Old 07-28-2012, 08:30 PM
Fast Bob's Avatar
Keeping it surreal
Originally Posted by mrg325i View Post
Has this lack of hp been going on for a while? Has it been a gradual change or something within the last weeks or months?
I am hoping to keep this thread going so we can get more help. My general automotive knowledge is fairly good. My BWM specific knowledge is not that good.
You are not going to get a gread deal of hp out of a 323.
OP thinks this may not be the original engine....an engine making anywhere *near* 200 HP would tend to confirm that idea....
The road goes ever onward....
(R.I.P. Jever)
*Please support the Wounded Warrior Project*
Old 07-28-2012, 09:37 PM
marinekilz's Avatar
marinekilz marinekilz is offline
Noone Special
Mein Auto: 02 e46 325 xi
Originally Posted by m-series View Post
i don't disagree at all, well a 330 is up to 235hp, a 328 is 190hp, i know that a stock 323i is 170hp,
You show me a stock m54 making 280 torque. There is none, numbers are way too high as I stated
straight out of the road and track july 2002 for the 330:
Peak Horsepower 225 @ 5,900 = 200 lb-ft
Peak Torque 214 lb-ft @ 3,500 = 143 hp
E9 One Day It Will Be Mine
Old 07-29-2012, 07:16 AM
m-series m-series is offline
Mein Auto: bmw
at first it was amazingly quick with even more boost at high revs, then suddenly it got slow, from then it got slower and worse when i first had it i got a digital 0-60 time of just over 6
Old 07-29-2012, 07:21 AM
Mein Auto: bmw
m52 engine, sorry i think it was 310 torque, you have me wrong on the type, i was talking in nm not lb-ft
Old 07-31-2012, 08:10 AM
mrcoffee mrcoffee is offline
Mein Auto: 323i 2000
I have the same problem with sluggish response in my 323i (2000). I know very little about cars but Im guessing it is a transmission problem? What did you find out? Were you able to fix the problem?
Old 07-31-2012, 08:54 AM
new_kid new_kid is offline
Mein Auto: 2000 BMW 323i
Idler pulley.
+ 1
Sluggishness? Auto or manual...?
Old 07-31-2012, 09:31 AM
Auto. The rpms go up but there's no engagement. The problem is intermittent with some shaking. Local guy told me to hold the neg wire to the pos terminal on the battery to clear the electronic mem. Might try that today to reset and determine if it's software or tranny
Old 08-01-2012, 02:33 PM
Mein Auto: bmw
mine isnt transmission trouble, does anyone know full name of idler pulley on that diaphragm on page 1
Old 12-07-2012, 01:37 PM
orightythen orightythen is offline
Mein Auto: BMW 323 - 00
Question Got a question...
Hey guys! my Bmw 323i - 00 Engine Head Gasket probably broke today, because i got oil in the water or at least Im hoping its just the gasket. My question is can i buy a 1 mm gasket instead of the 0.7mm gasket even if Im not planing on grinding the head? will the 0.3 mm difference change the compression? And has anybody changed the gasket on this engine? Is It hard? and do i need any special tools for it?
Old 12-07-2012, 01:49 PM
Fast Bob's Avatar
Keeping it surreal
I believe you`re jumping the gun, my boy....the FIRST step should be to make a proper diagnosis. Get a compression/leakdown test performed before doing anything else.
(R.I.P. Jever)
Old 12-07-2012, 01:55 PM
What about the oil in the water? what could it be if not the gasket or the head itself thats cracked? I mean the compression could be fine but the gasket could still be broken between the oil and water "compartments" or? I don't have a lot of time as i need the car to get to and from work, wanna get parts ordered as soon as possible^^
Old 12-07-2012, 02:59 PM
Fast Bob's Avatar
Keeping it surreal
Oil & water combined is usually a result of one of the following:
Head gasket
Cracked head
Cracked block
(R.I.P. Jever)
Old 12-07-2012, 03:27 PM
BMW318i_E36 BMW318i_E36 is offline
Mein Auto: 2003 BMW 325i
How can a BMW 323i have 200hp There is no possible way.
That dyno test may have something wrong with it.
Old 12-07-2012, 10:35 PM
Head gasket
Cracked head
Cracked block
Yeah, I'll order the gasket and keep my fingers crossed, Does anybody know If it makes a difference with a 1mm Gasket instead of a 0.7mm Gasket? I'll be ok with a 1mm or?
Thanks Fast Bob
Old 12-08-2012, 03:59 AM
Mein Auto: bmw
Thanks Fast Bob
I think you might be ordering your parts a bit too soon, if it could be cracked head or block that is
323i, bmw, e46
