read post #66 & post #107 & especially post #146]
- Does an ATF leak from power steering hoses onto the alternator cause the bearings to fail (1)
- How to make your own ball joint replacement tool (1) (2) & what balljoint tools to use for the I6 & V8 (1) (2) (3) (4) & where to buy a front wishbone (1) or rear ball joint press (1) (2)
- How to replace the E39 V8 valve cover gasket (1) (2) (3) (4) (540 pdf) (E38) (E38 pdf) & VCG DIYs for the E39 I6 M54 (1) (2) (3) (4) (5) (2004 E46 video) (another E46 video) (yet another E46 video) & which VCG brand to buy (1) (2) & what VCG lubricants to use (1) & how to replace the timing chain tensioner and rail guide on the I6 (1) & on the M62 (1) & on the M62TU (1) (2) (3)
- BMW M62TU engine VANOS seals DIY (1) & where to buy M62TU VANOS seals (1) & how to make your own VANOS tools (1) & socket tools (1) & how to objectively test VANOS seals in operation (1)
- Which of the dozen alignment specs are adjustable on the BMW E39 (1) (pdf) & cn90's front (1) (2) and rear (1) wheel alignment DIYs & how to keep the steering wheel (SW) straight during home alignment (1) (2) & what tools measure rear camber at home (1) (2) and what tools measure front/rear toe at home (1) & what tools lock the steering wheel & brake pedal at home (1) & the theory of alignment with weights (1) or without adding weight (1) (2) (3) & philosophically why most people prefer to let a professional alignment shop align their suspension (1) & what expensive equipment is used at the stealer to align your suspension (1) (pdf) & Internet references for how to DIY caster, camber & toe at home (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33) (34) (35) (36) (37) (38) (39)
- What are 'all' options when your instrument cluster or MID pixels slowly die due to a press-fit pink electrical-connection tape lifting off its contacts over time (1) & how to remove the E39 instrument cluster (1) (2) & a summary of the BMW NA cluster-repair goodwill policy (1) & how to fix the MID pixels yourself (1) (2) (3) (4) (5) (6) & how to remove the MID (1) (2) (3) (4) (5) (6) (7) & how to test the MID (1) & how to read the mileage from the key if you can't read the cluster display (1)
- ASCII TEXT symbols that work on this forum: ½, ¼, ¾,°, ±, 1st, 2nd, 3rd, 4th, 5th, ÷, ·, µF, ¢, £, €, X-x, §, H2O, ¿, strike, Vb, TM ®, (1) (2)
- It's not a DIY, it's what happened: One user's cooling system overhaul: How to get the radiator back on (1)
- Motor mounts (aka engine mounts) and transmission mounts (aka holders) DIYs for the BMW E39 I6 (0) (1) (2) (3) (4) & for the V8 (1) (2) (3).
- BMW E38/E39 V8 M62 engine valley pan gasket coolant leak DIY (1) (2) (3) (4) (5) (6) & what parts to order in a valley pan gasket kit (1) (2) & what is the purpose of the valley pan anyway (1)
- What to do if your steering wheel & key cylinder locks in place (1) (2) & signs of a failing ignition switch (1) or ring antenna (1) & the BMW TIS for when the ignition switch spins but does not engage (1) & rebuilding a failed ignition switch (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) & BMW training on the EWS alarm drive away protection system (pdf) & erasing old keys from the locking control module (1)
- Helicoils (1) vs Timeserts (1) for stripped oilpan (1) & spark plug (1) & head gasket thread repair (1) & Metric/SAE bolt conversion factors (1)
- How to remove and replace the glovebox latch (1) (2) (3)
- How to replace the rain sensor (1) (2) & retrofitting a windshield with a rain sensor (1) (2) (3) (4)
- How to locate, test, and replace the automatic transmission speed sensor (1)
- How to test and replace the steering angle sensor (1)
- How to diagnose the P0741 DTC (1) & how to replace your torque converter (1)
- What windshield washer fluid to use (1) (2) & what intensive cleaning system fluid to use (1) & how to adjust windshield washer spray nozzles (1) & where to get OEM VDO/Conti windshield washer pumps (1) (2) & windshield washer reservoir & pump DIYs (1) (2) (3) & specific issues of windshield reservoirs prone to leaking due to an ill-fitting pump o-ring gasket (1) (2) or to hose disintegration (1) (2) or to leaks in the main reservoir (1) (2) (3) or leaks in the intensive wash system (1) (2) or the pump itself goes bad (1) (2) & further debugging hints (1) & one users windshield washer leak experience (1)
- What is the cheapest usable BMW E39 airbag srs reset/scan tool on the net (1) & a cn90 DIY for replacing the driver seat belt buckle pretensioner and the passenger seat emulator (1) & what can cause a BMW E39 SRS airbag light (1) (2) (3) (4) (5) (6) & what scan tools reset the fault (1) (2) (3) (4) (5) & what happens when we disconnect the airbag before the battery or we connect the battery before disconnecting the airbag in seat and window regulator repairs (1) (2) (3) (4) (5) (6) (7) (8) & where to obtain an airbag occupancy sensor bypass unit (1) (2).
