Old 12-06-2012, 12:28 PM
How does the BMW E39 adapt to high altitudes when you go from sea level to 6000 feet?
This thread today, where a user went from a low altitude warm area to a high altitude cold area, got me wondering how the E39 adapts to altitude when it comes to engine control adjustments:
Originally Posted by kross1300 View Post
I recently moved from San Diego to Breckenridge, CO and I have been having some trouble with how my car runs!
I've noticed in the past when I drove from San Jose (about 100' ASL) to Tahoe (around 6,000' ASL), my car used to stumble more so than I thought it should (but I've since replaced all the hoses due to a vacuum leak in the throttle boot and CCV lower vent hose and air pump vent hose).
To better understand how the bimmer adapts to altitude, I ask the general question:
Q: What does our E39 do differently at altitude than at sea level?
Old 12-06-2012, 12:34 PM
Flybot's Avatar
Flybot Flybot is offline
Mein Auto: '98 528
In a nut shell, thats what your O2 sensors and MAF sensors are for. They are constantly measuring the air intake and sniffing the exhaust mixture for the proper fuel air ratio which will properly compensate for temperature and pressure. In the old days with carburetors, if you were going on a trip to the mountains, you would turn the mixture screws in a half turn to lean the carbs out a bit. Then undo do it when you got back.
Old 12-06-2012, 12:45 PM
540iman's Avatar
540iman 540iman is offline
resident, old fart
Mein Auto: 2002 540i sport
Bee-when warm, any car is in closed loop mode so the maf is measuring air passing maf and sending an anticipated fuel injector spray duration period to the ECU. Then, the pre-cat O2 sensor has the final word and determines how well the ECU did based upon Maf signal. The leaner air at higher altitudes will tell the O2 that car is running rich cause there isn't enough air to support your adaptation values for normal operation. ECU will start to change the adaptation values to take fuel injector pulse duration down to make the O2 sensor happier with less gas to match the lessor air. The car does not know how long you are going to be in the higher altitude, so it may not make a full adaptation for the height above sea level in one trip. If you moved to higher altitude permanently, it would change your whole table and then your car would run lean at sea level until adaptation values got used to being at sea level and getting more air and lengthen the fuel injector pulse time. Make sense?
Old 12-06-2012, 12:46 PM
Kamdog's Avatar
Kamdog Kamdog is offline
<- met in Rome, named Mo
Mein Auto: 2008 535i
Normally aspirated cars lose power at altitude because the air is thinner. Turbos make up a huge difference the higher up you go.
535i, Monaco, Cream, Light Poplar, Comfort Seats, PP, Nav, ED.
Old 12-06-2012, 01:06 PM
AnotherGeezer's Avatar
Entwicklung 39
Mein Auto: 2003 530i/5
Mine has been known to ask for a hoodie, a floppy wool cap, and some furry gloves.
Old 12-06-2012, 02:30 PM
mbell666 mbell666 is offline
Mein Auto: e39 2002 540i6
The key thing is that the MAF (Mass Air Flow Sensor) reads the Mass of air entering the engine, so the signal it gives to the ECU already account of change in air density due to the altitude. The higher up you go the less air mass the MAF will signal to the ECU, so the less fuel the ECU will inject. The O2 sensors of course send fine tune to the ECU to adjust the air/fuel mixture which adjusts the short term fuel mixture adjustment, which over time adjusts the long term fuel adjusts.
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but you’d never be without it.
Old 12-06-2012, 03:22 PM
540iman's Avatar
resident, old fart
Does your BMW have a turbo? How does this remotely answer the question?
Old 12-06-2012, 09:53 PM
Bandem Bandem is offline
Mein Auto: BMW
Any Naturally Aspirated engine will lose noticeable power as you increase altitude (in my experience). Air gets thinner, oxygen is more scarce. Same effect as with temperature, the hotter the weather, the more power you lose due to thinner air. Although you may accelerate easier at really high speeds due to less resistance (not sure on that one).
According to information online, at 6000feet, air pressure is at 11.1 PSI, which is is a 25% drop. I'd say that you would experience pretty significant and noticeable power losses.
Old 12-07-2012, 07:57 AM
540iman's Avatar
resident, old fart
A turbo or supercharged car can combat the lack of oxygen as it can generate more boost than the turbo can use and the pop-off valve will actually release some of the oxygen back, but even F.I. cars will suffer some loss of power.
Old 12-07-2012, 10:24 AM
manticore33's Avatar
manticore33 manticore33 is offline
Send a message via AIM to manticore33
Mein Auto: '86 Porsche 951, '01 530i
Your whit charms me immensely.
I like coffee.
My e39 is fixed and moving towards atrophy.
Old 12-07-2012, 10:58 AM
540iman's Avatar
resident, old fart
Can I ask you something kinda personal? When BMW Mtech'd your rear....well, did it hurt?
