Old 12-04-2012, 06:35 AM
HudaBmw HudaBmw is offline
Mein Auto: 2005 Bmw 325Xi
Automatic Reverse Side Mirror
Hello,
I have a 2005 Bmw325xi, manual and when I put it in reverse the right side mirror dips low so I can see the curb lines. A good feature but does anyone know how to control how much it automatically goes down? Right now I think its going dipping slightly more lower than what I woould I like.
Old 12-04-2012, 06:46 AM
j_schroeder's Avatar
j_schroeder j_schroeder is offline
Mein Auto: 330ci
I don't think you can adjust it but if you slide the switch to the right to adjust the passenger mirror it will disable the auto lower feature
2001 330CI
Old 12-04-2012, 06:48 AM
Ye thanks. thats what I found out too. Thats fine but I was just trying to control the lowering.
Boss I noticed you are in Michigan, I am out in Toronto. I heard parts/tires/rims are cheaper in the state side, Any truth to this?
Old 12-04-2012, 08:29 AM
E46_Ci E46_Ci is offline
Mein Auto: 2005 325Ci + ZPP/ZSP/ZCW
You can adjust the angle... but the car has to be programmed at the dealer to open this up... I had mine coded and it works like this:
Place the mirror control in the right side position, put in reverse and adjust where you want the mirror to be when in reverse... then place mirror control in the left side position. Now the mirror will dip to your set position.
This will not work if your car is not coded for this.
Alpinweiß 2005 325Ci
Spacegrau 2007 X5 3.0Si
Old 12-04-2012, 10:29 AM
Interesting feature, the ability to code the stopping position.
I wonder if it can be coded at home as a DIY?
- Where to find INPA, EDIABAS, NCS Expert, DIS, EasyDIS, Progman, & other BMW factory & dealer programming, coding, and diagnostic tools (1)
Old 12-04-2012, 11:52 AM
Mein Auto: 330ci
I'm not sure if they're cheaper or not but I paid $575 for 4 Toyo extensa hps w/ installation.
2001 330CI
Old 12-04-2012, 12:47 PM
TRIPLE_O TRIPLE_O is offline
OOO
Mein Auto: Coupe
It can be coded with NCS.
Old 12-04-2012, 01:48 PM
Fast Bob's Avatar
Keeping it surreal
Ummmm....the subject of this thread is how to program your mirrors....
The road goes ever onward....
(R.I.P. Jever)
*Please support the Wounded Warrior Project*
Old 12-04-2012, 05:38 PM
Mein Auto: 330ci
[QUOTE
Boss I noticed you are in Michigan, I am out in Toronto. I heard parts/tires/rims are cheaper in the state side, Any truth to this?[/QUOTE]
He asked me a question and I gave him an answer.
2001 330CI
Old 12-04-2012, 11:53 PM
Thanks!
Old 12-05-2012, 08:15 PM
OOO
Mein Auto: Coupe
The value is MEMORY_SPIEGELABKLAPPEN located in the BTM module for the E46.
