E90/E91/E92/E93 (2006 - 2013)
#126
Google and Bing can be your friends. The truth will set you free.
IOW the information doesn't really exist.
#129
Not for you or others with closed minds. The truth will set you free. Google and Bing can be your friends.
No closed mind here...I don't have a horse in this race one way or the other. If you can't provide supporting references for your position then I'll assume your position is unsupported. It's not my responsibility to seek out support for YOUR claims.
#132
Certainly true! But, the old saying is "Reduce, reuse, and recycle" and I think we often ignore the first component of that. Better to use less paper, glass, aluminum and oil than to recycle more.
2009 E91 Montego Blue w/ Gray Dakota 6AT ZPP/Logic7/Sirius/Idrive/Butt warmers/6FL/PCD/CA/6NL/Xenons |
#133
I do changes at 7,500 miles because I personally think it makes good sense. I also see little reason not to. For $90 extra a year, why give it a second thought? In fact, I will stick to Mike Miller's schedule as long as I own a BMW. To be clear, I am not trying to argue that BMW's oil change schedule is optimal. I simply agree with Sunny's point - there really isn't any compelling evidence to the contrary. I also rotate my tires every 5,000 miles and I plan to swap out the water pump early as a preventative measure. Better safe than sorry!
2009 E91 Montego Blue w/ Gray Dakota 6AT ZPP/Logic7/Sirius/Idrive/Butt warmers/6FL/PCD/CA/6NL/Xenons Last edited by Kilgore Trout; 12-07-2012 at 02:31 PM. |
#134
An ounce of prevention is better than a pound of cure (or something to that effect).
Kilgore, you posted "My SA would benefit from me betting more frequent oil changes. Yet, he discourages me from doing so because based on his expertise and experience, he does not view it as necessary." Do you really think that a SA is going to go against BMW Munich and say that you should get an oil change more often than it is required by the warranty? Do you see any opportunity for a lawyer to take any such suggestion and use it against BMW in a lawsuit over a sludged engine with 15K intervals?
I disagree with Mike Miller on a few things, but not on oil change intervals. Modern oils are far better than what was available only ten years ago. They can keep their lubricity, their viscosity, and their detergency for 15K miles. In the lab, but not in every engine in the real world. Salesmen who get onto highways in Nevada and drive all day without a complete cool down have the best shot at getting 15K safe miles between changes. A commuter in a congested New England city isn't going to make it. His oil never gets hot enough to boil off the condensation collecting in the sump. Ever see water almost pouring out of a tailpipe on a Winter morning? It's not all going out the tailpipe. Shear forces ('scraping' of oil with suspended water droplets) is going to mix some of that moisture with the oil. In the gasoline are sulphur molecules. These molecules mix with water molecules to form sulphuric acid. There are buffers in oil to fight acids. They run out. The moisture in the oil reduces the vaporization point of some of the oil. It boils off when the engine is shut down. It then passes through the system and condenses on the fastest cooling metal, forming deposits which eventually turn into sludge. Engines are started at 10F and then run at 200F and shut down. That kind of thermal cycling presents challenges to viscosity integrity you don't get in southern California. Where will oil last the longest? BMW always blames our sh*t gas for all kinds of mechanical and driveability problems. Do you think that maybe there are also things in the gas which result in risks to the oil? How about methanol blends, or base stock composition, or refinerey practices, or additive qualities? Your intuition has to recognize variability in all those areas. To think that BMW has evaluated all the potential hazards to oil reliability is absurd. If so, then one would have to say that to ensure every BMW engine will perform at peak reliability for as long as possible would require that oil last 40,000 miles in the very best circumstances. Because that would be the top end of the failure curve, and 15K would be the lower end. How likely is that? Last edited by DSXMachina; 12-07-2012 at 10:51 PM. |
#137
I addressed my comment to Kilgore because he is one of the former. Though I do smile whenever I read his support of 15K intervals, his claim of no contrary evidence, and his need for 7.5K intervals for his own vehicle. Thank you, Kilgore.
And, let's also be clear that 1) I still don't believe that is a lot of empirical support that intervals shorter than 15,000 are necessary, 2) I think it is a big mistake to push your oil much past 7,500. Points 1 and 2 may seem like contradictions, but they are really not. I'm saying that there is no real evidence in support of Mike Miller, but there is no real evidence that Mike Milller ISN'T the way to go either. So, in the absence much hard data, I'm just going to go with what makes the most logical sense to me. And, logically, I think that they single best strategy for prolonging the life of your car is frequent oil changes. In your own post, you've detailed many of the reasons why I believe that to be the case. But, I still respect Sunny's point. The hard evidence in support of my perspective still isn't there. So, its not really fact, it's just what I believe. So there!
2009 E91 Montego Blue w/ Gray Dakota 6AT ZPP/Logic7/Sirius/Idrive/Butt warmers/6FL/PCD/CA/6NL/Xenons Last edited by Kilgore Trout; 12-08-2012 at 12:31 AM. |
#140
You keep referring to some agenda. Specfically what agenda are you referring to?
#143
Tautological |
#144
That's a whole lot more than just reports on chat boards, unless you think the UOA's are faked or labs such as Blackstone are for some reason falsifying thier reports. DXM's points are very valid. TBN down to 0, sulfuric and nitric acid in the crankcase, won't take long for your engine to be a sludge factory. |
