Old 11-30-2012, 04:05 PM
BUZZ_PLUS BUZZ_PLUS is offline
Mein Auto: E46
Can anybody solve this riddle !!
I'm a bimmer for more than 10 years I have an E46 2000 with M52 engine Recently my car showed more fuel consumption , I thought it's the age or something but after no long time when I start the car it won't start !! the engine rpm goes up and then drops quickly I checked the ICV and cleaned it and got nothing,, after some trials I realized that the engine can start after the third or the fourth ignition trial then the engine is hesitated for 3-4 seconds and behaves as if one of the spark plugs is not working then it goes just fine.
I used the OBD scanner got codes of a faulty Crank positioning sensor, Miss fire and a faulty oxygen sensor
after a week with this mess I ran the scan again found same codes except the o2 sensor which I think it throw the code from the first time bad ignition !
the main symptoms are :
1-There is an obvious loss in power that I feel that the belts doesn't rotate with their full speed,even when going on steep ground or a garage i need to pump more fuel
2- high fuel consumption
3- some times when pressing the gas pedal while ignition to increase RPM the red battery sign in the cluster glows for 2 seconds then turn off
4-Hesitated engine while Idling
Share your thoughts with me please ,, seems like a tough job to do
Old 11-30-2012, 04:07 PM
skwidrific skwidrific is offline
Mein Auto: 323i, Ducati M1100
Vanos?
Old 11-30-2012, 04:19 PM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
High fuel consumption is symptom of bad oxygen sensors. pre-cat oxygen sensors (in exhaust manifold by engine) usually die around 100,000 miles. If you're getting a code and they haven't been replaced, probably time to replace them. At the age of your car, if you're getting crank sensor error, I'd replace that too.
Misfires - how old are spark plugs? If more than 60k miles on them, start there, then you might need to test for dying coil packs. Usually you change the misfiring coil to another cylinder and see if the error code follows it to isolate a particular coil.
EDIT - if you are just having to press the gas more like it's not getting enough gas, you could be looking at a clogged fuel filter or dying fuel pump. Fuel filter is a 60-80k miles maintenance item. Fuel pumps average 8-12 years of reliability.
Old 11-30-2012, 04:35 PM
Mein Auto: E46
I was thinking of a fuel pump or crankcase ventilation valve , anybody agree ?
Old 11-30-2012, 04:52 PM
j_schroeder's Avatar
j_schroeder j_schroeder is offline
Mein Auto: 330ci
Did you change the crank sensor?
2001 330CI
Old 11-30-2012, 08:19 PM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
I would guess fuel pump and / or oxygen sensors.
Old 12-08-2012, 11:56 AM
Mein Auto: E46
Changed the fuel pump and the CCV and nothing happened :S I'll go for the cps
Old 12-08-2012, 12:10 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Oxygen sensors !
The road goes ever onward....
(R.I.P. Jever)
Old 12-08-2012, 12:19 PM
Dave 330i's Avatar
Dave 330i Dave 330i is offline
The King of Common Sense
Mein Auto:
intermittent crankshaft sensor. My '01 330i (M54 engine) with 143K miles since new never had O2 sensors replaced. I can't imagine they could last that long. So, my intuition is that the oxygen sensor does very little from normal operation.
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein
Swim upstream. Go the other way. Ignore the conventional wisdom. If everybody is doing it one way, there’s a good chance you can find your niche by going exactly in the opposite direction", Sam Walton.
Old 12-09-2012, 11:00 AM
Mein Auto: '04 330Ci 6-speed
I wouldn't be so skeptical as you. Oxygen sensors provide valuable feedback to control fuel/air mixture for proper running and good mileage.
I'd guess yours are working better than zero. Get a live reading of their function to explore.
Old 01-12-2013, 02:55 PM
Mein Auto: E46
Relief your self guys it was a cracked cylinder head and it had its effect on all sensors A/f mixture and water consumption, I fixed the problem though wiped out my pockets and its working fine now