- How to mount a front license plate holder to the BMW E39 tow hook port (1)
- How to properly maintain a door lock (1) & a DIY for how to replace the front lock door actuator (1) & how to disable automatic door locks (1) (2)
Old 10-16-2012, 10:35 PM
- How to diagnose and replace a BMW E39 front driver side door window regulator (1) and how to remove a BMW E39 front passenger side door window regulator (1) (2) & the unintuitive trick to effortlessly loosen and tighten the astronomical cable tension without damaging the front door window regulator (1) & how to rebuild and restring your current E39 front door window regulator (1) & scores of pictures showing how NOT to remove & repair your front door window regulators (1)
- How to diagnose (1) and fix broken wires in heated seats (1) & how to do a front (1) & rear (1) heated seat retrofit & how to retrofit active comfort seats into the E39 (1)
- Where to find an E39 wiring diagram specific to your model (1) (2) (3) (4) & understanding European wiring diagrams (pdf) & where to find all E39 fuse boxes (1) (2) & how to find the elusive front passenger seat undercarpet fuse panel (1) & a diagnostic procedure to test for overnight parasitic battery drain (1) & specific troubleshooting for SAS fuse F107 (1) & cooling system aux fan fuse F75 (1) (2) (3) (4) (5) & oil level sensor fuse F15 (1) & the central locking trunk release fuse F53 due to a stock fuel door solenoid (1) (2) & various fuses due to a bad trunk wiring loom (1) & adding new fuses & wiring in the engine bay (1) & all about the BMW Glovebox Flashlight Cigarette Lighter Power Adapter (1) (2) (3) & how to install a Valentine or Escort radar detector (1) (2)
- How to replace the exterior door handle in the BMW E39 (1) (2) (3) & how to open a single stuck shut locked front or rear closed E39 door from a broken door latch/lock (1) (2) & how to properly maintain a door lock (1) & a DIY for how to replace the front lock door actuator (1) & how to disable automatic door locks (1) (2)
- The main causes of vibration while highway driving (0) (1) (2) (3) (4) (5) & while highway braking (1) (2) (3) & why it's not rotor "warp" (1) & severe ABS shuddering while slow speed braking on bumps (1) & how fluid-filled thrust arm bushings crack and tear causing the BMW to vibrate at speed (0) (1) (1) (2) (3) (4) (5) (6) (7) (8) & a comprehensive TireRack vehicle vibration diagnosis chart (1) (jpg) with wheel match mounting hints (1) & how a worn drive shaft, flex disc, center bearing, or "giunti Boschi", aka giubo (it's not spelled guibo although it sounds like it is to some) can cause the vehicle to vibrate (1) (2) (3) (4) & how to repair the rear driveshaft seal by the differential (1) & how to repair the inner constant velocity (CV) half-drive shaft (1).
- How to replace the V8 crank position sensor (CKP) crankshaft pulse generator (1)
- Where to by the cheapest least expensive precision measuring tools such as digital calipers, digital micrometer, and dial indicators (1)
- Is it true that "you get what you pay for" when purchasing E39 goods and services (1)
- How to tow extricate extract a bimmer from snow or mud without using the tow hook (1)
- How to contact the Bimmerfest E39 forum owners and moderators (1) (2) (3) (4)
- How to test and repair the self leveling suspension (SLS) system pneumatic spring (1) (2)
- What is Rislone or Bars Stop Leak or Bar's Head Gasket Fix and what will it do in your BMW (1)
- How to DIY the trunk boot struts (1) & how to replace the touring liftgate hatch shock absorbers (1)
- What gasoline mileage should an E39 get (0) (1) (2) (3) (4) (5) (6) (7) & achievable mpg calculation accuracy (1) (2) & E39 great fuel economy stories (1) (2) (3) & just some of the many E39 lousy miles per gallon threads (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33).
