Old 03-06-2008, 12:54 PM
morrieschoice's Avatar
morrieschoice morrieschoice is online now
Mein Auto: 2001 3.0 Z-3 ROADSTER
Brake Light & DSC light (Z-3 roadster)
The brake light & DSC light came on simultaneously the other day on my 2001 3.0 Z-3 Roadster. The car has 44,400 mi. on it. Brakes work fine & there's no slipping of the tires in the rear end. The DSC light has come on befoe but eventually went off. The front pads were replaced 14k miles back but the car brakes with no problem & does not pull to the right or left when stopping. Any idea why the lights are on?? Can I use a peake tool to turn off the lights? I am open for suggestions.
Old 03-07-2008, 03:03 PM
khammack khammack is offline
Warning - Thin Air
Mein Auto: 2002 M Roadster/2014 435i
When the light comes on like that it means that something is wrong with the system. If it was just the DSC light it would mean that it works just like when you have DSC turned off. With the brake light on along with the DSC, it could mean other things. My guess would be that one of the wheel sensors isn't working right. I will be trying to track down why my DSC is on this weekend. From what I can tell, check the wheel sensors first, but it can also be the steering angle sensor or the lateral acceleration and rotational rate sensor (which is under the left seat).
Other posts on the board suggest pulling the codes to see where the problem is. I tried to pull the codes with the key on, but the engine off. There were no codes. I'll try again tomorrow with the car running, if still no codes I'll start with the wheel sensors.
Old 03-08-2008, 11:46 AM
SamN SamN is offline
Mein Auto: '99 Z3 2.3; '03 R1150RT
Thanks much for the info. I'm having the exact same problem.
Old 03-08-2008, 01:59 PM
Warning - Thin Air
I just checked and cleaned all of the wheel sensors, but it didn't help. I'm thinking the next step is to replace the steering sensor, but it is $170. The wheel sensors are about $110 each. Does anyone know if there is any way to test these sensors to tell if they are bad or not. Trial and error replacements can get expensive.
Old 03-10-2008, 07:28 AM
SC Joe SC Joe is offline
Mein Auto: 2001 Z3 2.5
I hope you come up with an answer; mine does this intermittantly as well. Typically applies the anti locks HARD on the right front wheel for a few seconds, then the lights come on. I'm thinking a wheel sensor on the Rf wheel, but at $100/shot, I hate to just start replacing parts.
'01 Topaz blue Z3 2.5
Old 03-10-2008, 07:54 AM
Warning - Thin Air
I tried to test the wheel sensors based on a post I found for another model of BMW, but the post said there were two pins in each sensor and we seem to have three. I did check all four corners anyway and they all tested the same, but not what the post indicated. I'm thinking my wheel sensors are OK since I got the same reading on each. I did find that there are also sensors on the bottom of the break fluid reservoir, but they look OK. No idea how to test them. I think I'm going to need to take mine to the dealer because it seems to be either the steering sensor (and the computer needs to be reset when it is replaced) or the control unit.
Others have indicated that you can pull codes to see what the problem is, but I tried to pull codes with two different code readers and both reported no codes. I just have a solid DSC light.
Old 03-10-2008, 08:22 AM
There is a local independent BMW service place that is prettty good; they have confirmed they can work on it. i may take mine to them. At time, the car slamming on the front brake is troublesome
Old 03-10-2008, 08:50 AM
Warning - Thin Air
I'm not sure what would cause that, but I would take care of it as soon as possible. It sounds like it could be dangerous.
Old 03-13-2008, 02:36 PM
If you are interested in seeing where the speed sensor is located...then check with Randy Forbes on this site. Or you can check it out on http:/forums.bimmerforums.com/forum...t=speed=sensor. However, this info. is on another forum..."bimmerforums". Randy Forbes who is a member of this forum is apparently a member of the other one also. He posted pics of the speed sensor. Hope this will help you & me both....let me know if it does...looks fairly easy to replace if needed??