Old 12-07-2012, 11:50 AM
BigCo540i's Avatar
BigCo540i BigCo540i is offline
The Usual Suspect
Mein Auto: '12 X6 50i
"Originally Posted by kross1300 View Post
I would be pissed too, if somebody made me move from sunny SD to Colorado!
Old 12-07-2012, 11:59 AM
Nline6's Avatar
Nline6 Nline6 is offline
Slip slidin around town
Mein Auto: E36 M3
regardless, with lower o2 content in the air due to higher altitude the engine operates less efficiently. It can compensate all it wants, less oxygen means less boom
Old 12-07-2012, 12:09 PM
Entwicklung 39
I forgot to mention the fuzzy slippers.
Must haz fuzzy slippers.
Old 12-07-2012, 03:21 PM
540iman's Avatar
resident, old fart
Colorado has more sunny days than CA. truth. CO. is as close to CA. as you can get which is why they call CO. "little California". Same freeky laws and politicians. I lived in both states and I'll take CO. ANYTIME! Colorado weather is awesome.
Old 12-07-2012, 11:07 PM
BigCo540i's Avatar
The Usual Suspect
Lol ya.
Old 12-08-2012, 03:32 AM
Sumotide17 Sumotide17 is offline
Mein Auto: 2001 540I/6 Sport
His though process is correct and I'm sure he did not know that the ECU would compensate thereby suggesting the use of a turbo which will increase atmospheric pressure. The decrease in atmospheric pressure between SD and CO can and will be compensated overtime via the ECU.
At least he was contributing and not being a jerk off! What did you contribute to this thread? Absolutely nothing. FYI: No matter where you go in our atmosphere the gas mixture is the same... Depending on your altitude only the PRESSURE will change.
Maybe you should spend some time in college instead of the auto garage? Just Saying you might want to give it a thought.
Can I ask you something kinda personal? When BMW Mtech'd your rear....well, did it hurt? :
This is just immature. Grow up!
Old 12-08-2012, 09:02 AM
540iman's Avatar
resident, old fart
Your statements are just not true, but it's not worth arguing with you. Oh, btw...I got my MBA in 2007 at age 53. When did you get yours?
Old 12-08-2012, 09:33 AM
ND40oz ND40oz is offline
Mein Auto: 09 135i
Who calls Colorado "Little California"? Not sure what freaky laws we have either...
OP, try driving to the top of Pikes Peak or Mount Evans, that's when you'll really notice you're down on power. Never had an issue with any of my vehicles ecus not adapting to the changes in elevation though, so if your car is stumbling, somethings not right. High reving NA vehicles aren't exactly the best for compensating for the altitude though, you'll find you need to keep the revs higher then at sea level and in a lower gear to make up for the loss in power.
17 Volvo XC90 T6 Inscription P* (OSD 7/16)
15 BMW 328d xDrive Sports Wagon M Sport
15 Audi SQ5 Prestige
13 Honda Insight EX
Old 12-08-2012, 06:25 PM
Have you seen the hands of god? If so, it explains everything.
I like coffee.
Old 12-08-2012, 06:38 PM
540iman's Avatar
resident, old fart
I haven't seen him in awhile, but I do talk to him on a regular basis. Was not aware he was
still doing that procedure. If you happen to see God in the near future, will you see if he is still pissed at me?
Old 12-09-2012, 03:38 AM
fullthrottle540's Avatar
fullthrottle540 fullthrottle540 is offline
DINAN 5
Mein Auto: E39
he's just making a general point... the OP asked how does altitude affect motors, he's saying turbo cars do better at altitude than N/A cars, which is true.... don't hate
Old 05-04-2013, 11:40 PM
This information, added today, is apropos to this thread:
I think EDJACK and FUDMAN have it right regards engine performance. Engine sensors, particularly the MAF (mass air flow) and O2 sensors, compensate for changes in atmospheric parameters. FWIW, carbureted engines were/are an entirely different matter - 5,000 of altitude would definitely require re-jetting to maintain best performance. And depending on engine and carb, best at altitude may be a far cry from sea level.
Temperature ranges are primarily an oil issue, i.e. is the oil in the engine suited to the ambient? If you use BMW LL-01 certified oil you will be fine. The owners manual says approved oils in 5W-40 or 5W-30 viscosities "may be used for driving in all ambient temperatures."
If you are in below freezing temps for a prolonged period beware of potential CCV problems. Check Best Links for the story. Bottom line: avoid a steady diet of short trips that can build up sludge in the CCV or install the cold weather version of the CCV.
My 2003 530 takes ~10 minutes driving (not idling) to reach normal coolant temp in -25C, -13F. I've no indication of engine problems using LL-01 synthetic.
