6 Series
Old 12-05-2012, 08:52 PM
Vlad Dracul Vlad Dracul is offline
The prince
Mein Auto: 2005 645ci
Low tire pressure + extreme cold conditions
Greetings from ****ty cold Anchorage, Alaska!
So I was driving around a little while ago and I got the low tire pressure warning go off. It gave me the typical spiel on slowing down to a stop and checking my flat tire. The thing is that my tires all seems properly inflated and am wondering if the cold could be screwing with the pressure? I tried pulling over to put some air in the tire but 1) we use carbon dioxide here and it isn't like traditional air pumps 2) it was -4 out.
Thanks!
Old 12-05-2012, 10:42 PM
Yorgi's Avatar
Yorgi Yorgi is offline
It's very likely the temps. If you set your pressures at 50°F by 0°F you will be down by 8psi. Which is enough to trigger the TPM warning. Nitrogen is better when it comes to pressure dropping but I am not sure how much better.
If you checked all 4 tires and they are OK then I would just re-initialize the tire pressures in iDrive:
iMenu > Vehicle Settings > FTM > start the car and drive around for 5 to 10 min before the next step becomes available > Set Tire Pressure > Yes > you will see an "Initializing" message
Details are in the owner's manual. (page 88-89 in my manual for an '06 650i)
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 12-06-2012, 03:08 PM
HerbP HerbP is online now
You might have a cracked wheel, if you still have the OEM Ellipsoids. Does one tire seem to loose pressure when it starts getting colder during winter? If so, that might be a cracked wheel, or just old winter cold!
Old 12-06-2012, 06:35 PM
The prince
Thanks for the replies.
This is my first time in REAL winter since I bought her last year.
HerbP I'm not sure I can answer because it's the first time I got that message. I do mean to buy some tires, notably snow tires, but it has yet to really snow. This is weird for Alaska.
Sent from my MB855 using Bimmer App
Old 12-06-2012, 08:15 PM
Global Warming!
Old 12-07-2012, 04:28 AM
BvN BvN is offline
Mein Auto: '06 BMW 650i convertible
Do you have run-flats? With those tires it's more difficult to see if they have a leak. Indeed an instant temp change has influence on the pressure too.
Old 12-07-2012, 07:03 AM
coug60's Avatar
coug60 coug60 is online now
06 BMW 650i Sprt/Prem Pkg
Mein Auto: 2006 BMW 650i e64
I hope you park her indoores...
I use to live in North Dakota. Gets dam cold there (I remember one time there where the high did not get above zero for over a month)... and if Alaska is anytrhing like ND...
Its easy to break a seal on a tire (tire & rim) and get a flat.
You might want to consider a block heater, battery blanket to keep the car healthy...
+ Various Mods & Upgrades
