E90/E91/E92/E93 (2006 - 2013)
Old 12-06-2012, 08:15 AM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
He must be talking about the plastic aero pan.
Old 12-06-2012, 08:22 AM
Leekay07 Leekay07 is online now
Mein Auto: 08 335Xi, 2013 X1
No I ment the big metal one I unscrewed the 3 bolts on the right and loosened the other side then I did not have to deal with it dropping to the ground Got the bolt put it back in the throttle body reassembled the car and found that my transfer case my dealer serviced last week is pissing oil all over my parking space. LOL its just awesome. CAR fired up but the fan went on full speed after a couple of minutes
If you like customer service. Don't look beyond a BMW.
Old 12-06-2012, 08:23 AM
umm..
Old 12-06-2012, 10:35 AM
Car needs mechatronics seal again LOL its only been 3,000 since it was last done.
Old 12-07-2012, 02:49 PM
MP3_E46's Avatar
MP3_E46 MP3_E46 is offline
Code/wrench Monkey
Mein Auto: Miata NC2
Is the car running ok now? Was that the issue all along?
Six Euro Deliveries since December 1998 (Owned E46, E90, E91, E92 and E93)
28 vehicles in 26 years of driving so far. Guess I like cars
Old 12-07-2012, 03:03 PM
Cars running great now.
I love the car and the combination.
Now to come.
Shocks or Coilovers
Radiator
Big Brakes
CoBB AP Tune
PCV Valve.
Meth Kit.
Old 12-07-2012, 10:57 PM
DSXMachina's Avatar
Automaticallyparsinglinks
Now to come.
Shocks or Coilovers
Radiator
Big Brakes
CoBB AP Tune
PCV Valve.
Meth Kit.
Stay away from Calwaterboy. He's a bad influence.
(PCV valve???)
Old 12-08-2012, 05:29 AM
MP3_E46's Avatar
Code/wrench Monkey
(PCV valve???)
Cal is sending an invoice for the Internet Diagnosis that fixed Leekay's car. Would be interested if the BMW dealerships ever admit incompetence and/or refund any of the ~$3K in 'repair' bills. It was about $3K down the drain right?
Old 12-08-2012, 05:45 AM
3,100 and some change.
Old 12-08-2012, 05:48 AM
CALWATERBOY's Avatar
CALWATERBOY CALWATERBOY is online now
Mein Auto: 2009 E93 N54
(PCV valve???)
Might mean RB Turbo's PCV valve upgrade. $45 from Rob, but not on the site in the first link.
2nd link's Rob's email addr if you want to ask about it - reputed to reduce or elim valve coking, maybe w/catch can.
Or, preemptive strike re: existing need for walnuts. LeeKay?
Old 12-08-2012, 05:50 AM
If I use it and Methanol they should keep the inlets relatively clean because the methanol should/will keep the build up down.
Old 12-08-2012, 06:00 AM
Here's something re: PCV valve problems, by da man.
Sadly, methanol reputed to have minimal if any effect on valve coking. Counter-intuitive, no?
Old 12-08-2012, 06:14 AM
it wont remove junk but it will keep it from sticking. The issue is that its always dry and then the oil vapor hits it and sticks to the walls You can clearly see on my pic that the oil formed a trail down to the valve. Cylinders 4-6 where not so bad and I can only put that down to the fact the injectors would trickle/leak and the gas vapor in the cylinders made it harder for the oil to stick to the walls or even eat the stuff from the walls of the inlets.
