E46 (1999 - 2006)
Old 12-02-2012, 02:37 PM
carl4 carl4 is offline
Mein Auto: 2002, 325XI
Help So it was not the CCV or Oil seperator.
Actually it was the oil separator only problem is that now that it has changed some weird stuff started happening.
I drive a 2002 325XI 215,000KM or 134,000 miles. Recently I noticed I was using an excessive amount of oil. Did some investigation and decided to change the oil separator as a potential solution to the oil problem.
It took 3 days to get it changed. Don't ask me why?
However since the change it has not been running the way it did prior to changing the CCV.
The car is running rough when left to idle too long. It will start as normal run smoothly then the oil light will come on briefly then it start missing or sputtering and can not attain speeds above 50 km per hour.. If I pullover shut off the car and re-start. It will run smoothly again until I reach a stoplight, then the car has to idle for a while. The oil light will come on, then go off, start running rough, then start sputtering or missing and i either have to pullover shut off and restart for it to run smoothly or drive at 50km per hr regardless of how much gas I give her.
To me it feels like a couple of cylinders may not be firing when this happening. Anyone have an idea what could be the problem?
Old 12-02-2012, 02:40 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Codes ???
The road goes ever onward....
(R.I.P. Jever)
Old 12-02-2012, 03:06 PM
Actually I don't know. This might sound silly but how do I get those. Do I need a scanner or do I peel back the floor mat and their will be a light flashing. This is my first BMW and only own it for 4 months.
Old 12-02-2012, 04:56 PM
Fast Bob's Avatar
Keeping it surreal
There`s a small trap door in the underside of the dash, just below the steering column. Pop it open, and pull the umbilical cord out....now, plug that cord into an OBD II scanner.
(R.I.P. Jever)
Old 12-02-2012, 06:08 PM
Thanks, I will do that. MY buddy has a scanner or I can go to a local auto-parts store and get it scanned.
Old 12-02-2012, 07:02 PM
Oh one thing though they are no chk engine light on, so I don't think they are any codes to download.
Old 12-03-2012, 07:42 AM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
The car will often store codes even if there is no warning light on, particularly if its running as poorly as you describe. Still worth scanning ...
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 12-03-2012, 08:06 AM
how do I get those
- Cheapest CAN OBDII scanner on the net that reads DTCs, pending codes, & clears codes
+1. The car will store pending codes a couple of time before it triggers the yellow warning light.
Old 12-03-2012, 10:58 AM
MyLife MyLife is offline
Mein Auto: 1999 - 323i
Carl4, I feel your pain. I had the same problem (long story) and took it to the Indy last week and he temporarily swap the MAF and changed the sparkplugs (although I changed the Plugs, oil separator and the valve cover gasket in less than a year ago - I did these because of the same symptoms I had months ago - did flash the computer (DME?)as well). He asked me to buy the part and returned his when I replaced mine (I am grateful for that). These seem to stop the bleeding for time being but I am experiencing a lot of gas consumption (I used to get 19.3 avg city now only (14.6). The car feels/sounds like it is on "overdrive". I will take it back again next weekend.
Old 12-03-2012, 12:53 PM
Fast Bob's Avatar
Keeping it surreal
Originally Posted by MyLife View Post
). The car feels/sounds like it is on "overdrive". .
You mean the engine is running slower than normal ?
(R.I.P. Jever)
Old 12-03-2012, 02:05 PM
Yes and it feels like it is in differnt gear than it should be (323 auto). I used the term "overdrive" because of my old car that used to have a button for overdrive and used it when it snows (lower gear?).
Old 12-06-2012, 08:18 AM
Funny you would say that about fuel consumption. Cuz I do feel like I am using more gas than usual. I thought about changing the MAF but have not got around to doing it yet.
I just want to make sure all was done correctly with changing the oil separator so the guy is going to re-check.
He also confirmed that cylinders 2 and 4 are misfiring but that has not brought us any closer to a solution.
Let me know what happens when you take it back.
