Old 02-05-2009, 02:02 AM
jaldeborgh jaldeborgh is offline
Mein Auto: X3
Setting Up Garage Door Opener On 2007 X3
Anybody have experience setting up the garage door opener on their X3. I have a Lift-Master Security + opener and I think it has so much security that it doesn't work with the cars system.
I have followed the manuals instructions severall times with no luck.
Any thoughts or ideas would be appreciated.
I feel like a total idiot on this one.
John
2007 X3 3.0si - Wife's Car
2004 X3 2.5i - Daughter's Car
2003 K1200RS - Dad's Toy
2001 750 iL - Retired by me in 2005 - Great Car but wanted AWD
1995 750 iL - Retired by me in 2002 - Great Car
Old 02-05-2009, 05:40 AM
cubed cubed is offline
Mein Auto: 2010 X3, 2008 MT X3
I couldnt do it either
Old 02-05-2009, 06:17 AM
kyfdx's Avatar
kyfdx kyfdx is offline
Who, me?
Mein Auto: 2006 330Ci ZHP
It's complicated with a rolling code opener.. Be very careful, or you can fry your opener. Ask me how I know..
I did it with no problem with our previous E46, but this one drove me nuts.. After I replaced the opener ($400 later), I got it done on about the 5th try...
If your local dealer has a delivery specialist who goes over the car with you.. pay them $50 to come out and do it for you... It works with virtually all systems, so it's doubtful yours is a problem with the opener itself..
Good luck,
kyfdx
2006 330Ci ZHP Imola Red
2011 X3 Bluewater
1995 M3 Montreal Blue
1987 325iS Bronzit (retired)
2011 Z4 Space Gray (retired)
2008 X3 Sapphire Black (retired)
2005 330Cic Silver-Gray (retired)
2003 325i Sport Steel Blue (retired)
1967 2000CS Delphin Gray (retired)
Old 02-05-2009, 09:27 AM
b-y's Avatar
b-y b-y is offline
Mein Auto: 328xiT & M roadster
One suggestion that worked for me and has helped others (but possibly with different systems)...
Press and hold the buttons on the mirror for a longer time than specified in the instructions. Each step eventually gave the correct confirmation, but often after a longer period that listed in the instructions.
Recent ED: 25 June 10, 328xiT in Red. Then headed SW to Italy & France. Flew home via Rome. Hoegh Kobe departed 22 July; unloaded at PH 17 Aug. Redelivery 11 Sept. (Re-redelivery 14 Sept....read the details here.)
Previous ED: 7 June 08, X3 3.0si in rosso corsa (*), then off to Italy, Austria, Slovenia. (*Note: A61 Crimson Red north of the Alps.)
Back-up vehicle (while waiting for re-deliveries): 1999 M Roadster in Estoril Blue.
Old 02-05-2009, 10:09 AM
Coffeeman's Avatar
Coffeeman Coffeeman is offline
Mein Auto: 2005 X5 3.0i
Here is what worked for me:
1: Turn ignition to position 2
2: Hold down buttons 1 & 3 on the X3 until they begin to flash. This clears any previous codes
3: Hold down button 1 on the X3, then continuously press/release the button on your hand held remote, till button #1 flashes. (Time the press/release repeat cycle at about 1 second)
4: Press the learn button on the opener, then within 30 seconds, press button #1 on the X3.
5: Done
2008 ML320 CDI
2008 X3 3.0si
2005 X5 (retired)
2002 X5 (retired)
1999 Z3 (retired)
1990 535i (retired)
1986 528e (retired)
1978 733i (retired)
1977 320i (retired)
1974 2002tii (in storage)
1972 Bavaria (retired)
1970 2002 (retired)
Old 02-05-2009, 02:20 PM
BCX BCX is offline
Mein Auto: 2007 X3 Sport Package
Our rolling code garage door opener has a little button up on the motor/mechanism (that pulls the door up) under the cover for the lightbulbs. We needed to push that button (someone up on a ladder) and the one in the X3. It takes two people to do. I would download the instructions from your garage door opener off the web and see what they say. It is a pain...
Old 02-06-2009, 06:12 AM
madurodave's Avatar
BMW Enthusiast!
5: Done
Coffeeman's instructions should work. You may have to hold your current garage remote close to the mirror to allow it to take the coding. I did it by just pressing, not press and release.
Once mirror is programmed, press button on garage door opener motor then press your mirror button again. Garage lights should flash on/off. Then the X3's button should work!
Madurodave
My garage: 2013 BMW 550xi GT, 2007 BMW Z4 3.0si Manual, 2006 BMW 530xi
Retired: 2007 BMW X3, 1998 BMW Z3
Member of BMWCCA!
Old 02-06-2009, 06:27 AM
kyfdx's Avatar
Who, me?
Those are the correct instructions.. Doesn't mean it will work the first time, however..
Part of the problem... is that a lot of the steps don't give you any confirmation that they've been completed correctly.. So... if it doesn't work, you aren't sure where the problem lies...
I'll reiterate.. You CAN fry the electronics in your garage door opener.
One other small bitch..lol: On our 3-series, you just had to tap the button to get the door to open. On the X3, you have to hold it in for a full-second before the door moves, even though with the normal remote... it's just a tap.
Before this turns into a rant.... We love our X3!
2011 X3 Bluewater
Old 02-06-2009, 06:42 AM
madurodave's Avatar
BMW Enthusiast!
