E36 (1991 - 1999)
Old 12-07-2012, 08:21 AM
JDMwizkid JDMwizkid is offline
Mein Auto: 1993 bmw 325i
Crank fan delete
what is needed to do a crankshaft fan clutch and blade delete?
this is why im hot
Old 12-07-2012, 08:27 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Google-fu is the only thing you need.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 12-07-2012, 08:31 AM
i guess im not understanding.. what do you mean?
this is why im hot
Old 12-07-2012, 08:36 AM
southpark11235's Avatar
southpark11235 southpark11235 is offline
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
Please do not do it. The cooling system in e36's is the weakest part and you are talking about making it weaker.
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 12-07-2012, 08:41 AM
jonesin's Avatar
The Canadian Prick.
I'm saying to use the search function.
Not only will it tell you step by step how to do this (as it has been covered no less than 50 times) but will also tell you as alluded to above, why it is a bad idea.
Old 12-07-2012, 08:42 AM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
The funny thing I've never understood about this is......what exactly do you think you're gaining?
Sent from my LG Revolution 4G using BimmerApp
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
jonesin's Avatar
The Canadian Prick.
Old 12-07-2012, 08:51 AM
i have the stage 3 cooling refresh kit from ecs tuning.. would you still recomend not doing it?
this is why im hot
Old 12-07-2012, 08:52 AM
jonesin's Avatar
The Canadian Prick.
/thread.
i want to take the weight off the crankshaft but idk if it would be an ulpgrade or downgrade
this is why im hot
Old 12-07-2012, 08:54 AM
I Am The Machine
And what will that accomplish? The crankshaft has much stronger forces exerted on it several times a second.
Not only is that weight negligible in operation, the crank bearings were designed with that load in mind. I don't heat of a lot of crank bearing failures, do you?
// Chad //
You're a derbanana
Old 12-07-2012, 09:00 AM
ok i got another question.. my fan clutch bearing lost a couple balls and was wobbling around.. the bearing has not failed but idk how close it is to failure.. so im askin if i should replace it or take that weight off?
this is why im hot
Old 12-07-2012, 09:10 AM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
No, the pump lost bearings cause either its old/worn. or your fan might be missing a blade or two...
I dont have a clutch fan, but i dont think theres much of a difference
-Dino
Old 12-07-2012, 09:28 AM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
It definitely does not make any practical sense to remove your fan, and is making an already extremely weak cooling system even weaker.
And if your fan clutch bearing has "lost a couple balls", I wouldn't even drive the car like that. If it gives out while the engine is on, it could send the fan flying into the radiator, hood, hoses, etc, thus making a $30 & 15 minute repair much more costly.
1998 BMW 328is
1966 Pontiac GTO
I dont have a clutch fan, but i dont thinks theres much of a difference
what do you mean you dont have a clutch fan? do you have a direct fan or something?
this is why im hot
Old 12-07-2012, 09:31 AM
BMRfanatic's Avatar
like theres no fan connected to my waterpump.
-Dino
Old 12-07-2012, 09:41 AM
did you delete it? what does it look like?
this is why im hot
Old 12-07-2012, 10:31 AM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
Mein Auto: A redhead E90
this thread hurts my brain....
STAHP
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
Old 12-07-2012, 10:52 AM
BMRfanatic's Avatar
Look under your hood. Then ignore the fan. And picture thr waterpump with only a threaded nut sticking out lol
STAHP
Lolz
Sent from my SPH-D710 using Bimmer App
-Dino
Old 12-07-2012, 11:01 AM
Kdoherty's Avatar
Also to the OP (that's you JDMdudewhatever) the clutch fan weighs so little that you will get NO extra power by removing it. The electronic fan is meant to supplement the belt driven one, and not perform the whole duty. Our engines are very susceptible to overheating, and once you do you'll either wreck the head which is bookoo dollars or you'll blow the head gasket which is nearly as expensive to repair if you can't do it yourself. So to save yourself money in the long run, not to mention the brand new radiator you're probably planning to install, replace the damn fan and fan clutch
i searched it for you and took LESS than 5 minutes
http://www.pelicanparts.com/cgi-bin/...ch%20%20%20%20
^fan clutch
^fan
EDIT: You'll also need a new waterpump if there's a ball bearing missing. http://www.pelicanparts.com/cgi-bin/...0Each%20%20%20
  • '06 325xi 6MT
Old 12-07-2012, 12:00 PM
BMRfanatic's Avatar
^fan clutch
^fan
This.
In shorter words, dont remove it, replace the broken stuff.
Have piece of mind
-Dino
Old 12-07-2012, 03:02 PM
By "stage 3 cooling refresh kit" do you mean this one. if so the Stewart pump should last for ever. Are you sure it is failing? Also did you change the fan clutch and blade when you refreshed the cooling system. If so and the wobble started right after you refreshed it then maybe you installed something wrong.
Old 12-07-2012, 07:24 PM
http://www.ecstuning.com/BMW-E36-325...ing/ES2598404/ no i mean this one
this is why im hot
Old 12-07-2012, 07:25 PM
i have not installed the refresh kit yet.. its on its way.. and i dont know that it is failing but i know that the vibration cannot be doin any good at all for it
this is why im hot
Old 12-07-2012, 07:44 PM
ZeGerman's Avatar
Warm Leatherette
I'm telling you man, do NOT drive your car if it's vibrating like that. You're going to make a cheap repair much more expensive that way.
1998 BMW 328is
1966 Pontiac GTO
