318i misfire @4500rpm - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 11-27-2012, 04:02 PM
92_318i 92_318i is offline
Mein Auto: 92 BMW 318i Sedan
Now that I've got the electrical issue taken care of, I took the car out for a test drive.
Ran through 2nd at WOT, and noticed a repeatable miss right around 4500-5000 rpm.
Seems almost as if the car is hitting a rev limiter of sorts.
If I back off the loud pedal a bit, I can get it past the miss and all the way to redline just fine
My best guess is a lack of a signal from the O2 sensor, as I still have to wire it up.
Anybody else got any better ideas? Plugs are new, seems to be running rich, so not a fuel problem...
Old 11-27-2012, 04:32 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Running rich is a fuel problem.
1998 BMW 328is
1966 Pontiac GTO
Old 11-27-2012, 04:47 PM
Yes however, it wouldn't cause a miss like what I'm getting. Running lean might, but not running rich.
Old 11-27-2012, 04:50 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
~4500 is right at when the DISA valve swings over in the manifold, changing the intake runner length. Maybe not moving as it should?
And a rich condition can't cause a miss? Since when?
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 11-27-2012, 06:30 PM
Can't cause a miss like what I'm getting
A Misfire caused by a rich condition is different than one caused by a lean condition.
I will check into the DISA valve.
Old 11-27-2012, 06:39 PM
D'oh, You Kids!
By your own admission (1) it's missing, and (2) it's running rich. Tell me how you determined it can't be the fault of running rich. Explain how a lean miss differs from a rich miss. Missing is missing. Since it's running rich, it at minimum contributes to the miss.
Quotes to live by:
BMW-CCA #441426
Old 11-27-2012, 07:41 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
ken, it's running ricch, so the fuel isn't missing....get it?? huh?? huh?? huh??
did i make teh funniez???
meds have worn off, so, brb, k??
don't go anywhere....
df
Old 11-27-2012, 10:04 PM
D'oh, You Kids!
David, you made me lol!
Sent from my MB860 using Bimmer App
Quotes to live by:
BMW-CCA #441426
Old 11-27-2012, 11:32 PM
while I agree, running rich is a fuel problem, what I meant was fuel [I]delivery[I] is not an issue... filter is new, injectors were recently cleaned, and certainly arent clogged, etc.
I'm asking if the ECU will cut fuel at a certain point, at WOT, if it is not seeing a signal from the O2 sensor
It feels as though the ECU is cutting off fuel right at 4500RPM.
My summer car is a Lincoln LS, notorious for faulty ignition coils (first gen cars go through them almost a set a year), so I am well versed in misfires. But this feels more like a rev limiter to me.
Old 11-28-2012, 02:52 AM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
I'd check out that DISA valve. I had a similar problem with my m44.
When the cable opened it Caused a vacuum leak thus producing a misfire.
Have you tested the coil pack?
What type of fuel are you using? Higher compression due to carbon build up can do this as well. High grade fuel could help, but seafoam to remove carbon would be better.
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 11-28-2012, 05:53 AM
It gets only 93 from various stations. I will seafoam it later today.
I will also look at the DISA valve.
Old 11-28-2012, 06:55 AM
D'oh, You Kids!
It feels as though the ECU is cutting off fuel right at 4500.
Short answer: no. It can adjust fuel trim/ mapping overall, but it cannot cut fuel abruptly enough to cause a miss like you describe.
Quotes to live by:
BMW-CCA #441426
Old 12-05-2012, 08:55 PM
Ok so I took care of the rich problem, rewired the O2 sensor, and
Rewelded part of the exhaust. Car runs much better, but still misses @4500rpm.
I'm going to try running it with the DISA valve connector disconnected.
Old 12-06-2012, 05:08 AM
Bimmer1995318ti's Avatar
Bimmer1995318ti Bimmer1995318ti is offline
Mein Auto: 1995 bimmer 318ti
I suspect an Ecu problem, maybe when you were fixing the wiring something crossed and caused a disruption in the code possibly. I have a 318 as well and 4500 is when max hp is reached so I suspect your computer is confusing your max hp gain with your redline
Old 12-06-2012, 05:13 AM
When you shift at red line, your gearing and Ecu is set to bring you back to max hp (4500 rpm) so either a sensor is sending the wrong message to your Ecu regarding rpm or your Ecu is completely screwing that one up
Old 12-06-2012, 06:42 AM
still learnin'
The DISA valve opens up around 4,200 to 4,500 RPMs... the valve could be malfunctioning.
99 540i TiAg
