X1 E84 (2011 - current)
The new to the US BMW X1 will arrive at BMW dealers in the fall of 2012 as a 2013 model year. Get your X1 28i with either sDrive (RWD) or xDrive (AWD) or get the US exclusive I6 N55 powered X1 35i dDrive. |
X1 Driver Side Mirrors
Is there an issue with driver (left) side mirrors on these cars. I test drove an X1 and notified the dealer that the mirror could not be adjusted enough to the right (Could not see the car door).In fact it warped the mirror glass as I moved it to the right stop.
I ordered the car anyway and when mine came in, I have the same problem. Going in for repair but two cars with the same problem seems strange. Anyone else with this problem? |
Why do you need to see the car door?
From a frame of reference perspective, how do you you know where the mirror is pointed if you can't see the edge of the car?
However, getting used to it may take some time. But give it a chance and you'll soon realize that it works. I could explain it myself but this link will do it better. Like I said, give yourself a chance to get used to it and you will see more than you ever have. http://www.linquist.net/motorsports/tech/mirrors/
HaveBulldogWillTravel English Bulldog Rescue Recover Rehab Rehome Rewarding '13 X1 xDrive28i, Min. White, Sand, UP, LP, M-Sport, HK, Heated Seats, Satellite Cross Bars Trailer Hitch Arrived 12-4-12 without shift paddles...Dang-it! Oh well...shizz happens. |
If you can see the door handle on your side view mirror, then you have a blindspot esp when switching lanes.
I know this bec I used to set my mirrors the same way like you do. Not amymore. I feel safer with lane changes now. Last edited by CanadianDriver; 11-30-2012 at 01:22 PM. |
I personally adjust mine similar to what the article states.
2005 325xiT Jet Black / Beige - current daily driver 2010 528xi Saphire Black/Black/Dark Poplar - retired 2008 528xi Saphire Black / Oyster/ 6sp manual - retired 2003 330cic Jet Black / Natural Brown - retired 2001 X-5 3.0 Titanium Siver /Black - retired BMW CCA Member |
These are all wonderful suggestions on proper mirror setup. And I will try them out to see if they are better than what I have been using for the last 40 years.
However, the point of this thread was that the driver side mirror on my car does not have sufficient side to side travel. And since this was the second X1 that I noticed this on, I wanted to see how widespread this was. Whether or not I should be looking at the door, I still should be able to move the mirror enough to see the door. Thanks in advance. |
Part of this design hiccup probably has something to do with the fact that European vehicles don't have a flat exterior mirrors like the US requires. Since their mirrors are convex (and aspheric on the outer edge), the engineers' probably thought a certain angle of adjustment was sufficient for their mirrors, when with a flat mirror it isn't.
Kinda like how on the earlier E90-93 models, the smaller exterior mirrors had irritating blind spots with the flat glass even when adjusted properly (as mentioned in the article above). Completely fixed with the Euro-spec glass when I put it on my mom's 325i. |
Hmmmm. Strange that I drove plenty of other European (non-BMW) cars that did not exhibit this issue. Anyhow, it's going in for service on Tuesday. I'll let you know what the BMW techs have to say.
Had the same problem with my new X1. You can somewhat remedy the problem by pushing at the mirror with your finger. I had my dealer take a look at the mirror and it seems fine now. Not sure what they ended up adjusting or replacing. I feel that there was also some weird distortion in my original mirror.
Maybe something to do with seating position etc. that makes it difficult to adjust the mirror correctly. I use, and have always used, the method recommended in the link to adjust my door mirrors and the X1 mirrors seem to be able to accommodate both my wife and I with no problems albeit the drivers side is at the maximum clockwise position (when viewed from above the mirror) or very nearly.
Cheers Whitby 2012 528i MSport, Space Grey, Nav, Premium 2013 X1 XDrive 28i Msport, Valencia Orange, Ultimate, Lighting |
I have no problem with the drivers side mirror, I can adjust to where I can almost see myself in the side window (just went and tried it), it should be nowhere near that unless you are gangster leaning way to the right.
Ohhhh, you mean I'm NOT supposed to be sitting on the passengers side when driving?
I've seen some people driving almost that far over lol.
Well, the car went in for service today.
Good news is that I was right, the mirror is pooched and they will replace it under warranty. Bad news is that it has to come in from Germany. Won't be in for two weeks. |
I just picked up my X1 today and noticed the same problem!!! I thought there was just something wrong with the test car when I drove that but mine has it as well. I guess I'll be taking it back to BMW on Wednesday to get looked at... not even 2 hours home with the car and I have to take it in for service. whoopee.
I guess the BMW engineers know what's best for us (or someone messed up). Oh, by the Way "Happy New Years!" |
Haha, that's a good one!!!
Just picked up our new X1, and ran into the same problem. Not a good start. Do they do QA on these cars?
Based on your seating position and your height, the issue may be minimized, so not everyone notices this. But me being 5'9" tall forces me to position the mirror where it has the least amount of travel. |
I'm 5'9" and have no problems with the side mirror position and seeing whats around the car. My seating position may be different than yours.
How far can you move your mirror to the right? In my Subaru, while seated in a comfortable drivers position, I can move it so far that all I see is the car window. In my X1, I can't move it enough to the right to see the window or drivers side door. If I move the seat all the way back, the angle is better for me but then my feet can't reach the pedals. |
#25
I feel like I've asked this before: Why do you need to see the driver's side door? I guess I just adjust mirrors to see traffic, not my own vehicle. A bit of my rear quarter panel is all I need to see.