- How the secondary air system (SAS) and secondary air pump (SAP) and air valve, check valve, & electrical valve operate (1) & how to maintain (1) (2) (3) & replace (1) & troubleshoot the BMW E39 SAS SAP valve secondary air pump system (1) (2) (3) (4) & an SAP valve group buy (1)
- What is the cheapest usable BMW E39 airbag srs reset/scan tool on the net (1) & what other scan tools reset the fault (1) (2) (3) (4) (5) & a BMW description of the SRS system (1) & what can cause a BMW E39 SRS airbag light (1) (2) (3) (4) (5) (6) & a cn90 DIY for replacing the driver seat belt buckle pretensioner and the passenger seat emulator (1) (2) & where to obtain an airbag occupancy sensor bypass unit (0) (1) (2) & what happens when we disconnect the airbag before the battery or we connect the battery before disconnecting the airbag in seat and window regulator repairs (1) (2) (3) (4) (5) (6) (7) (8)
Old 12-19-2012, 05:26 AM
- One users experience diagnosing parasitic dead battery overnight current drain (1) & what's the secret to removing FSU blower motor fuse F76 (1)
- How to find the General Module under the glovebox and how to remove the GMIII General Module 3 and how to repair the GM 3 and how the GM3 affects door locks from the key fob and central locking button (1)
- What is the best hands free bluetooth cellphone and handsfree audio streaming in 2013 (1) & what cigarette lighter car adapter is the best power supply charger (1)
- How the secondary air system (SAS) and secondary air pump (SAP) and air valve, check valve, & electrical valve operate (1) & how to maintain (1) (2) (3) & replace (1) & troubleshoot the BMW E39 SAS SAP valve secondary air pump system (1) (2) (3) (4) & an SAP valve group buy (1) & a BMW TIS on how to diagnose the SAS (1)
- What stuff (parts, fluids, gaskets, o-rings, filters, scanners, tools, etc.) should we stock in our garage for eventual use (1)
- What is the complete list of o-rings to order for routine oil change maintenance tasks (1)
- How to wire an aftermarket radio audio amplifier (1)
- How best to integrate an Android cellphone or iPhone smart phone into your E39 (1)
- How to remove the E39 business CD radio MID (1) and adding the BMW AUX smart phone connection (1) & DICE Silverline radio-mount instructions (1) (2) (3) & how to remove just the MID (1) (2) (3) & how not to remove the MID (1) (2) by stripping the torx twist screw.
- How to locate, access, and replace the CKP crank position sensor in the I6 (1) and the crankshaft pulse generator in the V8 (1)
- How to diagnose and replace a BMW E39 front driver side door window regulator (1) and how to remove a BMW E39 front passenger side door window regulator (1) (2) & the unintuitive trick to effortlessly loosen and tighten the astronomical cable tension without damaging the front door window regulator (1) & how to rebuild and restring your current E39 front door window regulator (1) & scores of pictures showing how NOT to remove & repair your front door window regulators (1) & what is the empty two-wire connector in the front driver side door used for anyway (1) (2)
- Where to buy wiper blade refills (1) & a DIY for replacing your windshield wiper blades (1) & how to replace the wiper arm (1) (2) & troubleshooting or replacing the wiper motor (1) (2) (3) (4) (5) (6) (7) or wiper switch (1) or wiper relay (1) & how to replace the wind shield rain sensor (1) (2) & retrofitting an aftermarket rain sensor (1) (2) (3) & how to remove Rain-X water wiper streaks & spots on windshield glass (1) (2) (3) (4) (5) (6) (7)
- Complete DIY for how to test a BMW battery & alternator (1) & a diagnostic procedure to test for overnight parasitic battery drain (1) & how to find all the fuses (1) & how to choose a good aftermarket battery (1) and a simple battery replacement DIY (1) & where to find the battery explosive charge emergency quick disconnect (1) (2)
- The Gasoline FAQ & top-tier gas stations (1) & what gasoline to use (1) & all about ethanol in gasoline (1) (2) & what is the true cost differential between 87 & 91 octane AKI (1) & how large is the fuel tank and reserve in the E39 (1) & how much gas should be left to cool the fuel pump (1) & how to siphon the fuel out of the tank (1) & does spilled gasoline go into the charcoal canister (1) & all about those Techron additives (1) & all about Bell Performance Mix-I-Go (1)
