7 Series - F01 (2009 - current)
The new re-designed 7 series leads off the BMW Fxx chassis code! |
premium gas?
How important is it to use premium in my 2011 750i?
Follow the owner's manual
If you want the car to develop the advertised HP, yes. If you don't care, then no problem, fill it up with whatever you like.
Its been sorta covered on the F30/F10 forums after Sandy. You can use 87 but it'll retard the timing, and can give you worse gas mileage. So you're at a draw, if you're trying to save money (on a 100k car
) just go with mid grade.
![]() 2013 BMW 750 - Coded, Executive, Lighting, Cold Weather, M Sport, M 303 Wheels, 5% Tint, Conti DWS Tires, 3M Bra, Front DE Plate, Vinyl Black Gloss Roof Wrap. |
If you want to save money, buy Costco premium. It is the same price as regular anywhere else, and contains 5 times more cleaning additives than EPA recommendation.
09 750i, 06 330Ci, 03 MDX, 08 535i (Sold), 73 Piper Cherokee (sold), 82 Yamaha 750 (sold) Too many Audis, Mercedes-Benzes, and Lexuses to mention. |
I've never put cheap gas in my car, it's always Chevron and premium which doesn't contain ethanol.
And the car show "Fifth Gear" did a octane test and they found that higher octane does give you better mileage and performance but not all premium gas is the same which was interesting.
2011 750i |
I reported a 2mpg increase when I went from cheap gas to quality premium. Also, throttle response was a bit better. This is on an ancient E36, so it can only make wonders for your new 7
![]() RIP Ben "Jever" Doebele, we wont forget you Hi, I'm Chad. Talk to me or GFY ![]() 1997 328iS... HR coilovers, Brembo F40 calipers, camber plates, so many more cool things! 1993 Chevy K3500 CUMMINS 6BT 5 speed with 19.5" commercial grade wheels. Pulling 15k pounds going 75mph up a 7% grade... cake
My first "high end car" was a new 1999 C280 Sport, and Beverly Hills Mercedes told me to only use Chevron Supreme. In 2004, when I made the switch from Mercedes to BMW, Century West BMW told me to only use Chevron Supreme. I had used it almost exclusively since my 1995 SAAB, but would switch now and then. Since 1999....I stick with Chevron. I believe if you do Google searches, Chevron usually rates the highest. I just like it, and most Chevron stations in L.A., have the most maintained pumps and gas stations. And if you add the savings up from switching to 89 or 87...You probably save about $1 or $2 per tank of gas. Is that worth it to you?? You cannot even buy a cup of coffee for that!!
2013 Phantom Aviator Coupe, 2013 G63 AMG |
It's only Chervon or Shell 91 for me.
I too only use Chevron, Shell is my alternate if I cant find a Chevron. Its only a couple bucks more per tank for better gas. Wish we had 93 octane out here
Is Shell or Chevron "better" than a Valero, Phillips, or a generic gas station if the octane is the same rating? I imagine most of it is just marketing, but I'd love to know more about it.
I dont see much proof its better, other than the times Ive put cheap gas in my Jeep for a long period of time, then swapping to Chevron made the engine run smoother. These cars are expensive, why put cheap stuff in them? Last edited by ChrisF01; 12-04-2012 at 04:54 PM. |
I use Costco when Shell is not available. No difference in performance. Always use 91 octane, and add a bottle of Chevron injector cleaner (available at Costco) every 3K miles. Purrs like a charm.
Since they opened a Costco near where I live, I try to fill up when I go there. Costco in Chicago is at 93 octane and cheaper than regular gas from the nearby BP or Shell.
With regards to which brand gas station you go to, the reality is that most people will not be able to tell where the gas in their gas station ultimately came from. For example, a BP station may not get gas delivered by BP and so on. |
For an engine with twin turbos, don't even think about using less than the OEM recommended octane. I know these engines have knock sensors and boost control, but if anything doesn't work correctly with crappy gas in the tank and you tromp on the gas a time or two, bad things can happen.
JMHO, Greg
Greg 2011 Alpina B7 ![]() 2005 Mini Cooper S with John Cooper Works Package From the past... 1999 Mercedes Benz E55 AMG (good riddance!) ![]() 1995 Ferrari F355 1987 Porsche 911 1983 BMW 533i 1980 Corvette ![]() 1973 Corvette ![]() 1974 Pantera L ![]() 1974 Datsun 260Z
I guess it wouldn't be a new month without someone asking if they could save $7 a month to help pay for their $100k car. By all means, put whatever you like in the tank if that is all you can afford. Your performance will be worse, you will lose gas mileage and you will risk engine damage, but at least you will only have to find the other $993 to make that payment.....
2012 650i convertible, titanium silver, vermillion red, M sport, IAS, ARS, premium sound w/B&O, cold weather, drive assistance, luxury seating, 20's, leather dash, ceramic controls, BMW apps. 2012 750IL x drive, imperial blue/oyster, a finely loaded beater car... 2010 Escalade ESV Platinum nuff said.... 2011 550ix (gone) |
i put super even in loaners
2012 750 AH 2010 E63 AMG 2008 SRT8 |
McD's coffee = $1 You have a good pt though. What would the difference be for a year? Maybe $120 avg.
Some people just won't listen to some simple facts.
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein Swim upstream. Go the other way. Ignore the conventional wisdom. If everybody is doing it one way, there’s a good chance you can find your niche by going exactly in the opposite direction", Sam Walton. |
Dunno about you, but, for some strange reason, I've been getting over 1,500 miles on every fillup of 87AKI at Costco!
![]() Plus I get (slightly) better emissions results: See also: - What is the true cost differential between 87 & 91 octane AKI (1) & all you need to know about engine fuel & octane (1) & The Gasoline FAQ & top-tier gas stations (1) & what gasoline to use in a bimmer (1) & how much gas should be left to cool the fuel pump (1) & how to siphon the fuel out of the tank (1) & does spilled gasoline go into the charcoal canister (1) & the P0455 diagnostic trouble code when the gas cap is missing (1) & the truth about mpg calculation accuracy (1) (2)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
#25
I am not sure what your point is. You drive over a decade old non turbo car. We drive a twin turbo with a 450 HP powerplant. None of us is interested in keeping this car for 100K miles. We just want the driving pleasure and sweet purr of our V8. If we wanted fuel economy, we would be driving a Prius!
