Off-Topic
Everything not about BMWs. Posts must be "primetime safe" and in good taste. No personal attacks allowed. Political posting is restricted to the Political Science forum! |
#51
Netflix, Hulu and Bunny Ears here.
If Amazon gets better, I may cancel one of them and sign up. But for now, Amazon is meh. Agreed with Bee on the user interface. |
#52
Nah... AMZN isn't in the same league as Netflix. If all you have is $8 bucks to spare and you must pick one, clearly it will be Netflix. Fortunate for me, I make my own Starbucks in the morning and I can afford the extra $7 bucks
Go DUCKS!!! 2002 LeMans S62 E39 30 Jahre BMW ///M Power 1972~2002 BMWCCA #182142Autzen Stadium Aeriel View http://www.nmnathletics.com.edgesuit...ads1/24863.jpg http://www.nmnathletics.com.edgesuit...ads1/20562.gif http://www.goducks.com/fls/500/splas...oseBowl_03.jpg |
#54
Agreed - Amazon's current selection is pretty limited. Amazon did just sign Epix to get more stuff. But Prime's huge advantage is for the 2 day shipping.
BTW, Netflix is digging into digging into Nick's ratings supposedly. My son loves that he can watch Wallace & Gromit, Pinky Dinky Doo, etc via the Rokus in our house. I'll take that any day as a treat for him over letting him near real TV (and awful commercials). |
#55
Maybe use a cable tester? I'd get feedback from those with more experience with your situation before spending on anything. My related experience is limited to one single experience with a multimeter, I think I was testing a passive xover during a speaker repair, and nothing else, never once on a car, etc. You're welcome. Not that I wasn't already steering you away from my choice, but I forgot to mention you can have at least three quick-access favorite lists (don't remember if there is an ability to name these), and I don't know of a limit of channels per list (my first has a nice handful). The programming info isn't available like a "guide" as it of course would be with sat/cable. It shows only on the tuned channel, and IIRC, only for the present half hour block, and the next. A trait this is unique to this device out of my few sources is the option for instant subtitling when hitting mute (if subtitle info is available from the source to begin with). |
#56
I am pretty sure this is the way Dish had mine hooked up. IIRC, my 722 actually used a single triplexer that took the place of separate diplexer and separator at the tuner. Mine was a bit less straight forward since every RG6 is a homerun to a wiring closet, but the circuit is the same. The key for you will be to find where the satellite comes in from outside. If the satellite comes downstairs, terminates in the left-most diplexer, and then runs upstairs to the non HD TV, you should be good for cable runs. If the satellite terminates into a diplexer in some third space- like on the outside of your house- then your two TV's are connected by a cable that doesn't run directly between the two TV's. This will complicate your initiative. It can be confusing when you're looking at splitters because you might be seeing the duplex one- a Diplexer- or the separator plus- which is really just a one way split of incoming satellite signal. The tri-plexer works the same way, it's just one unit. The key to getting your head wrapped around this is understanding that the RG6 cable between diplexers has bandwidth to send data in both directions-up and down, to and fro. Said another way, multiple, physical, one way (up.down-to.fro) links are not necessary directly between 222k receiver and the 2nd TV. The signal leaves the 222k, hits the diplexer, and finds it's way back upstairs alongside the incoming satellite signal. The 722k I used has a slot in the back for an OTA tuner module. I actually still have a module (and a 722k) that I am not using. The OTA tuner allows for any connected TV to use OTA channels. |
#57
You've just reminded me that the DISH guy did some drilling on the exterior wall, maybe I should take a pic of the "device" on the outside wall. I don't see nor recall anything else inside except for the 222k. How about you stop by my house after work and I'll buy you dinner? KS isn't that far away really... Edited: Oh wait, maybe I've seen the separator as well... So let's say the 222 no longer exist and I only have OTA antenna. How would you wire the setup? Last edited by Griffoun; 09-06-2012 at 08:33 PM. |
#58
But that's me. I get (got) acceptable signal for as much TV as I watch. (not a lot) If I was to do it up right and perm skillz, I would get me one of those gargantuan attic antennas then split the bad boy up. You should be OK with a regular splitter as they usually handle up to ab 900Mhz. The highest OTA channel is like ~804Mhz, so it should work. You may get into trouble with the splitter and need an amp. That takes electrical power. Something to keep in mind. |
#59
![]() No doubt about you saying the OTA working just fine because mine also works perfectly even though it's not in the attic.
#60
I started this post and then something happened. New thread coming. |
#61
. I guess I have to wait for the station to come back on line, then run another scan to get all the above. I just wanted to follow up on this for you. Oh, the fav lists are nameable after all. I'm still waiting to see which providers are going to pick up TWC and if they will charge more for it, and if so by how much. I'm not up to date on this, just a personal desire. |
#62
Guess what...
Grif? Did you ever solve the question of the day? |
#64
NFLX just knocked the cover off the ball w/ this Towering Home RUN!!
One thing fur sure... never bet against a competent manager like Reed Hasting.. DAMN!!
#65
![]() Now they need to renew A&E |
#66
They did well with this deal, but after watching what happened with the Qwikster debacle my confidence in their competency is definitely shaken.
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium // ![]() E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. . |
#67
I haven't gotten the chance to check if I have access to cable box yet... that's the first question that needs to be answered.
#68
#69
I have a question for you guys
How many hours a day or a week do you guys spend watching tv?
Netflix has too much market share already to decline any time soon... Hulu etc. may be trying to chip away at them, but I don't see it happening. Netflix will become outdated when and if a competitor offers superior selection and service at better prices.
#71
Haha!! Dude!! You are a Geniues!!
#72
60 mins.. mostly news program..
#73
#74
Pardon me.. 14 weeks a year I watch College Football on saturdays for 15 hours.