- What gasoline mileage should an E39 really get (0) (1) (2) (3) (4) (5) (6) (7) & what is a realistically achievable mpg calculation accuracy (1) (2) & worsening E39 miles per gallon diagnostics (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33) (34) (35) & even some E39 great fuel economy stories (1) (2) (3)
- How does the E39 fuel injection work (1) & what are the most often recommended fuel pump & fuel filter brands (1) (2) & a DIY for replacing the fuel filter (0) (1) (2) (3) (4) (5) (6) & a quick test for fuel pump operation (1) (2) and a DIY for replacing the fuel pump (1) (2) (3) (4) (5) & how to replace and service your BMW E39 fuel injectors (1) & details on replacing the 7.52X3.52mm and 9.2X2.8mm fuel injector o-rings (1) & the location of the K96 fuel pump relay (1) & where is the fuel system pressure test Schrader valve for the I6 (1) & where is the fuel pressure test point for the V8 (1) (2) (3) & where is the location of the fuel pump relay K96 (1) & cleaning (1) (2) & replacing the fuel sensor (1) & resolving blown fuses due to a stuck fuel filler door solenoid (1) & how to replace the gas cap tether (1) & a reputed fuel filler leak into the trunk (1) & the P0455 diagnostic trouble code when the gas cap is missing (1) & what is the cost differential between 87 & 91 octane AKI (1) & what gasoline mileage should an E39 get (0) (1) (2) (3) (4) (5) (6) (7) & the truth about mpg calculation accuracy (1) (2) & E39 great mpg stories (1) (2) (3) & E39 awful fuel mileage issues (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30).
- How to test compression on a BMW E39 V8 engine (1) and on the I6 engine (1)
- How to diagnose and replace the TPS throttle position sensor (1)
- How to identify a heated steering wheel (1) & how to retrofit to a 3-spoke M-Sport steering wheel (1) (2) (3) (4) & heated steering wheel mods (1) & restoring the life of an old steering wheel (1) (2) & where to buy the BMW steering wheel roundel (1) (2) (3) (4) (5).
- How to remove & replace a catalytic converter (1) & how to fix rattling cat shields (1) & BMW P0420 codes related to cats (1) (2) (3) & cat autopsy photos (1) & what kills cats (1) & an EPA fact sheet on catalytic converter warranties (1)
- Signs of a failing ignition switch (1) (2) or ring antenna (1) & the BMW TIS for when the ignition switch spins but does not engage (1) & rebuilding a failed ignition switch (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) & what to do if your steering wheel & key cylinder locks in place (1) (2) & the BMW training on the EWS alarm drive away protection system (pdf) & erasing old keys from the locking control module (1)
- How to diagnose the BMW amber ABS BRAKE DSC/ASC trifecta or bifecta (1) & what are all known options when your ABS control module is bad (1) & Quick99Si's explanation of why the 10-minute wheel speed sensor diode-action quick test doesn't always work, especially on brand new non-OEM wheel speed sensors (1) (2) & explanations by 540iman as to why the fancy diagnostic tools very often (extremely often, like almost all the time) fail to properly diagnose the trifecta or bifecta (1) (2) (3) (4) (5) (6) & where to get the fancy schmancy diagnostic tools for free once you're aware of these limitations (1) & an ABS BRAKE DSC trifecta brake pressure sensor diagnostic DIY (1) & how to test and replace the steering angle sensor (1)
- What do you keep in your trunk for winter emergencies (1) & for all-weather emergencies (1) & pictures of complete rear tool kit contents (cn90) (3-series) & the BMW Rescue Manual for Emergency Services (1)
- How not to (JB Weld) fix a cracked radiator or other cooling system overhaul leaks (1) (2)
- How to jump start your E39 & where is the proper place to hook jumpstarting cables (1) (2)
- Where is the FSU located on European UK spec right hand drive (RHD) vehicles (1) (2) (3)
- How to remove the two kidney grills (mirror trick?) when you can't open your stuck hood on your BMW E39 (1)
Parts & labour rates:
