E36 (1991 - 1999)
Old 10-03-2012, 02:06 PM
Riverasam1 Riverasam1 is offline
Mein Auto: 1998 328i
1998 328i PA6GF50
Hi everyone I'm new to this forum and new some help. I just purchased a 1998 BMW 328i coupe. Ever since I bought this car I kept hearing a beeping sound from under the steering wheel. Thought it was the seatbelt warming but it's not. I took panel out and found it was a black plug with a small speaker labeled PA6GF50. And I was wondering of anyone knows what this is for? I tried google and yahoo search but nothing pops up. Would really appreciate the help. Thanks
Old 10-03-2012, 02:12 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
How many times does it beep?
The Evolution of a Lady
“This is the fast lane, folks...and some of us like it here.”
--Hunter S. Thompson
Member of the Non-M Bumper By Choice Club
Old 10-03-2012, 02:56 PM
It constantly beeps even when the car is off and no key in the ignition.
Old 10-03-2012, 03:40 PM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i Hellrot Red
Is this part of the memo function?
Patrick ///98 328i hellrot///BMWCCA#465139
Old 10-03-2012, 03:42 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
Door chime is my bet.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by EnserioJose View Post
Sorry. I'd imagine Seattle is a-hella-nother country.
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 10-03-2012, 04:32 PM
still learnin'
Forget what that sounds like... Mines disconnected.
Old 10-03-2012, 07:20 PM
Memo function??? This my 1st Bimmer. Wat I did was cut wire to speaker so I don't have to hear that annoying sound
Old 10-03-2012, 09:11 PM
CoolStanceBro's Avatar
CoolStanceBro CoolStanceBro is offline
I6 feels good
Mein Auto: 97/4/5 Cosmos
You don't cut anything just unplug the speaker...
97 M3, KW V2 C/O, shark injected, SS Headers, AA Exhaust, Apex Arc8s, Daily Driven, POS, Slammed!
Old 10-03-2012, 09:17 PM
Gooby's Avatar
Gooby Gooby is online now
Kebab Lord / Sexy Sax Man
Mein Auto: 1995 M3
I'm gonna guess aftermarket alarm...
Sounds like you have an after market alarm system. Normally a factory alarm will not have a shock sensor. Its probably the shock sensor causing the constant beeping. If you think this is the case you can normally find the shock sensor under the drivers side dash secured to the steering column. It will probably have a light inside that comes on when it detects vibration. There will be an adjustment to make it more or less sensitive. Hope this helps.
http://www.fixya.com/support/t309228...nstantly_03_z4
Old 10-07-2012, 07:39 PM
I disconnected e speaker wire not the plug. Alarm is original BMW not aftermarket
Old 12-01-2012, 02:18 PM
E36 Dash lights
Hi everyone I have a 1998 328I E36 coupe and my light from the dash wont turn on. all fuses are working.. can someone help me. tnx
Old 12-01-2012, 07:16 PM
jonesin's Avatar
The Canadian Prick.
Is it (the cluster) fully plugged in?
Old 12-04-2012, 02:56 PM
It's fully plugged in. All the gauge lights are not illuminating, A/C , heater buttons (only in green not orange) the lighter
Or the back trunk not turning on.
Old 12-04-2012, 07:32 PM
jonesin's Avatar
The Canadian Prick.
Try taking your pictures again. But in focus please. Lets us see more clearly the issue. Pun not intended.
Old 12-04-2012, 08:01 PM
http://m48.photobucket.com/albums/jose160/bmw/ let me kno if these help.
Old 12-04-2012, 09:48 PM
jonesin's Avatar
The Canadian Prick.
Check fuses 23, 27, 31, and 46. They affect your instrument cluster.
Also possible that you just have a buttload of light bulbs blown in your cluster and center console.
Old 12-04-2012, 10:35 PM
All fuses are good and tested
Old 12-17-2012, 06:36 AM
Can some please help me I've tried everything possible.. Nothing in orange is lighting up
Old 12-17-2012, 07:08 AM
jonesin's Avatar
The Canadian Prick.
Have you checked the bulbs?
How did you test the fuses?
How does the light switch 'feel' when you turn it 2 clicks right?
Old 12-17-2012, 07:24 AM
Yes bulbs are good. Tested all fuses with tester. And yes 2 clicks. I checked light switch plug all have power going thru. Except one which is or ground.
:3
