#26
Thanks. Actually, it turns my mechanic can do it. The confusion came when I was talking to somebody from his shop the person told me they don't do it and I have to go to the dealer...
In any case, I wish that was the only problem with the car... but this is already topic for another thread. Best, M |
#27
As a thought, maybe now is a good time to switch to the forum for your car being that it's not an E39, but just one question. How long have you owned this car and did you have at checked-out before you bought it? Is it your E39 that has the problem or the 6 series? maybe I misunderstood by the part you were looking at.. You are welcome anywhere, but this problem..it is with the 5 series E39 or the early 6 series? The module rebuild you were looking at ...well, I was not aware it fit all the cars you mentioned AND the E39??
#28
I think the OP has worse problems though, based on a new thread from him today: > E39 (1997 - 2003) > Internal leak I would fix the head gasket or cracked block before even touching the ABS.
#29
Best, M |
#30
Just don't make the mistake I made of going to the inspection station the day after repairing the ABS control module! - Failed smog due to bogus P0500 Vehicle Speed Sensor Malfunction after repairing ABS control module
#31
Should have cleared if you used a tool that would clear errors and not just read them.
#32
Plus, even if I had cleared it, I would still have had to wait for the FTP cycle to be completed, so that the monitors were filled (as California will fail you if too many monitors are not ready). So that's why I'm warning the OP (I don't want him to have to pay twice for two inspections, like I did, because of a bogus failure). Luckily, the bogus failure afforded me the opportunity to check emissions under two gasoline conditions (so I got 'something' out of my money paid for the bogus results):
#33
Wow, I did not know you had an ABS error with no lights whatsoever. I lived in Whittier for 5 years and don't really know of the FTP cycle you speak of. When I was living in California, you could go to certain mechanics who were licensed to give the emmission test. I had a 68 Chevelle SS with a crate LS7 454 which ran on 100 octane LL gas and it passed so you knowe they would do a lot of stuff to get you through. In did not recall you did not have a SES light or maybe you had the brake lights, but no SES lights? Not sure I understand the FTP risk and so forth. You had no clue of an issue until you failed the test? What did you do between tests to pass? I'm sure you talked about it, but I forgot :-(