  • Supplier prices lookup comparison engine (1) & BMW salvage (junkyard) parts lookup engine (1) & BMWfans search by part number (1) & Realoem nominal prices by part number (1) & EACTuning actual prices by part number (1) & BMW of South Atlanta actual prices by part number (1) & Maxmillian BMW dealer prices by part number (1) & the most often recommended parts suppliers (1) & what BMW E39 parts & supplies are best to buy OEM (1) & joining BMWCCA to lower parts costs (1) (2) & what parts to always get OEM (1) which BMW dealers match prices (1) & in situ pictures of common parts of the M54 engine (1) & what other tandem parts to buy while you're there (1)
  • Finding a reputable BMW indy in your area (1) (2) & the consumers' checkbook method of finding a good mechanic (1) & repairpal labor/job/shop rates by zip code (1) & other things to consider replacing while you're already there (1)
  • Making sense of the most often recommended BMW diagnostic tools & cable interfaces (1) & BMW factory & dealer programming, coding, and diagnostic software such as INPA, EDIABAS, NCS Expert, DIS, EasyDIS, Progman (1) (2) (3) (4) (5) (6) (7) (8) (9) & related BMW diagnostic-tool forums (1) (2) (3) (4) (5)
  • Where can one obtain the BMW KSD for flat rate unit (FRU) labor pricing (1) & the BMW TIS for technical service bulletins (1) (2) & an on-line WDS (1) & a text-searchable PDF Bentley E39 repair manual, volume I (1) (2) & the best price on paper Bentleys (1) & the Bentley Publishers Online Technical Library (1) & if you can no longer find the TIS, here's why (1)
  • What to tell those who haven't yet bonded with their E39 who feel they don't have time, money, expertise, or tools to DIY & why the tools are free when they do so (1)
Old 02-17-2013, 09:11 AM
- What is the location of the engine drain plug and proper procedure to drain the M54 coolant (1) (2) & draining the M52 engine cooling system (1)
- One user's attempt at locating and snapping a picture of every single fuse & relay in the BMW E39 (1) & the most often recommended method to diagnose overnight parasitic battery current drain including the FSU (1)
- One users method of installing 12v and USB cigarette lighter power adapters for smart phones and cell phones in 2013 (1) & how people add a handsfree bluetooth cellphone or smartphone in 2013 (1) (2) & how some install an iPad (1) or an Android tablet (1)
- How much does personality type play a role in how people approach an unexpected BMW repair (1)
- How to modify the cooling system expansion tank 2 bar cap to 1.2 bar to vent at a lower pressure (1)
- What to check if your cluster indicates a rear brake lamp out (1) & how to remove a melted center brake light (1)
- Where to get coupon codes for buying parts at local suppliers (1)
- Motor mounts and transmission mounts (aka holders) DIYs for the BMW E39 I6 (0) (1) (2) (3) (4) & engine mounts or the V8 (0) (1) (2) (3).
- What is that brown discoloration color of my heated side view mirrors (1)
- What does a blinking SES light mean and is it safe to drive the car with the CEL flashing (1)
- How to build a test jig for fsu parasitic battery drain and HVAC anomaly diagnostics (1)
- What stuff (parts, fluids, gaskets, o-rings, filters, scanners, tools, etc.) should we stock in our garage for eventual use (1) & how long will these stocked rubber parts last stored in your garage (1)
- What brand is the OEM original equipment manufacturer OE for my BMW parts (1) & what parts & supplies are best to buy OES or OEM (1)
- What size is the exhaust pipe cutout (1)
- Why are all four windows rolled down when I go outside to my BMW (1) (2) (3)
- The main causes front-end clunk while driving (1) & clunking while braking (1) & the generic causes of vehicle vibration while highway driving (0) (1) (2) (3) (4) (5) & while highway braking (1) (2) (3) & why it's not rotor "warp" (1) & severe ABS shuddering while slow speed braking on bumps (1) & how fluid-filled thrust arm bushings crack and tear causing the BMW to vibrate at speed (0) (1) (1) (2) (3) (4) (5) (6) (7) (8) & a comprehensive TireRack vehicle vibration diagnosis chart (1) (jpg) with wheel match mounting hints (1) & how a worn drive shaft, flex disc, center bearing, or "giunti Boschi", aka giubo (it's not spelled guibo although it sounds like it is to some) can cause the vehicle to vibrate (1) (2) (3) (4) & how to repair the rear driveshaft seal by the differential (1) & how to repair the inner constant velocity (CV) half-drive shaft (1).
