Old 11-27-2012, 10:28 AM
Wolfman64 Wolfman64 is offline
Mein Auto: 750li, S550, SL550, ML350
Originally Posted by FalconFlyer View Post
umm... hate to say it but they are too dim..... I could not tell you even had AE's.... they look no different than other LED AE lights...
Tend to agree. I was hoping that they be brighter with 40Watt output. Others are as low a 6Watt.
Unless of course it's 40Watts combined for both sides...
Old 12-05-2012, 08:42 AM
745ion22s 745ion22s is offline
Mein Auto: F01
The Stahl LED replacements I'm using may not perfectly recreate the look of the current model year but in my opinion look 100 times better than the ugly yellow look the halogen bulbs gave. I've used a number of different halogen bulbs and none gave a good white output. Some even gave off codes. I also tried a different vendor's LED and saw that the center ring was way brighter than the outer. With these I get good output out of both AE rings.
Personally, I'm not willing to run wires and drill holes to accommodate HIDs.
Old 12-05-2012, 11:32 AM
E92-Lighting's Avatar
E92-Lighting E92-Lighting is offline
Mein Auto: 335i
our MTEC angel eyes produces over 900 Lumens
BMW CREE LED ANGEL EYES ALL BMW MODELS MTEC V3 V4 DTEC V7 V8 V9 V10 V11 V12 V13 RGB V14 NO ERROR
BMW ACCESSORIES and PARTS
BMW LED INTERIOR KITS ALL BMW MODELS
please PM/Email us for Bimmerfest member BMW discount/combo pricing
info@e92-lighting.com "e90post5" for 5% off as the promo code at checkout
Old 12-05-2012, 04:49 PM
ChrisF01's Avatar
ChrisF01 ChrisF01 is offline
Gib mir Feurschutz!
Mein Auto: 2016 750i xDrive
Originally Posted by 745ion22s View Post
Is this enough sunlight?
1st pic, AE's are off
2nd AE's are on
Wow those are really dim, this is why E92Lighting didn't want to post any pictures of his own products, they're vaporware!
2016 750i xDrive M-Sport (Current)
2015 650i Coupe
2013 750i M-Sport
2012 740Li
Old 12-05-2012, 04:58 PM
FULL 6 FULL 6 is offline
Mein Auto: 2012 750i MSport
E92 lighting, why do you always get so much bad press on this forum your posts are crazy you post you post you post you post and none of your **** works - then claim to have the best stuffs and it CODES!!!!SHOW US REAL F01 EXAMPLES of your product with testimony and review instead of bumping everyday and boasting.
Old 12-05-2012, 07:25 PM
f01driver f01driver is offline
Mein Auto: 11' 750i, 14' Bentley GTC
Lol, I agree; if you have a product which is supposedly superior you would post tons of pictures, the issue is there is no "silver bullet" when it comes to aftermarket angle eyes.
2011 750i
Old 12-07-2012, 10:47 AM
MOPAULY's Avatar
MOPAULY MOPAULY is offline
Mein Auto: Many things
Originally Posted by full 6 View Post
e92 lighting, why do you always get so much bad press on this forum your posts are crazy you post you post you post you post and none of your **** works - then claim to have the best stuffs and it codes!!!!show us real f01 examples of your product with testimony and review instead of bumping everyday and boasting.
amen
Old 12-08-2012, 09:11 PM
stephenaron stephenaron is offline
Mein Auto: 2011 750i
Strahl
Took out my alpines and replaced with Strahls kit. Though not as blindingly bright as the alpines, the strahls still look good. I bought the strahl kit to see if the reason my outer rings dimmed was due to something in the alpine kit/parts. As you can see in my pic with the strahls, the outer rings are still bad. Thinking the alpine lights damaged the rings. Anyone?
2011 750i with 19" M Package
Bridgestone SO-4 tires.
Old 12-12-2012, 08:05 AM
Mein Auto: F01
Sorry to hear that happened with your outer rings. I run the Strahls and my outter rings light up fine. Glad I never went with using the HID
Old 12-12-2012, 01:05 PM
jprescott jprescott is offline
Mein Auto: 740Li
I hate to jump in here so late but I installed the following back in June :
http://www.bimmerfest.com/forums/sho...hlight=umnitza
Yes they were cheap and stupid easy to install. Yes I did have a code issue that was easily rectified with an extra resistor. No I do not have any dimming after 6 months. They are not the brightest bulbs in the pack but they sure look good
2015 640iX GC
Old 12-12-2012, 07:57 PM
Mein Auto: F01
I had that brand prior to the Strahls. Problem with that brand was the outer ring was still quite dim.