Old 03-20-2008, 02:41 PM
Warning - Thin Air
Well, after not being able to find anything wrong on my own (except the DSC light on) I took it to the dealer. They put it on their fault reader and didn't find anything wrong except for one code - "Vehicle Power Above 18 Volts". They checked the charging system and it was OK. They then recalibrated the Steering Angle Sensor to fix my DSC light on problem.
Old 03-20-2008, 02:49 PM
cngizbleevng's Avatar
cngizbleevng cngizbleevng is online now
hardtop potentate
Mein Auto: 2002 Z3 3.0i 5 speed
I had that same thing happen last year. I cleaned my wheel speed sensors and evened out the tire pressure (one tire had lost a fair amount of air for some reason), and all has been good since.
Old 03-20-2008, 03:00 PM
Warning - Thin Air
Been there, done that. I even tried to test the wheel sensors using a write up I found for an E46 (I think). It wasn't good for Z3s, but I did get similar reading on all 4 wheels, so I thought the wheel sensors were most likely OK. I couldn't find any way to check the steering angel sensor or to recalibrate it, so no choice but to go to the dealer.
At least I got to sit in a 1 series. It looked nice. I'll bet they go fast once they get some in they can actually sell (they said this one was demo only and they can't sell any until after the announcement in about a week).
Old 09-01-2009, 06:43 AM
ufviper ufviper is offline
Mein Auto: 2001 BMW Z3 2.5i
2001 BMW Z3 2.5 DSC Brake Light Brakes activating
Front Brakes Activating hard, DSC light blinking, then DSC and Brake light stay on. It happens random. every 30 miles every other day.
Solution:
Rotational Rate Yaw Sensor Under seat is malfunctioning
Part Number 3452 6 754 289
The mechanic informed me he would charge $1000 to replace but i fixed for only $60 and this is how:
1) The part retail's for $600 dollars - Mechanic told me that a used part is no good and that it has to be programmed. HE IS WRONG. That yaw sensor doesn't have to be programmed and you can do it yourself.
2) FIND A USED SENSOR - Go on EBAY - I found the part for $60 , but i was lucky. Other used yaw sensors go for $260-350. Make sure that it is a POWERSELLER for used parts and that it is a working sensor tested before you bid on it.
The sensor is a universal sensor that was placed on alot of BMW models. Just make sure it's the same part number. The listing on ebay said it came off a 3 series when i drive a Z3 but its fine.
3) The sensor is located under the driver seat and carpet. REMEMBER to disconnect battery before removing seat or the airbag light will stay lit.
4) The carpet under the seat is indented and no tools are needed to reach sensor.
5) The sensor has 2 bolts and a electronic connection (EASY TO REPLACE)
Old 09-01-2009, 03:30 PM
mcelhinny mcelhinny is offline
Mein Auto: 2000 m roadster
can also be weak battery
Old 09-02-2009, 01:41 AM
siwilson siwilson is offline
Mein Auto: M Roadster S54 - E39 3.0
Just watch out with a used sensor. My yaw sensor was causing problems, but only after around an hour of driving. Park up for an hour and good as new again. I now have a new sensor as a permanent fix and kept the old one as a 'spare'. Just watch out someone else didn't have that intermittant problem and sell a semi-faulty unit.
Old 04-28-2010, 02:27 PM
lilumiah lilumiah is offline
Mein Auto: BMW 320Ci M Sport
Chaps, My 320ci is also having the same problems. It happened today after i inflated my tyres (32 at back and 29 in front) and i was driving behind a Hay Truck for a while which was spilling Hay everywhere and so i'm wondering if there may be Hay stuck in my Traction system? Is that possible or am i just making up problems here?
Anyhow, If i wanted to clean the sensors, where would i find them? Thanks
Old 12-07-2012, 08:51 AM
tim2012 tim2012 is offline
Mein Auto: Z3 CONVERT
my Brake light is on & my DSC (traction) light is on & my airbag light is on. I took it to German Auto repair and they fixed the Check Engine light but could do nothing with the other 3 lights..... whats the deal? theyve been on for a year now and im ready to sell it but hard to sell with the dash lit up like a christmas tree!!
