E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
So i recently bought a 2001 BMW 330i, not knowing sh*t about them smh, and about 2 days later the airbag light came on, & i told the dealer guy about it and he said it was some type of malfunction and all he needed to do was reset it, well that never happened. so a month has passed by and i decided to go on a road trip to denver.. (i know im dumb..) so on the way over there everything went smooth, but on the way back while driving on the highway the car jerked, and the BRAKE light came on, along with the ASC light, & the CHECK ENGINE SOON light, i pulled to the side and turned it back on after 10 minutes and the lights came off. As i drove home this happened about 3 times (another stupidity). not only that but the car also turns off automatically!! which is super deadly! can someone help me?? i know i dont know sh*t but i got to learn somewhere, just like evryone.. thanks guys.
My best advise to you is go to a Bmw dealer thats your best bet it could be 1 simple thing thats making everything eles go hay wire. when i bought my car it kept telling me that the key wasn't in the ignition now mind you iam driving the car..lol so i went to the dealer here all i needed was a update on my computer cost was $175.00 and problem solved
haha nice, well i hope it is a small thing, & not something too bad where i most likely will get charged an arm or leg =(. thanks man!
Don`t be stupid....go somewhere like Autozone and have them scan the codes. That`s *always* the first step in any diagnosis with these cars. If you stumble into a dealer not knowing *anything*, they WILL chop your balls off....
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
^^^^^ - The dealer will charge one hour labor - $130 to scan the codes. Autozone it -
The fuel pumps ($150ish) are usually reliable 8-12 years and will cause this issue, or a clogged fuel filter ($40). But get the codes read and report back here before you start throwing $$ parts at it. At this age, lots of things can cause this. Have AZ test your battery as well. A failing battery can make these cars do weird things too. |
FYI -- he's from California, and in this sorry excuse for a state, Autozone cannot scan for codes. Our state considers scanning a car for codes "auto repair" for which one must be a licensed mechanic with the state of Kalifornia before performing. I'm still trying to figure out whether it's the state simply being its typical greedy and over-intrusive self, or whether some organized mechanics group lobbied the state legislature to prohibit parts stores from scanning in some sort of corrupt back-room deal. I wouldn't be surprised by either.
Find a reputable indy shop. If you want to drive down to SD, I have some suggestions. Otherwise, perhaps other LA/OC-area festers can recommend an indy. |
If your cars randomly turning off and all those lights go on. Car you even start the car after? auto or manual? sounds very similar to a alternator going bad.
http://www.luxury4play.com 2004 Maserati M128 GT 2000 3-series BMW supercharged Because race car.
Update !!
Okay i got an update for you guys. I had my buddy's buddy read the codes for me. It read "P0335" which we googled, and crank shift malfunction came up. ?? Feedback would be greatly appreciated, and any other options or directions on how to fix this... btw all the lights on the dashboard are off now except for the airbag, & every once in a while the yellow oil light comes on which I'm aware of an oil change ASAP, other than that my car is close to 125k mi, any other details that can help, let know. THANKS to everyone responses!!
P0335 is a failing Crankshaft Position Sensor. Replace it.
http://www.facebook.com/home.php?sk=...?id=1338939628 "I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride" |
^^^This. All of your problems are sensor related. Your airbag light is most likely on due to a bad airbag sensor which unfortunately expensive to replace. With the yellow oil light, all this means is that your oil level sensor is toast, just be sure to keep an eye on your oil level regularly. If the light flashes RED this means that you are dangerously low on oil and you need to shut your car off IMMEDIATELY.
WileyPSims... you're half way there. Then comes the DIY, if you're up to it, check around for the procedure or have it done by a certified independent shop.
DIY = $ave $$ @Rocky Charles4 Hey an idea; Maybe we should have the red shirt character in you signature saying; Dealership instead.