- How to replace the old-style BMW square key battery (1) (2) & how to replace the rubber key pads in the square keys (1) (2) & what the red LED indicates on the old square key (1) & what can go wrong with a key and where to send it for repair (1) (2) (3) (4) & what battery to use in the new style 2000+ BMW E39, E46, E53, E85, etc. diamond key (1) (2) (3) (4) (5) (6) (7) & youtube videos of diamond key repairs (1) (2) (3) & a square key to diamond key retrofit and transponder swap (1) (2) (3) (4) & diamond key to square key retrofit questions (1) & how to recharge your key out of your BMW and how long that key will last in the drawer before it needs that off-the-car recharging (1) & the details on swapping the BMW diamond key transponder (1) & the proper diamond key initializing or programming sequence (1) (2) (3) (4) (5) (6) & what to do if your only key is locked inside your bimmer (1) & a description of the various types of BMW Remote, Illuminated, Spare/Wallet, & Valet/Service keys (1) (2) & a list of diamond key EWS, FZV, & DWA functions (1) (2) & all about the 10-key limit to programming your own keys at home (1) & a description of the ignition key ISN (individual serial number) ten-second rule (1) & what to do if you lost your only diamond key (1) or what to do if your BMW key was stolen (1)
- How to tell whether you have the high or low on board computer cluster (1) & a video showing how to unlock the low OBC (1) or the high OBC cluster for diagnostics (1) (2) and quickie telephone verbal instructions for unlocking the high instrument cluster on the E39 (1) & how to change the OBC MID IHKA KTMP temperature from degrees Celcius to Fahrenheit (1) (2) (3) (4) (5) (6) (7) (8) & how to retrofit an E39 from the low obc to the high obc (pdf)
- BMW E39 rear window regulator replacement DIY (1) (2) (3) (4) (5) (6) & McGyver fixes on the road (1) (2) & rear window regulator repair kits (1) (2) (3) (4) & what brand rear window regulators should I get (1) & where to get salvaged parts (1) & how to remove the rear window (1) (2) & how to adjust the windows after the repair (1) (2) (3) & how to temporarily keep the window up (1) & how to rewind the transmission case windup spool (1) (2) & how to slip the cable wires back onto the pulleys (1) (2) (3) & how to replace just the rollers (1) (2)
- One user's effort to diagnose, rebuild, and replace a BMW E39 front driver side door window regulator (1) and how to remove a BMW E39 front passenger side door window regulator (1) (2) & the unintuitive trick to effortlessly loosen and tighten the astronomical cable tension without damaging the front door window regulator (1) & how to rebuild and restring your current E39 front door window regulator (1) & scores of pictures showing how NOT to remove & repair your front door window regulators (1) & how to replace just the rollers (1) (2)
- How to maintain (1) and repair your hood release bowden cable (1) (2) (3) & how to replace the hood cable the easy way (1) & how to open the hood when the hood cable snaps (1) (2) & how to open the hood manually when you have a dead 12v car battery (1) [or trunk (1) (2)] & how to make your own hood release tool when the cable breaks and the hood won't open (1)
- What is your opinion on buying a BMW with a salvage title (1) (2) (3) (4)
- One user's convoluted quest to find & fix persistent intermittent misfire set of lean condition vacuum leaks P0313 P0300 P1353 P1083 P1085 P1351 P0171 P0174 (1)
- Heated seat fire burn on the BMW E39 (1) (2) (3) (4) (5) (6) (7) (8) & how to diagnose and fix broken wires in heated seats (1) (2) & a front heated seat retrofit DIY (1) (2) & how to add rear heated seats (1)
- What does an outside temperature chime and a triple beep beep beep memo clock monitor mean in the BMW E39 (1)
- Throttle pedal position TPS potentiometer autopsy photos (1)
- What triggers the E39 tamperdot and how the VIN and mileage and service interval are associated with the cluster red tamper dot (1)
- How to open the BMW E39 white e-box under the passenger side cabin air filter ebox (1)
- How to remove water in the headlights or headlight condensation on the lens (1)
- How to gracefully remove the upper & lower radiator hose (1) and how not to remove the M54 coolant temperature sensor (1)