Maximum power depends on the mass of air that can be drawn into the cylinders. At 5,000 ft air density is ~83% of sea level. So maximum power would be about 83% of sea level. This corresponds pretty well with the rule of thumb that max power is reduced 3% for every 1,000 of altitude on normally asperated engines, which ours are. So, WOT throttle acceleration will be a little less than at sea level.
Highway gas mileage should improve. Aerodynamic drag accounts for ~80% of the power requirement at highway speeds. Drag is proportional to density. So a 15% reduction in density should result in a noticeable improvement in MPG. City driving MPG is primarily a function of tire rolling resistance and energy wasted on stops. Neither of these vary with altitude; city MPG should be the same as sea level.
Note though, as discussed in other threads, MPG depends on so many factors that any change compared to your current driving patterns and routes may be difficult to detect.
Your car, like mine, has an open (not limited slip) differential. This is good while moving; loss of traction on one driven tire does not transfer all torque to the other tire and jerk the car sideways - especially if accelerating at the instant. Not so good if stopped and one tire is spinning on slippery stuff, in which case you get none or almost no torque on the other tire. This is called being stuck.
But your chains will solve that problem, if anything can.
Regards tires.
There is so much difference in wet, snow and ice performace between tires, even within the same performace group, that your experience will depend entirely on what you are now running. Search for tests, surveys and reviews at Tire Rack
http://www.tirerack.com/index.jsp
for an estimate of how your tires will perform.
My personal opinion is that driver experience and skill with ice and snow are as important as the tires. Some drivers can't stay in their lane with snow tires in 2 inches of the white stuff. Others manage just fine with all season or even summer tires in 10 inches. Of course if you want maximum performance and safety in snowy conditions, dedicated snow tires are the way to go.
Best of luck in Colorado. Your biggest challenge may be keeping your eyes on the road - the scenery is stunning.
See also:
- How does the BMW E39 fuel trim behave at high elevation (1) (2) (3) & where is the BMW E39 altitude pressure sensor (APS) (1)
Old 05-05-2013, 01:07 AM
Itinj6's Avatar
Itinj6 Itinj6 is offline
Mein Auto: 2012 650i Convertible
Re: How does the BMW E39 adapt to high altitudes when you go from sea level to 6000 f
Altitude alone doesn't determine engine performance... nor does pressure or temperature.
The term is "DENSITY ALTITUDE" ... for all you aviation fans. It is possible to be at 6'000' and still perform as if you were at a lower altitude. Same holds true for the opposite.
Here is a calculator in case anyone is interested. Pretty straight forward. "Altimeter Setting" is your local atmospheric pressure (29.92 in. Hg is standard at sea level). You can get the required information from weather sources such as The Weather Channel.
http://wahiduddin.net/calc/calc_da.htm
Old 01-26-2014, 07:24 PM
gmak2012's Avatar
gmak2012 gmak2012 is offline
Mein Auto: E60:M5 530xi E39:540 528
The "LOAD" value is used by the DME (it shows up in INPA in the ANALOG 1 screen for the MS41.1). It is a calculated value that adjusts the air mass measure from the MAF (as a ratio of the table-stored MAXIUMUM air mass [at least I think it's table stored]. Here is the quote. It is taken from a Baum Tools document written with input from BMW. The ratio implies that if either the MAF or altitude sensor readings are wrong, then the DME will not adjust the fuel injectors properly - leading to running rich or running lean until it gets feedback from the O2 sensors and can adapt. However, if the error is big enough, the DME may not be able to adjust enough and the engine will mis-behave, IMHO. The ratio may not display correctly. It is [MAF / Max air mass] x [sea level pressure / current barometric pressure]
"When the engine operates at normal or higher load or at higher engine speeds, larger volumes of fuel and air are needed. In order to maintain a Lambda = 1 in these conditions, the ECU monitors the O2 sensor and calculated load (see figure 2) and compares the values against the optimal value for the fuel injection pulse width stored in the drive map. If this base fuel injection pulse width value does not yield a Lambda = 1 at the O2 sensor for the measured air mass, the computer increases or decreases the pulse width by a percentage (%) determined by the difference in Lambda from optimal. These percentages have been computed by the engineers at the factory from extensive dynamometer testing and are stored in a "weighted STFT value array1" in the drive maps.
Calculated Load = Current Air Mass X Atmospheric Pressure @ sea level
Maximum Air Mass Current Barometric Pressure
Figure. 2
When the STFT reaches the limit of its adjustment it will cause corresponding decrease or increase to the Long Term Fuel Trim. If the correction to the base value exceeds +25% or -25% for longer than 10 seconds a DTC is set for rich or lean stop for STFT."
Last edited by gmak2012; 01-26-2014 at 07:29 PM. Reason: ratio not displaying correctly
air metering, altitude, ccv, diagnostic repair, dme, engine management, icv, maf