Old 12-12-2012, 11:22 PM
ChrisF01's Avatar
Gib mir Feurschutz!
Could it be the mixing back and forth with AEs?
Mine have worked flawless *knock on wood*
2015 650i Coupe
2013 750i M-Sport
2012 740Li
Old 12-25-2014, 01:24 PM
lionplayer lionplayer is offline
Mein Auto: 740d M Sport
so guys..... 2 years later with your HID angel eyes.... how's it going?
did you guys go back to stock or did you replace failed HID bulbs?
please share
cheers
please share
cheers
Old 12-26-2014, 09:19 AM
CABimmerNation's Avatar
CABimmerNation CABimmerNation is offline
CABimmerNation
Mein Auto: 2010 750i M Sport
My 7 is a piece of crap, but my HID angel eyes are great.
Dinan S3, PedalBox, 22" Agetro rims, H&R spt springs, RDsport front lip, coded, paddle shift retrofit, AlpineMSS HID 8000k. All exterior chrome, roof, roof spoiler and everything behind wheels painted black, wing, side and rear reflectors and door handle trim painted white, light smoke on tail lights. Audio: focal separates, earthquake low profile subs under front seats (crossed over as mid base to support the pathetic 4" fronts), arc audio amps, audiocontrol lcq-1 and epicenter, (2) L7 subs.
Old 12-30-2014, 11:25 AM
Mein Auto: 335i
please share
cheers
please share
cheers
watch out for failed fiber optics, HID angel eyes get extremely hot, headlights are already over $2000.
Old 12-30-2014, 11:48 AM
what watt was the hid used in that very old photo you keep posting on different forums?
Old 12-30-2014, 11:53 AM
CABimmerNation
Not an issue, thanks though.
Old 12-31-2014, 11:46 AM
Mein Auto: 335i
it doesnt matter when the picture was taken, the end result is the same, please do some research, there used to be a particular vendor who was popular a few years back who only sold HID angel eyes, they already went MIA.....
Old 12-31-2014, 01:49 PM
it was common back in 2010 to put 55w HID bulbs in the angel eyes, hence the possibility of melting angel eyes was high. but since then, 35w HID have come into the market and operates at a lower temp.
hence it is why i was asking the date of that photo. and that is the only photo i have every seen. also it shows the right hand side of the angel eye to be broken off, could be a defective early model or tampered with or otherwise.
at the end of the day, only a few things are clear, BMW headlight design is weak in comparison to Mercedes Benz and audi. Mtec's design is rather rudimentary and unsatisfactory, quite frankly i am surprised an American company such as yours cannot manufacture a rather brilliant retrofit.
Also the stuff you sell on your website is almost all from china, in the UK, anyone can import that stuff from china without question, even the cree led's, your 5600+lm per fog bulbs are actually advertised as by the real manufacturer as 1800-2500 per item. Won't be surprised if you file for bankruptcy in 5 years.
i diverge, people will choose to believe what they want to believe.
Old 12-31-2014, 01:54 PM
how long have you had them installed?
Old 12-31-2014, 02:43 PM
wjhughes420384's Avatar
wjhughes420384 wjhughes420384 is offline
2009 F02
Mein Auto: 750li, XJ8
these are my MTEC H8 4750 bulbs, I have been happy with them, and all I had to do was change the bulbs
http://www.bimmerfest.com/forums/att...1&d=1414507482
2009 750Li - Space Grau Metallic, Camera pkg, Conv pkg, Driver Asst pkg, Lux Seat pkg, Lux rear seat pkg, Prem sound pkg, Sport pkg, HUD, Massaging rear seats, Smartphone integration, Sat radio, MTEC H8 4750K Halo lights
Old 12-31-2014, 03:01 PM
CABimmerNation
Over 3 years. I put less than 7k miles on my car/ year and it never gets super hot here. Your results may vary.
Old 12-31-2014, 03:08 PM
CABimmerNation
Very few, like one or two have complained that the HID's melted their headlight assemble. So I say go for it.
Old 12-31-2014, 04:24 PM
Mein Auto: 335i
a perfect example of Dogma, which is defined as living with the results of others peoples thinking, when did we claim our MTEC led fog light kits are over 5600+ lumens??
any proof? we didnt think so since we didnt say that?
please go back to elementary school, where they teach you how to read and write and also basic math, you already failed twice, you think you know so much about HID angel eyes? you think you do, but obviously need much guided help, besides, we are actually designers , we can design HID angel eyes very easily anytime we want, maybe there is something that is hindering the process?
certain knowledge is better not said in public, sorry to be so dramatic, but its actually quite true
https://www.e92-lighting.com/hid-kit...100-lumen-new/