- Locating and replacing the additional 1996-98 M52 coolant hoses (1)
- Outside ambient temperature sensor reads -40° on the cluster (1) (2) (3) (4) (5) & how to calibrate the ambient temp sensor (1) & how to change OBC MID IHKA KTMP temperature from degrees Celcius to Fahrenheit (1) (2) (3) (4) (5) (6) (7)
- BMW 10-character vehicle defect code lookup tool for dealer service records (1) & how to better understand your 17-character BMW VIN (1) (2) (3) (4) (5) (6) and online BMW VIN decoders (0) (1) (2) (3) (4) (5) & what is the definitive list of electronic computer modules that need VIN recoding once replaced (1)
- How to remove and replace the windshield (1) & how to align the windscreen based on the BMW TIS (1) & how to replace crumbling windshield gasket trim cover molding (1) (2) to prevent wind noise (1) & how to install or tighten a loose rear view mirror on the glass (1) (2) & how to replace rain sensors (1) (2) (3) & what is double glazing (1) & window glass cleaner fluids & cloths (1) & how to remove Rain-X water wiper streaks & spots on windshield & rearview mirror glass (1) (2) (3) (4) (5) (6) (7)
----- repairs -----
Behr cooling system leaking
Plastic DISA valve breaking & destroying the engine
Cluster pixel tape lifting
MID pixel tape lifting
Hella PBT headlight adjusters breaking
Power steering cap & hose leaking
Trunk wiring loom fraying
CCV clogging
Bosch ABS control module frying
Cupholders breaking
I6 VANOS seals deteriorating
V8 valley pan gaskets leaking
GKR/BMW/Valeo FSU/FSR dying
Thrust arm bushings leaking
Ambient temperature sensor breaking
Window regulators breaking
Vapor barrier adhesive leaking
Jack pads falling off
Windshield cover molding crumbling
Driver's seat control switch breaking
Rear center brakelight socket melting
Seat cables fall out causing seat twist
Windshield washer tanks & pumps leaking
BMW roundel paint chipping
Vent trim corner cracking & wood trim varnish cracking
----- maintenance -----
150K mile maintenance checklist & parts to periodically clean
Check and replace all fluids
Common engine misfires diagnosed & cold start misfires identified
The most recommended brake pads and rotors purchased & installed
Battery tested & the most often recommended battery & installation
Spark plugs bought & replaced
Check & align & mount and balance wheels
O-rings & gaskets & bulbs & vacuum hoses & fuses & wiper blade inserts & belts & bearings & oil filters & cabin air filters & engine air filters to stock
----- tools -----
Common tools needed for the E39 & an obdii DTC scanner & an SRS reset tool & accurate measurement tools & specialty cooling system tools
File Type: pdf california_air_resource_board_federal_test_procedure_and_the_california_unified_cycle.pdf (1.51 MB, 60 views)
File Type: pdf BMW_E36_1999_Electrical_Troubleshooting_Manual_Vehicles_produced_9-98_to_8-99-e36_99.pdf (4.12 MB, 25 views)
File Type: pdf BMW_E36_1997_Electrical_Troubleshooting_Manual_Vehicles_produced_9-96_to_8-97-e36_97_pages_1-251.pdf (6.82 MB, 40 views)
File Type: pdf BMW_E36_1997_Electrical_Troubleshooting_Manual_Vehicles_produced_9-96_to_8-97-e36_97_pages_249-e.pdf (3.00 MB, 39 views)
File Type: pdf BMW_X5_Central_Body_Electronics_ZKE_III_Training_Class.pdf (4.03 MB, 30 views)
File Type: pdf bmw_ews_programming_instructions_1of2.pdf (6.91 MB, 53 views)
File Type: pdf bmw_key_programming_instructions_2of2.pdf (6.91 MB, 40 views)
File Type: pdf BMW_E39_E53_Low-to-High_OBC_Retrofit_kit_PN_65900308455.pdf (779.8 KB, 32 views)
File Type: pdf BMW_E39_TIS_Remove_Front_Windscreen_Windshield.pdf (679.1 KB, 13 views)
Last edited by bluebee; 04-15-2013 at 04:42 AM. Reason: I'll do some research for you, so you can find how to change the V8 alternator, and, you, for your part, agree to read the re
Old 02-21-2013, 08:54 PM
lreyes lreyes is offline
Mein Auto: 1999 BMW 528i
First timer
HELLO everyone, this is my first time to ever actually get into the hood of my car and fix things myself. I changed my oil yesterday and want to know when I schedule the next oil change? AND everytime I turn my driving wheel I hear kind of like a scretching noise (like metal and rubber rubbing against each other) what do you think that could be?