I don't mean to disagree with you, but how can this fry your garage door opener? If the code does not take, the garage will not open. If it does, it will open. It sounds like there may have been some other issue with your opener? Fauly board, possibly?
The only confirmations you get is that the codes are cleared on your X3's buttons, that the button is programmed, and the flashing of your garage lights. Those should let you know you're moving in the right direction.
I love my X3 too!
Madurodave
Member of BMWCCA!
Old 02-06-2009, 07:11 AM
iamthewalrus iamthewalrus is offline
Mein Auto: 2014 X1 xDrive35i
One last thing...
The instructions say to hold the original opener 8 inches away from the BMW opener. That didn't work for me. When I held it about 1 inch away, then it worked.
Old 02-06-2009, 07:18 AM
madurodave's Avatar
BMW Enthusiast!
My owners book said 1 - 2 inches away. For the 2007 model year.
Madurodave
Member of BMWCCA!
Old 02-06-2009, 07:23 AM
kyfdx's Avatar
Who, me?
I love my X3 too!
When you are pushing the button to set it up, you are also pushing your remote button... This is sending a constant signal to the main unit (from your own remote) That's what can fry the unit....
Granted, my unit is (was) ten year's old.. I'm sure a brand-new garage door unit can withstand a lot more...
Which on another note... I love the new belt drive unit!
2011 X3 Bluewater
Old 02-06-2009, 10:49 AM
Coffeeman's Avatar
Forgot to mention that during the programming process, I unplugged my door opener, to avoid frying it.
2008 ML320 CDI
2008 X3 3.0si
2005 X5 (retired)
2002 X5 (retired)
1999 Z3 (retired)
1990 535i (retired)
1986 528e (retired)
1978 733i (retired)
1977 320i (retired)
1970 2002 (retired)
Old 02-06-2009, 03:27 PM
Mein Auto: X3
All good ideas - but no luck yet. I'l keep trying.
John
Old 10-07-2010, 09:20 AM
ViperNY ViperNY is offline
Mein Auto: 2008 528XI E60
2010 X3 with Wayne Dalton worked perfect
5: Done
I searched the manual and the homelink web site and nothing worked. These instructions were perfect and on the money. Followed each step exactly and bingo. This is my 6th BMW and the first I have actually gotten to work.
Thanks for the post.
Vipz
Old 04-03-2011, 08:03 PM
nels415 nels415 is offline
Mein Auto: X3
I tried this recently, and no luck! I have a sears craftsman garage door opener. What am I doing wrong? On the last step #4 above, do I need to hold down the button on the X3. Thanks in advance.
-nels
Old 04-04-2011, 12:03 AM
X3-po's Avatar
X3-po X3-po is offline
Mein Auto: 2009 X3
#4 After pressing the button on the opener hold the button on the X3 mirror until the light flashes on the opener.
Old 04-04-2011, 06:01 AM
madurodave's Avatar
BMW Enthusiast!
Instructions do work. Make sure you clear existing codes in X3, then hold remote that works 2 inches from X3 buttons to program. Then link to opener - get confirmation of lights on opener blinking on/off.
Madurodave
Member of BMWCCA!
Old 02-21-2012, 04:06 AM
PC in Ohio PC in Ohio is offline
BMW CCA Member
Mein Auto: 2007 X3
5: Done
What is the learn button-on the car or remote?
Old 02-21-2012, 07:33 AM
CleanKM's Avatar
CleanKM CleanKM is offline
Bee Em UU
Mein Auto: 2014 328d
Should be on the opener unit itself.
Current: 2014 328d Black Sapphire Metallic, Black Interior, Nav, Xenon
Past:
2011 328i SA SULEV Black Sapphire Metallic, Dakota Beige, ZPP, Nav
2007 X3 3.0si Black Sapphire Metallic, Grey Nevada, M Sport Package, Premium, Cold Weather, Navigation, and Xenon.
Prod Date: March 2, 2007
Old 02-21-2012, 09:19 AM
ShakyDog's Avatar
ShakyDog ShakyDog is offline
Mein Auto: Z4 3.0i
Also have a liftmaster and the trick I had to use was to press the remote opener for 5 seconds, then release for 5 seconds and I kept repeating until it worked. I then had to have the girlfriend press the Homelink button, while I pressed the learn button on the back of the opener. This worked on both openers. I also had to experiment on the direction to hold the remote and the location. Backwards, up and to the left of the mirror about 2" 4" away.
Good luck, it was a source of get frustration :-O
Steve
Old 03-13-2012, 10:24 PM
X3mer One X3mer One is offline
Mein Auto: X3
5: Done
This is exactly what worked for me... Looked it up, followed the instructions and voila, it worked!!! Been trying for a week now and did it in 5 minutes after I read this post. Thanks much for he info.
Old 03-13-2012, 11:53 PM
X3mech X3mech is offline
Mein Auto: E83 3.0 si, E84 35i
I had the same issue. The way to resolve it is to make your cars reciever learn to clone what one of your existing working remotes is doing.
Old 12-04-2012, 08:48 AM
dmf415 dmf415 is offline
Mein Auto: x3
5: Done
This worked for me too, and it worked very quickly. I actually did the method in the manual and then tried the step 4. which didn't work the difference was pressing my remote once a second. And also doing step 4.
Old 12-11-2012, 06:36 PM
BMW CCA Member
Mein Auto: 2007 X3
Thanks for all the help on this thread/forum! Got mine to work! Step 4 was my key as I found the "Learn" button on my Liftmaster on the ceiling opener unit....thx again :Roundel:
