How does the BMW E39 adapt to high altitudes when you go from sea level to 6000 feet?
This thread today, where a user went from a low altitude warm area to a high altitude cold area, got me wondering how the E39 adapts to altitude when it comes to engine control adjustments:
To better understand how the bimmer adapts to altitude, I ask the general question: Q: What does our E39 do differently at altitude than at sea level?
In a nut shell, thats what your O2 sensors and MAF sensors are for. They are constantly measuring the air intake and sniffing the exhaust mixture for the proper fuel air ratio which will properly compensate for temperature and pressure. In the old days with carburetors, if you were going on a trip to the mountains, you would turn the mixture screws in a half turn to lean the carbs out a bit. Then undo do it when you got back.
Bee-when warm, any car is in closed loop mode so the maf is measuring air passing maf and sending an anticipated fuel injector spray duration period to the ECU. Then, the pre-cat O2 sensor has the final word and determines how well the ECU did based upon Maf signal. The leaner air at higher altitudes will tell the O2 that car is running rich cause there isn't enough air to support your adaptation values for normal operation. ECU will start to change the adaptation values to take fuel injector pulse duration down to make the O2 sensor happier with less gas to match the lessor air. The car does not know how long you are going to be in the higher altitude, so it may not make a full adaptation for the height above sea level in one trip. If you moved to higher altitude permanently, it would change your whole table and then your car would run lean at sea level until adaptation values got used to being at sea level and getting more air and lengthen the fuel injector pulse time. Make sense?
Normally aspirated cars lose power at altitude because the air is thinner. Turbos make up a huge difference the higher up you go.
535i, Monaco, Cream, Light Poplar, Comfort Seats, PP, Nav, ED. |
Mine has been known to ask for a hoodie, a floppy wool cap, and some furry gloves.
The key thing is that the MAF (Mass Air Flow Sensor) reads the Mass of air entering the engine, so the signal it gives to the ECU already account of change in air density due to the altitude. The higher up you go the less air mass the MAF will signal to the ECU, so the less fuel the ECU will inject. The O2 sensors of course send fine tune to the ECU to adjust the air/fuel mixture which adjusts the short term fuel mixture adjustment, which over time adjusts the long term fuel adjusts.
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but you’d never be without it. |
Any Naturally Aspirated engine will lose noticeable power as you increase altitude (in my experience). Air gets thinner, oxygen is more scarce. Same effect as with temperature, the hotter the weather, the more power you lose due to thinner air. Although you may accelerate easier at really high speeds due to less resistance (not sure on that one).
According to information online, at 6000feet, air pressure is at 11.1 PSI, which is is a 25% drop. I'd say that you would experience pretty significant and noticeable power losses. |
A turbo or supercharged car can combat the lack of oxygen as it can generate more boost than the turbo can use and the pop-off valve will actually release some of the oxygen back, but even F.I. cars will suffer some loss of power.
I like coffee. ![]() My e39 is fixed and moving towards atrophy. |
Can I ask you something kinda personal? When BMW Mtech'd your rear....well, did it hurt?
"Originally Posted by kross1300 View Post
I recently moved from San Diego to Breckenridge, CO and I have been having some trouble with how my car runs! I would be pissed too, if somebody made me move from sunny SD to Colorado!
regardless, with lower o2 content in the air due to higher altitude the engine operates less efficiently. It can compensate all it wants, less oxygen means less boom
![]() Touring the nation, one state at a time |
I forgot to mention the fuzzy slippers.
Must haz fuzzy slippers.
Colorado has more sunny days than CA. truth. CO. is as close to CA. as you can get which is why they call CO. "little California". Same freeky laws and politicians. I lived in both states and I'll take CO. ANYTIME! Colorado weather is awesome.
Lol ya.
At least he was contributing and not being a jerk off! What did you contribute to this thread? Absolutely nothing. FYI: No matter where you go in our atmosphere the gas mixture is the same... Depending on your altitude only the PRESSURE will change. Maybe you should spend some time in college instead of the auto garage? Just Saying you might want to give it a thought. This is just immature. Grow up! |
Your statements are just not true, but it's not worth arguing with you. Oh, btw...I got my MBA in 2007 at age 53. When did you get yours?
OP, try driving to the top of Pikes Peak or Mount Evans, that's when you'll really notice you're down on power. Never had an issue with any of my vehicles ecus not adapting to the changes in elevation though, so if your car is stumbling, somethings not right. High reving NA vehicles aren't exactly the best for compensating for the altitude though, you'll find you need to keep the revs higher then at sea level and in a lower gear to make up for the loss in power.
09 135i 6MT, ZMP, PPK1 13 X5 35i ZMP, ZMX, 2VA 13 Tiguan SEL 4motion |
Have you seen the hands of god? If so, it explains everything.
still doing that procedure. If you happen to see God in the near future, will you see if he is still pissed at me? |
he's just making a general point... the OP asked how does altitude affect motors, he's saying turbo cars do better at altitude than N/A cars, which is true.... don't hate
This information, added today, is apropos to this thread:
- How does the BMW E39 fuel trim behave at high elevation (1) (2) (3) & where is the BMW E39 altitude pressure sensor (APS) (1)
Re: How does the BMW E39 adapt to high altitudes when you go from sea level to 6000 f
Altitude alone doesn't determine engine performance... nor does pressure or temperature.
The term is "DENSITY ALTITUDE" ... for all you aviation fans. It is possible to be at 6'000' and still perform as if you were at a lower altitude. Same holds true for the opposite. Here is a calculator in case anyone is interested. Pretty straight forward. "Altimeter Setting" is your local atmospheric pressure (29.92 in. Hg is standard at sea level). You can get the required information from weather sources such as The Weather Channel. http://wahiduddin.net/calc/calc_da.htm Last edited by Itinj6; 05-05-2013 at 12:14 AM. |
| Tags |
| air metering, altitude, ccv, diagnostic repair, dme, engine management, icv, maf |