Old 12-07-2012, 08:53 AM
I have a brand new battery, 4 brand new tires, fresh alignment, brand new front brakes and rotors, new water pump, new fan, new belts and a fresh new oil change.... what gives?
Old 12-07-2012, 10:26 AM
ghpup's Avatar
ghpup ghpup is offline
Glfbggy
Mein Auto: 07 X3si, 14 535xd, 00 MZ3
I believe that your DSC and Brake lights indicate a speed sensor has gone out. Mine did this intermittantly for about 4 months then went solid. After doing some searches in this forum and Bimmerforum, I figured it was the speed sensor. I called my local indi to tell them and make sure he had a speed sensor in stock. Took it to them, they validated on their machine (same one as used by the local deal and direct from BMW) and had it turned around in less than an hour.
The airbag light has been known to indicate a bad seat connector for either the passenger or driver side. At least that is what I've seen in this forum. Do a search and see.
If your indi hasn't figured it out, I would take it to a dealer or a different indi that specializes in BMWs. Mine does BMW, Mercedez and Volvo. Nothing more. They have factory diagnostic machines for all makes, not just the after market readers...that don't always have the right BMW codes in them.
Good luck.
GLFBGGY
'00 MRoadster, '00 528 now in other hands, '07X3si, '14 535d XDrive
Old 10-08-2014, 10:17 AM
kalaigh kalaigh is offline
Mein Auto: Z3
DSC and Brake lights on
Can i test, using a DVM, the wheel speed sensors from the engine compartment. Do all 4 sensor wires converge to a central area?
Old 10-10-2014, 11:47 AM
Brian4 Brian4 is offline
Mein Auto: F11 535d and 3.0i Z3
You can if you unplug the large plug from the control unit next to the DSC pump , right hand side of the engine bay looking from the front.
43 pin connector and the pins are numbered with very small numbers.
Pins 2&3 are Front left.
Pins 5&6 are rear right
Pins 30/31 are front right
Pins 33/34 are rear right.
The should have a small reistance when standing still.
Brian
F11 535d
Z3 3.0i
Old 10-14-2015, 08:49 AM
vintage42's Avatar
BMW CCA 1405
Originally Posted by ufviper View Post
... 3) The sensor is located under the driver seat and carpet. REMEMBER to disconnect battery before removing seat or the airbag light will stay lit....
I have removed my driver seat three times, to replace the seat bushing, to replace the seat belt tensioner, and to access the clutch pedal bushing.
I did not disconnect the battery, and it did not affect the airbag light.
Old 10-14-2015, 09:05 AM
As long as you don't turn on the ignition with the seat disconnected you would be OK
Old 10-20-2015, 10:04 AM
Paul1940 Paul1940 is offline
Mein Auto: 2001 BMW Z3 3.0i
Your cluster alerts
I had the same lights on. Is the BRAKE alert yellow or red? If yellow along with DSC light could indicate DSC turned off. Might you have hit the switch? Otherwise indicates an error or fault in the DSC module. Need to get code reader that attaches to the 20 pin BMW port in the engine compartment. Same for the airbag light. Read the ABS module for fault codes. This will give you an idea of what is wrong. Since Z3 is notorious for water under the carpet, it is a good idea to check connectors under the seat. Let us know when you get codes read. Read SRS module for airbag codes. What year is your Z3?
Old 10-20-2015, 10:58 AM
vintage42's Avatar
BMW CCA 1405
Originally Posted by Paul1940 View Post
... Since Z3 is notorious for water under the carpet, it is a good idea to check connectors under the seat...
In removing my seats at 32,000 miles, I found all the modules and connectors were tied up under the seat, with nothing laying on the floor.
I guess that over the years and miles, as Z3s have their seats removed for one reason or the other, the modules and connectors are left laying on the carpet
