E36 (1991 - 1999)
Old 12-04-2012, 11:18 PM
rufus2004 rufus2004 is offline
Mein Auto: 2000 740IL
1997 328ic Door Panel Repair
Thanks for all of the replies to my original post. You have all made it WAAAY to complicated! I do not need to re-upholster the panel, it is in excellent condition. I simply need to remove the insert, apply new glue, and attach it to the main part of the door panel. It appears that it is held on at a single point, but I can't tell if it is a screw, clip, or whatever. Hope somebody reads his and has made this repair before. Thanks again.
Old 12-04-2012, 11:49 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
The insert is glued onto the larger panel.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 12-05-2012, 01:08 AM
1997 328ic Door Pasnel Repair
Hi jonesin. I know it is glued to the larger panel, but how do I remove it from the larger panel so that I can re-glue it, what holds it on besides glue?
Old 12-05-2012, 01:42 AM
lynchard lynchard is offline
Mein Auto: 2008 BMW 325
I think this is also a good.
Old 12-05-2012, 01:59 AM
hornhospital's Avatar
D'oh, You Kids!
Nothing holds the insert to the panel except glue.
Quotes to live by:
Old 12-06-2012, 11:39 AM
Thanks for the input on the door panel repair. I've decided not to try to reglue. It only needs it on the end of the insert, The "treatment might be worse than the disease". Could be that the original glue needs high heat to adhere, anyway, not going to chance it.
Old 12-06-2012, 11:42 AM
jonesin's Avatar
The Canadian Prick.
That isn't the issue with 'repairing door panels' The issue is when the fabric itself peels away from the backing. Simply regluing the inner to the outer is easy.