Old 04-27-2013, 05:21 AM
- How to locate all the cooling system hoses in the BMW E39 (1) (2) (3)
- Where to find the BMW TIS for technical service bulletins (1) (2) & if you can no longer find the TIS, here's why (1) & where to obtain the BMW KSD for flat rate unit (FRU) labor pricing (1) & an on-line WDS (1) & a text-searchable PDF Bentley E39 repair manual, volume I (1) (2) & the best price on paper Bentleys (1) & the Bentley Publishers Online Technical Library (1)
- Ideas for strapping emergency kits into the trunk indents above the battery and amplifier (1)
- Where to find a good deal on LL01 Mobil1 0W40 (1) & what is the difference with Mobil 1 10W40 (1) high mileage oil (1)
- How to determine the proper replacement alternator brand and amperage (Valeo, Bosch, 90A, 120Amps, or 140 amps) for your E39 (1)
- Survey of all available brands and prices and suppliers for front window regulators (1)
- How to replace the timing chain tensioner and rail guide on the I6 (1) & on the M62 (1) & on the M62TU (1) (2) (3) (4) (5)
- What size is the exhaust pipe cutout (1) & building a faux quad exhaust (1)
- DIY for changing the I6 manual transmission clutch (1) or the V8 clutch (1) or a BMW M5 clutch DIY (1) & how long does the OEM LUK BMW dual-mass flywheel last (1) & a CDV delete by removing or modifying the manual transmission clutch delay valve (1) (2) (3) (4) & brake & clutch hydraulic fluid (1)
- How does the BMW E39 fuel trim behave at high elevation (1) (2) (3) & where is the BMW E39 altitude pressure sensor (APS) (1)
- What parts to buy for a complete engine overhaul (1)
- How to DIY your BMW E39 I6 tie rods (1) (2) and your V8 tie rods (1) (2) (3)
- How not to clean your MAF mass airflow sensor (1) (2)
- How does the E39 fuel injection FI system work (1) & the location of the K96 FPR fuel pump relay (1) & the location of the fuel system pressure test Schrader valve for the I6 (1) and V8 (1) (2) (3) & a quick test for fuel pump operation (1) (2) & what are the most often recommended fuel pump & fuel filter brands (1) (2) & a DIY for replacing the fuel filter (1) (2) (3) (4) (5) (6) (7) & a DIY for replacing the fuel pump (1) (2) (3) (4) (5) & how to service your BMW E39 fuel injectors (1) & how to replace the 7.52X3.52mm and 9.2X2.8mm fuel injector o-rings (1) & cleaning the fuel gauge sensor (1) (2) & replacing the fuel sensor (1) & resolving blown fuses due to a stuck fuel filler door solenoid (1)
- Fuel injection LDP leak detection pump DIY (1) & a fuel system charcoal canister DIY (1) & where is the fuel tank breather valve (1)
Similar Threads
BEST BUY - E39 BMW shop manuals shaftdrive 5 Series DIY 61 08-02-2012 09:23 PM
E39 how-to/ performance links ? VTi E39 (1997 - 2003) 5 11-01-2010 01:28 PM
Why is there more used E39 540's for sale, is there something i don't know? gixxer E39 (1997 - 2003) 47 07-19-2006 10:25 PM
E39 Dimond Key Thread tkruger206 E39 (1997 - 2003) 4 07-07-2006 10:01 AM
NJ BMWCCA Round 2 Elwood Motorsports, Racing & Track 75 07-06-2004 04:45 AM
